    Can paneldue's screensaver be customized?
    PanelDue
    778
    • JayTundefined
      JayT
      Is it possible to customize screensaver in PanelDue? Or the text that it displays? IF possible, how to do so? any guiding instructions.
      alankilianundefined oozeBotundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @JayT
        @jayt
        THIS page tells you how to update the "Splash" screen.
        I've never seen a "Screen saver" so I'm not sure if that's the same thing or not.
        JayTundefined 1 Reply Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @JayT
          @jayt no, it can't be updated outside of recompiling the firmware..
          • mfs12undefined mfs12 marked this topic as a question
          • mfs12undefined
            mfs12
            @JayT, no, it's not possible. If you want to change something to the screensaver you would need to adapt the sources or implement it and the re-compile it.
            Visit me on github at https://github.com/mfs12/
            JayTundefined 1 Reply Last reply Reply Quote 1
            • mfs12undefined mfs12 has marked this topic as solved
            • JayTundefined
              JayT @mfs12
              @mfs12 : So you mean, the text "Touch to wake up" is a hard coded string in the source code of Paneldue firmware. If we want to change it , we have to modify source code and rebuild. Same applies if we wish to change the screensaver to an image.
              Please confirm my understanding?
              • JayTundefined
                JayT @alankilian
                @alankilian : If you aren't aware, leave the machine/Paneldue unattended for a while, it switches to screensaver mode. We can modify the seconds after which the screensaver appears. I hope you are using the latest Paneldue SW to check on this
                • mfs12undefined
                  mfs12
                  @JayT, yes the text is hardcoded. The things which are NOT hardcoded are the configurations you can see in the setup tab. And there's no image used. But this sounds like an interesting feature being able to configure the screensaver background.
                  And you can also replace the splash screen. For this, check the repository and there are for sure some threads in the forum about.
                  • JayTundefined
                    JayT @mfs12
                    @mfs12 : I have changed the splash screen already 🙂
                    And I felt it would be nice if we can have a custom screensaver too.
                    May be you can tag someone who can address this feature, if feasible. Thanks!
                    • mfs12undefined
                      mfs12
                      @JayT tagged. 😉
                      • mfs12undefined
                        mfs12
                        how would you like to see the current screensaver to be improved?
                        oliofundefined JayTundefined 2 Replies Last reply Reply Quote 1
                        • oliofundefined
                          oliof @mfs12
                          @mfs12 a complete "backlight off" mode would be interesting.
                          oozeBotundefined 1 Reply Last reply Reply Quote 2
                          • oozeBotundefined
                            oozeBot @oliof
                            @oliof Agreed as any user would quickly learn to touch to wake it up without being told. We toy’ed with this but could t get the backlight to completely disable. Currently, we’ve settled on just removing the prompt so the screen is blank, but would really like to see it fully turn itself off for longevity of the panel.
                            • JayTundefined
                              JayT @mfs12
                              @mfs12 : I like the given suggestions. However, IF someone wants a custom screensaver, may be to display logo or machine is active then it would be nice. IF we completely black it off, it shouldn't appear like Panel not working...thats all.
                              @mfs12: Can you tell me where in source code I must look for this hardcoded string?
                              • mfs12undefined
                                mfs12
                                I created a feature request. Any progress will be reflected there.
                                https://github.com/Duet3D/PanelDueFirmware/issues/230
                                mfs12 created this issue in Duet3D/PanelDueFirmware
                                open Allow customization of screensaver #230
                                • mfs12undefined
                                  mfs12
                                  @JayT, check function "CreateScreensaverPopup" in src/UI/UserInterface.cpp. Good luck
