BLTouch stuck at 1000
Just last night i managed to successfully run a print. I went to collect it off my bed this morning and tried to simply run another one. When the printer went to home the z axis, it raised a couple mm before displaying the error that the bltouch was already triggered at the start of movement. Nothing i do seems to resolve this issue. Help?
@messiahman have you tried just resetting the BLtouch? read up on the M280 command. M280 P0 S160 your Px may vary. Otherwise post your config.g and homez.g homeall.g
@nurgelrot interesting, ill give it a try and let you know? I have been trying to turn the printer on and off, unplugged and replugged the bltouch wires, etc. etc., i didnt realize there was an actual function to just reset the bltouch
@messiahman Post your configs when you get a chance if its failing that much something isn't right.
@nurgelrot thats the thing though, like i said it was working fine last night and i havent since changed anything, its like the probe just decided “today’s not the day” lol
@messiahman Cosmic rays...
BLtouch are touchy. I had one just go nuts once too would always error out on a G29 ended up just replacing it cuz I never did figure out what was the issue and the config had worked for long time (and still does with the new one). But don't get too drastic yet. fiddle with the pin etc... see if you can see when/why it thinks its deployed. move your signal wires away from steppers etc...
@nurgelrot Sometimes is the grub screw. The screw has to be at a exact distance. See the manual for it
Is the BLTouch well clear of the bed when you power on?
If the probe touches the bed when it tries to do its self-test, it will fail.
@rjenkinsgb yeah no the entire extruder head is nearly to the top of the print area cuz my last print ended off pretty high up
@messiahman if the reading is 1000 when the pin is extended, most likely there is a break in the signal connection. On a genuine BLTouch this is usually the white wire.
@dc42 I've checked all the wires, theyre all pretty strong connections
Use a multimeter to test continuity of the wires themselves.
@messiahman you can test the Duet and your configuration by disconnecting the white wire and connecting that input on the Duet to ground. That should make the reading go to 0.
@dc42 that didn't work
@messiahman please post your config.g file and post a photo of the wiring connecting the BLTouch to the Duet.
@dc42 will do, but i did just unplug the whole bltouch to try and dispel any charge in the capacitor and replugged it all in, and now it won't deploy or retract.
; generated by RepRapFirmware Configuration Tool v3.3.3 on Wed Oct 06 2021 12:37:23 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"The Print-inator" ; set printer name
M918 P1 E4 F2000000 ; configure direct-connect display; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E136.79 ; set steps per mm
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X235 Y235 Z260 S0 ; set axis maxima; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P9 C"^zprobe.in" H3 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X40.00 Y5.0 Z1.250 ; set Z probe trigger value, offset and trigger height
M557 X40:220 Y25:220 S41 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S275 ; set temperature limit for heater 1 to 275C; Fans
M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@messiahman said in BLTouch stuck at 1000:
Does it light up at all? The plug at the BLTouch end is very delicate.
@phaedrux the red light comes on yes, but not the blue. it also goes through the startup sequence
Could you also post the contents of "deployprobe.g" and "retractprobe.g" please? There is a chance that's the source of your problem.
The reason why I am asking is this:
When you are issuing either M401 or M402 your BL's pin should move down or retract. If it does not, then either these files are missing altogether or they are referring to the wrong servo pin number.
The contents of deployprobe.g should look like this based upon your config.g (P0 = S0 = pin number):
M280 P0 S10
And second your retractprobe.g would be:
M280 P0 S90
Issue single M401 and M402 to see if your BL responds.
