    230v heatbed thermal runaway
    816
    • Poul Erikundefined
      Poul Erik
      Hi Duet Forum
      I have a problem with thermal runaway on my heatbed.
      The temperature will continue rising past the temperature I set in the Web interface, even if I push the emergency stop button.
      Apparently I get the correct temp reading, but the board doesn´t shut down the bed heater.
      What is going on? Can anyone suggest a solution ?
      Thanks in advance.
      Poul Erik
      printer spec:
      Deltaprinter
      Duet Wifi
      230v heatbed / SSR
      T3P3Tonyundefined Poul Erikundefined zaptaundefined 3 Replies Last reply Reply Quote 0
      • T3P3Tonyundefined
        T3P3Tony administrators @Poul Erik
        @poul-erik you need to post how the board and temperature sensor are wired. also post your config.g
        www.duet3d.com
          Poul Erik @Poul Erik
          @poul-erik
          config.g:
          ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sun Jun 07 2020 22:29:30 GMT+0200 (Centraleuropæisk sommertid)
          M550 P"DuetWasp" ; set printer name
          M665 R391.149 L613 B200 H748.863 X0.011 Y-0.286 Z0 ; Set delta radius, diagonal rod length, printable radius and homed height , X,Y,Z tower position correction
          M666 X-0.05 Y0.54 Z-0.49 ; put your endstop adjustments here, or let auto calibration find themx
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S0 ; physical drive 0 goes backwards
          M569 P3 S0 ; physical drive 3 goes backwards
          M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation, enabled
          M92 X80.00 Y80.00 Z80.00 E400 ; set steps per mm
          M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X1800.00 Y1800.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X700 Y700 Z700 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z0 S1 ; set minimum Z
          M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
          M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
          M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin null
          ; M574 E1 S0 P"fstop" ; configure active-high endstop for high end on filerment
          ;M574 U2 S1 ; active high endstop switches, XYZ at min, U at max
          M581 E1 S1 T3 C0 ; filament out, 2=simple sensor (low signal when filament present) C1 when running this, C0 is only for testing
          M558 P1 C"zprobe.in+zprobe.mod" H3 F5 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          ;M558 H3 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
          G31 P500 X3 Y3 Z 1.251 ; set Z probe trigger value, offset and trigger height
          M557 R180 S20 ; define mesh grid
          ; Heaters ;Bed
          M305 P0 T100000 B3977 R4700 ; Set thermistor + ADC parameters for heater 0
          M143 H0 S110 ; set temperature limit for heater 0 to 110C
          M307 H0 A190.4 C1871.8 D7.2 V16.6 B0 ;Pid tuning bed
          ;hotend
          M305 P1 P"e0temp" Y"thermistor" T500000 B4217  ; configure sensor 1 as thermistor on pin e0temp
          M307 H1 A338 C126.3 D3.3 V23.9 B0 ; Pid tuning heater
          ; MCU
          M912 P0 S35.5 ; MCU temperature calibration
          M106 P0 S1.0 H-1 I0 ; set fan 0 value, H-1=PWM disabeled= Thermostatic control is turned off. Invert PWM (I1), disable fan (I-1), or normal mode (I0, default)
          M106 P1 S255 F500 X0.2 H1 T45 B0.1 ; set fan 1 value. On. (F500 frequency.) Thermostatic control is turned on, start at 45dgr.
          ;(B0.1= Time for which the fan will be operated at full PWM when started from cold 0,1sec. (L0.05 X0.2 = Min power 0.5pct. Max power20pct)(H1 T45 Start at45 dgr)
          M563 S"Maby this will work"P0 D0 H1 F0 ; define tool 0
          • T3P3Tonyundefined
            @poul-erik the configuration is not correct for RepRapFirmware 3. There was a change to use M308 not M305 to define temperature sensors and first the heaters need to be defned with M950 so I guess you are using older RRF?
            What is the result of M115?
            www.duet3d.com
            Poul Erikundefined 1 Reply Last reply Reply Quote 0
              Poul Erik @T3P3Tony
              @t3p3tony
              m115
              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
              • T3P3Tonyundefined
                @poul-erik ahh ok that makes more sense.
                And how is the SSR wired?
                If you start up the Duet does the bed begin heating immediately or only when you set the temperature?
                www.duet3d.com
                Poul Erikundefined 3 Replies Last reply Reply Quote 0
                  Poul Erik @T3P3Tony
                  @t3p3tony
                  Yes, it starts heating rightaway.
                    Poul Erik @T3P3Tony
                    @t3p3tony
                    i would have to take the printer apart to answer how the it is wired.
                      Poul Erik @T3P3Tony
                      @t3p3tony
                      Thank you Tony, I really appreciate your time.
                      The wiring is pretty standard and worked until yesterday.
                      I suspect you are asking for somthing other than what the image is showing! But what?
                      Kind Regards
                      Poul Erik
                      achrnundefined 1 Reply Last reply Reply Quote 0
                      • achrnundefined
                        achrn @Poul Erik
                        @poul-erik said in 230v heatbed thermal runaway:
                        SSRs do fail, and permanently-on is the most common failure mode, which would match your symptoms (bed starts heating as soon as mains power is applied, no control over it).
                        • Gixxerfastundefined
                          Gixxerfast
                          Is the bed marked as active in the DWC?
                          Also have you measured the input of the SSR, does the LED on the SSR (if there's one) light up ?
                          Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                          Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                          Ender 3 Pro with BTT SKR-2 + RRF
                          • zaptaundefined
                            zapta @Poul Erik
                            @poul-erik , if you disconnect the driving wires between the Duet and the SSR, does the bed heats when you turn the printer on? If so, you may have shorted SSR.
                            Also, does your SSR have a led, indicating the control signal? I so, it will help you identify if the problem is on the duet/firmware side or the SSR.
                            And whatever you do, think safety first.
                            Poul Erikundefined 1 Reply Last reply Reply Quote 1
                              Poul Erik @achrn
                              @achrn
                              Thank you, much appreciated!
                                Poul Erik @Gixxerfast
                                @gixxerfast said in 230v heatbed thermal runaway:
                                HI @gixxerfast The heatbed will turn on even if the bed is not marked as active.
                                Thank you.
                                Poul Erik
                                  Poul Erik @zapta
                                  @zapta said in 230v heatbed thermal runaway:
                                  Thank you @zapta
                                  What might cause the SSR to short?
                                  //pe
                                  • achrnundefined
                                    achrn @Poul Erik
                                    SSRs are not 'bulletproof' and are more finicky than many people believe.
                                    The main problem with SSRs is that most of the ones on ebay, amazon, etc. are fakes and only good for a fraction of their stated rating. Even if you have a genuine one, the rating is that for an ideal situation - no heating, no inrush current, no capacitive load etc. Admittedly, a heater element is much closer to that than many loads.
                                    Personally, my rule of thumb is always use an SSR that has a rating at least twice and preferably three times what the load actually draws.
                                      Poul Erik @achrn
                                      Thank you @achrn
                                      Your time is much appreciated.
                                      I will change the SSR and see if this solves my issue.
                                      //pe
                                      dc42undefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                        dc42 administrators @Poul Erik
                                        @poul-erik I suggest you disconnect the SSR from the Duet. If the bed heater still turns on as soon as you turn the power on, then the SSR is shorted.
                                        • zaptaundefined
                                          zapta @Poul Erik
                                          @poul-erik, I recommend one of the ssrs listed here https://vorondesign.com/sourcing_guide?model=V2.4, for yours mains voltage.
                                          3A sends to be on the low side.
                                          • Th0mpyundefined
                                            Th0mpy
                                            I'd also recommend looking at a physically bigger model. I have had good luck with this style, plus you can mount it on some aluminum to dissipate heat: https://www.digikey.com/en/products/detail/kacon/KMSR-DS0104/13148008 rated for 10A which should be enough.
                                            Usually the team that scores the most points wins the game.
                                            Gixxerfastundefined 1 Reply Last reply Reply Quote 0
