    please help me blv setting
    129
    7.9k
    • A Former User?
      A Former User @oliof
      @oliof
      I put new pei my ca does not adhere to 60 degrees
      • A Former User?
        @oliof
        as the aluminum plate is 10mm I have to heat for 30 minutes to 60 after it holds
        • oliofundefined
          oliof @A Former User
          @sgk that's quite possible. If you let the print bed soak the heat, does the print adhere better? Show us a new photo.
          To speed up printing, I suggest a simple 30mm cube in vase mode.
          • A Former User?
            @oliof hello I tried to print more than once at 60d but the cubes end up taking off I must put in mini 80d.
            I put a new pei sheet and the same ideas?
            • oliofundefined
              oliof
              Since 80C is way above PLA glass transition temperature, your thermistor configuration may be wrong Please confirm what kind of thermistor you bought for this build.
              Alternately, the thermistor ADC may need calibration.
              you're saying you can print a vase mode cube with the bed at 80C -- can we get a photo of that?
              A Former User? 3 Replies Last reply Reply Quote 0
              • A Former User?
                @oliof
                good morning, how are you doing? yes ok
                • A Former User?
                  • A Former User?
                    @oliof the bed
                    • A Former User?
                      A Former User @A Former User
                      @sgk IMG_20211215_095813_edit_63873446177232.jpg IMG_20211215_100009_edit_63813279327762.jpg IMG_20211215_095846_edit_63849951138173.jpg IMG_20211215_095839_edit_63860796521504.jpg
                      • A Former User?
                        @sgk and i have this error too
                        • A Former User?
                          • oliofundefined
                            oliof
                            still looks slightly hot on the bed surface. and you either have z banding from a z drive that's not straight, and/or banding like artifacts from a bed heater that's not PID tuned.
                            • oliofundefined
                              oliof
                              (also it doesn't look like a single wall vase mode print)
                              • A Former User?
                                @oliof
                                the bottom part it's just that I didn't turn on the fan
                                • A Former User?
                                  @oliof how do i have to?
                                  • A Former User?
                                    @oliof 16/12/2021, 10:05:15 Warning: Turning on the print cooling fan did not increase hot end cooling. Check that the correct fan has been configured.
                                    Auto tuning heater 1 completed after 3 idle and 10 tuning cycles in 671 seconds. This heater needs the following M307 command:
                                    M307 H1 B0 R2.737 C155.7:155.7 D8.86 S1.00 V23.5
                                    Send M500 to save this command in config-override.g
                                    i have this error the pid tune
                                    • oliofundefined
                                      oliof
                                      I see you are currently getting help in the STM RRF Discord. Please follow the advice you get there and let's continue here when you're done.
                                      • A Former User?
                                        @oliof thank you to you I ask for help or I can nothing bad I take the advice of all those who can help me.👍
                                        • oliofundefined
                                          oliof
                                          no worries, it just doesn't help doing things in parallel.
                                          • A Former User?
                                            @oliof please excuse me just that it will be 2 years since trying to adjust this printer and I was looking for help for a while so I ask a can everywhere I start to lose hope and it is true that the people are really nice to me also you but for the moment I still have the same problem as 2 years ago.
                                            thank you very much for your help it's really nice👍 ☺
