    How to not require Home before next print?
    555
    • code7undefined
      code7
      Can someone remind me where I can disable the feature that requires a home move before the next print on a delta platform?
      Delta Printer Using a Duet 2 Wifi v1.04c, FW3.4.0beta2, Duet WiFi sever 1.26, Duet Web Control 3.3.0
      alankilianundefined zaptaundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @code7
        @code7 Look at the end GCODE provided by your slicer.
        There might be an M18 "Disable stepper motors" command in there.
        That was the reason my delta required homing every time.
        code7undefined 1 Reply Last reply Reply Quote 0
        • code7undefined
          code7 @alankilian
          @alankilian
          I just checked my sliced gcode and verified the slicer isn't putting an M18 in there.
          alankilianundefined 1 Reply Last reply Reply Quote 0
            alankilian @code7
            @code7 Can you post a small GCODE file?
            Maybe it's M84.
            What are you using as a slicer?
            code7undefined 2 Replies Last reply Reply Quote 0
            • code7undefined
              code7 @alankilian
              @alankilian
              I don't see M84 anywhere in the gcode either. I'm using Simplify3D.
              • code7undefined
                code7 @alankilian
                @alankilian
                I just found M84 in the Cancel macro. Thanks!
                alankilianundefined 1 Reply Last reply Reply Quote 2
                  alankilian @code7
                  @code7 Look at the Ending Script tab.
                  Also, can you post a small GCODE file?
                    alankilian @code7
                    @code7 said in How to not require Home before next print?:
                    @alankilian
                    Oh, I didn't know you were cancelling a print.
                    I would have suggested that. 🙂
                    Great news anyway.
                      If you happen to know that the print head is in the same position post print every time because you home it at the end of a print and power off the motors, you could create a macro that just uses G92 to force set that position again to mark the axis as homed. I would be reluctant to trust that for the Z axis unless you've verified the Z doesn't drop at all.
                      • code7undefined
                        code7 @Phaedrux
                        @phaedrux OK - thanks
                        • zaptaundefined
                          zapta @code7
                          Why do you want to do that? Saving time or something else?
