    Solved PanelDue does not connect properly
    PanelDue
    282
    • donpedro
      donpedro last edited by mfs12
      Hello
      I have a Duet 3 Mini 5+ with PanelDue, I use RRF3.2.2 and on panel due I have version 3.2.11
      I would write command lines for the panel
      M575 P1 S1 B576000
      When the printer is turned on, the panel lights up, it shows me that the wifi connection has been made, but that's all, I can only access the setup menu
      I mention that the duel panel on a printer with duet 2 wifi works
      I don't know where the problem comes from
      Has anyone else hit her?
      • DaveA
        DaveA last edited by
        M575 P1 S1 B576000 Are you sure you have 576000 in the config or is this a typo in your post? 576000 is not a valid baud rate.
        donpedro 1 Reply Last reply Reply Quote 0
        • donpedro
          donpedro @DaveA last edited by
          @davea I added a zero in the post but in the config it's correct
          M575 P1 S1 B57600
            dc42 administrators @donpedro last edited by dc42
            @donpedro does the status in the top right corner show Connecting and never change? If so then it sounds like PanelDue is receiving data but unable to send it. If you are using the 4-wire cable, check the connection between Dout on the PanelDue and IN on the Duet IO port. The fact that PanelDue shows the popup WiFi status notification indicates that the baud rate etc. Is correct.
            donpedro 1 Reply Last reply Reply Quote 1
            • donpedro
              donpedro @dc42 last edited by
              @dc42 I use ribbon cable and the displayed status is connected, my IP appears but that's it
              I used the same panel due to a 2 wifi duet board and it works correctly there
              • T3P3Tony
                T3P3Tony administrators @donpedro last edited by
                @donpedro can you explain what does not work in more detail?
                www.duet3d.com
                oliof 1 Reply Last reply Reply Quote 0
                • oliof
                  oliof @T3P3Tony last edited by
                  @t3p3tony Wasn't RRF 3.2 the release where due to a bug you had to do M575 twice for the PanelDue to connect properly?
                  <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
                  • Topic has been marked as a question  mfs12 mfs12
                  • mfs12
                    mfs12 last edited by
                    Looks like a wiring issue.
                    Visit me on github at https://github.com/mfs12/
                    • mfs12
                      Closing due to inactivity.
                      • Topic has been marked as solved  mfs12 mfs12
