    please help me blv setting
    129
    7.9k
    • martin7404undefined
      martin7404 @A Former User
      @sgk p.s speed, accel , jerk ?
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
      • A Former User?
        A Former User @martin7404
        @martin7404
        I can't find where the graphics are
        martin7404undefined 1 Reply Last reply Reply Quote 0
          @sgk On DWC heightmap
          • A Former User?
            @martin7404 Capture d’écran 2021-12-17 133901.jpgRepRapFirmware height map file v2 generated at 2021-12-17 13:36, min error -0.140, max error 0.223, mean 0.055, deviation 0.129
            axis0,axis1,min0,max0,min1,max1,radius,spacing0,spacing1,num0,num1
            X,Y,20.00,270.00,20.00,270.00,-1.00,240.00,240.00,2,2
            0.076, 0.223
            0.062, -0.140
            • A Former User?
              A Former User @A Former User
                @sgk it is ok, but I will suggest you do at least 16 points map
                A Former User? 2 Replies Last reply Reply Quote 0
                • A Former User?
                  @martin7404 ok 16
                  • A Former User?
                    @martin7404 how do you manage to put in 16?
                    • A Former User?
                      @sgk ; bed.g
                      ; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300
                      M291 P"Probing mesh grid process started" R"Probing.." S1 T2
                      G28 ; home all axis bb
                      M671 X-30.0:364.0 Y175.0:175.0 S5.0 ;bed compensation
                      G30 P1 X5 Y150 Z-99999
                      G30 P0 X300 Y150 Z-99999 S2
                      G90 ; absolute positioning bb
                      M557 X20:270 Y20:270 S240 ; Define mesh grid
                      G29 S0 ; Probe the bed and save height map to file
                      M374 ; Save calibration data. Default is sys/heightmap.csv
                      M291 P"Probing mesh grid process finished !" R"Probing.." S1 T2
                      ; Probe the bed at 4 points
                      ;G30 P0 X10 Y10 H0 Z-99999
                      • A Former User?
                        This post is deleted!
                        • A Former User?
                          • A Former User?
                            @sgk Hey friends after changing the thermistor probe for a Semitec 104GT-2 the lines are now straight horizontally but the vertical lines are shifted and lack of filament as we see in the photos? Any ideas folks?IMG_20211217_193356_edit_145064851518488.jpg IMG_20211217_193332_edit_145086467969527.jpgIMG_20211217_194559.jpg
                            engikeneerundefined 1 Reply Last reply Reply Quote 0
                            • engikeneerundefined
                              engikeneer @A Former User
                              @sgk to me, that looks like either z banding or a bed that doesn't have great PID control (so the bed temperatures fluctuate through the print).
                              If it is z banding, I.e. some issue with the z axis motion, things to look for would be:
                              • is there room for the ball screw to float a bit in case there is any misalignment?
                              • are the ball screws straight?
                              • do they wobble at all as the z axis moves?
                              • are the z guides giving the bed enough support (I.e. can the bed move in x and y at all)
                              For the PID issue, watch your bed temp during a print - it should be pretty stable. Also double check you are using it in PID mode, not bang bang
                              i3 clone with a bunch of mods
                              • A Former User?
                                A Former User @engikeneer
                                @engikeneer
                                hello thank you very much for your help. This has to say that I am an average novice there are things that I do not understand, excuse me
                                but how do I know and how can I verify all this?I put a new thermistor for the hotend I must also do for the bed?
                                the z rods are mounted on sfu1204 I imagine they are straight.
                                i have this the zCapture d’écran 2021-12-17 210600.jpg Capture d’écran 2021-12-17 210549.jpg
                                A Former User? Nuramoriundefined 2 Replies Last reply Reply Quote 0
                                • A Former User?
                                  @sgk i have this for z
                                  https://youtube.com/shorts/-nA3WhPwsdA?feature=share
                                    @sgk well that mount looks good for the bed end - looks like it's got some room for flex in x and y which is good.
                                    Maybe down at the motor end, might be worth checking that. Is the coupler to the z motor perfectly concentric? I had a cheap one once that wasn't and made the bottom of the z screw wobble a lot. Maybe loosen the screws for the black support piece so it is slightly free and see if it wants to wobble?
                                    • Nuramoriundefined
                                      Nuramori @A Former User
                                      @sgk I run a BLV with SF1024 ball screws as well. With this set up you need the top blocks - the approach with lead screws does not translate well when you change to ball screws. Your variations in the horizontal layers going vertically is from micro shifts that are occurring, and it’s exacerbated with a two screw setup over a three a axis layout.
                                      You also may want to rerun a PID. What version of the firmware are you running?
                                      Nuramoriundefined 1 Reply Last reply Reply Quote 0
                                      • Nuramoriundefined
                                        Nuramori @Nuramori
                                        Example of output. Ignore the zits, I was still tuning the pressure advance and coasting after installing ball screws.
                                        • A Former User?
                                          A Former User @Nuramori
                                          @nuramori hello my print is
                                          Board: Duet 2 WiFi (2WiFi)
                                          Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
                                          Duet WiFi Server Version: 1.26
                                          i have thsi engine moons
                                          thank you very much friends i will start to control the z.
                                          I have installed a new semitec 104gt-2 104nt-4 and pid 3 x thermistor
                                          It can also come from the hotend fan because at home I can not adjust it?
                                          • A Former User?
                                            are normal when I do the pid my fan does not cut hotend?
