    New Raspberry Pi Zero 2W
    65
    4.0k
    • PCRundefined
      PCR @T3P3Tony
      @t3p3tony yes. I dont want to Stack in diectly on the Board. Because of some connectors. And yes the Header is placed diffrently on duet 3 and Duet Mini ;(
      PCRundefined 1 Reply Last reply Reply Quote 0
      • PCRundefined
        PCR @PCR
        @pcr btw someone from Germany who Likes to Test the Board ?
        o_lampeundefined PCRundefined 2 Replies Last reply Reply Quote 1
        • zaptaundefined
          zapta @T3P3Tony
          @t3p3tony said in New Raspberry Pi Zero 2W:
          definitely worth giving it a go though!
          How about a duet controller board with a plugged in Pi Zero for both controller and SBC functionalities?
          Edit: or a Pi Zero and a minimal MCU for i/o only, basically a Klipper style RRF on a single board.
          • o_lampeundefined
            o_lampe @PCR
            @pcr said in New Raspberry Pi Zero 2W:
            Ich habe heute einen Zero 2W bestellt, aber ich habe weder Duet3 oder Mini5+.
            Vielleicht @cosmowave ?
            English: I've ordered a Z2W, but don't have duet3 nor Mini5...maybe Cosmowave?
            • PCRundefined
              PCR @PCR
              @pcr
              pi@raspberrypi:~ $ neofetch
                `.::///+:/-.        --///+//-:``    pi@raspberrypi
               `+oooooooooooo:   `+oooooooooooo:    --------------
                /oooo++//ooooo:  ooooo+//+ooooo.    OS: Raspbian GNU/Linux 10 (buster) armv7l
                `+ooooooo:-:oo-  +o+::/ooooooo:     Host: Raspberry Pi Zero 2 Rev 1.0
                 `:oooooooo+``    `.oooooooo+-      Kernel: 5.10.63-v7+
                   `:++ooo/.        :+ooo+/.`       Uptime: 10 mins
                      ...`  `.----.` ``..           Packages: 533 (dpkg)
                   .::::-``:::::::::.`-:::-`        Shell: bash 5.0.3
                  -:::-`   .:::::::-`  `-:::-       Terminal: /dev/pts/0
                 `::.  `.--.`  `` `.---.``.::`      CPU: BCM2835 (4) @ 1.000GHz
                     .::::::::`  -::::::::` `       Memory: 49MiB / 427MiB
              pi@raspberrypi:~ $ ls /opt/dsf/sd
              filaments  firmware  gcodes  macros  menu  sys  www
              • PCRundefined
                PCR @T3P3Tony
                @t3p3tony https://copperhilltech.com/canpico-can-fd-module-with-raspberry-pi-pico/
                oliofundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                • oliofundefined
                  oliof @PCR
                  @pcr I am game.
                  • o_lampeundefined
                    o_lampe @PCR
                    @pcr
                    CAN-FD module for RasPi Pico I checked the prices of the main components: the CAN-FD module and the transceiver chip cost less than 3€
                    Why is this module so expensive?
                    • PCRundefined
                      PCR @o_lampe
                      @o_lampe dont Know. Could be the programming software. If Somebody would be interested in programming i would make a small Board with only the 2040 chip
                      • o_lampeundefined
                        o_lampe @PCR
                        It's open source
                        The open-source MicroPython SDK from Canis Labs implements a sophisticated CAN API, including priority-inversion free drivers, 1μs accuracy timestamps, large buffers, and an API for triggering a logic analyzer or oscilloscope.
                        If you make your own CAN-board, make sure all Pico through-hole pins are still available
                        • PCRundefined
                          PCR @o_lampe
                          @o_lampe Sure 😉 First development would be a hat for the pico
                          • o_lampeundefined
                            o_lampe @PCR
                            @pcr I wonder, if it would also work for the Zero 2W? A quad-core 1GHz SBC-board with CAN-FD would be a gamechanger...
                            • PCRundefined
                              PCR @o_lampe
                              @o_lampe
                              Should
                              https://copperhilltech.com/pican-fd-zero-can-fd-hat-for-raspberry-pi-zero-with-1a-smps/
                              o_lampeundefined 1 Reply Last reply Reply Quote 1
                              • o_lampeundefined
                                o_lampe @PCR
                                @pcr @T3P3Tony If we could integrate CAN-FD as PIO state machine in M0(Pico) hardware, we would only need a tranceiver...
                                • oliofundefined
                                  oliof @o_lampe
                                  @o_lampe is that realtime capable though?
                                  • o_lampeundefined
                                    o_lampe @oliof
                                    @oliof I started reading about PIO statemachines yesterday, so I might got a wrong impression. They say, those state machine work independant from the processor.
                                    I assume RRF uses them for pulse generation, too.
                                    • gloomyandyundefined
                                      gloomyandy @o_lampe
                                      @o_lampe said in New Raspberry Pi Zero 2W:
                                      Does RRF currently run on any hardware that has a PIO state machine?
                                      • o_lampeundefined
                                        o_lampe @gloomyandy
                                        @gloomyandy
                                        It seems only the M0 processor has those state machines. The M4 (duet2) doesn't have.
                                        I'm not even sure, if the Sam-C21 has them, although it's from the M0 family.
                                          gloomyandy @o_lampe
                                          @o_lampe I may be wrong but I think that those pio blocks are part of the rPi silicon and not part of the Arm core.
                                          Most of these devices are a combination of a core from Arm plus manufacturer specific peripheral devices. So for instance the SPI device on an STM mcu is more than likely totally different to the SPI devices on a microchip mcu even if they both have the same Arm core. Things get a little bit more confusing though because Arm does provide some standard peripheral designs, that some manufacturers may use (or I think can even modify). So for instance the the SSP device on the LPC1768 (which provides SPI functionality) is actually an ARM PrimeCell Synchronous Serial Port (PL022).
                                          • T3P3Tonyundefined
                                            T3P3Tony administrators @gloomyandy
                                            @gloomyandy said in New Raspberry Pi Zero 2W:
                                            Yes they are rpi specific
                                            Some Atmel/Microchip processors have a similar (but much more limited) idea called "configurable custom logic" designed as hardware "glue logic".
                                            PIO statemachines .....I assume RRF uses them for pulse generation
                                            We do not as they are Rpi 2040 specific. Although we have considered a range of options for pulse generation.
                                            Yes, that would be great, anyone found an example of CAN or a similar protocol implemented on 2040 statemachines, with a reference for what bus speeds could be accommodated?
                                            @PCR using that CAN-FD bus IC & transceiver with a Pi (either directly on a Pi 2/3/4, or using a 2040 + USB to a PC) could certainly allow for bus monitoring and protocol diagnosis, independent of using an oscilloscope so that could be interesting.
                                            Alternatively it might allow Klipper or similar to use Duet 3 expansion boards w/o a mainboard, they could implement the Duet CAN-FD protocol on the pi and send the planned moves to each board....
                                            www.duet3d.com
                                            o_lampeundefined zaptaundefined 3 Replies Last reply Reply Quote 1
