    please help me blv setting
    129
    7.9k
    • PaulHewundefined
      PaulHew
      Due to the size of my bed, I use 2 thermistors. 1 in the heat mat, Keenovo and I have a slot in the top of the bed to take a second.
      For safety I use the thermistor in the heatmat, but the one in the top to give me a better idea of what the heat on the bed is.
      Regardless what material I am printing, I let the bed and printer warm up for 50mins to an hour. My bed is 8mm thick
      All Z tweaks are done at temp. ie Z Offset. Bed at 100 nozzle at 150.
      As @oliof mentioned, 80 degress is way to hot for PLA.
      If you use SuperSlicer, there is a lot of calibration tools in it, to help get your bed level, extrusion rates, bridging speeds etc.
      Has helped me a lot.
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
      • A Former User?
        A Former User @PaulHew
        @paulhew hello indeed it works well after heating 1 hour to 60 of the rooms are glued to the bed thank you for your advice. But the cubes are full of lines as before.
        • PaulHewundefined
          PaulHew
          I have looked, but what printer is it please?
          Picture also?
          • A Former User?
            • PaulHewundefined
              PaulHew
              3 things that could be an issue.
              Has the gantry been de-racked?
              Do the Z rods move smoothly, no untoward noise? Bed securely fixed.
              How old is the PLA? and is it a good quality?
              I keep my PLA and PETG in a sealed box when not in use. Has a rechargeable silica box in it.
              And before use, I throw it in the de-humidifier for an hour.
              A Former User? 2 Replies Last reply Reply Quote 0
              • A Former User?
                @paulhew hello yes my z it's sfu 1204
                yes it moves noiselessly well oiled it pla ila 2 months but I use it on my cr10s and the parts are perfect the bed well fixed nothing abnormal
                • A Former User?
                  A Former User @A Former User
                  @sgk Has the gantry been de-racked? what does it want? racked
                  • A Former User?
                    @sgk I changed my hotend dragon hf plus extrudezr orbitor and my rods slide perfectly
                    • A Former User?
                      @paulhew
                      I made another cube to see I did the pid hotend again
                      • A Former User?
                        @sgk IMG_20211217_102826_edit_129272722893814.jpg IMG_20211217_102657_edit_129323993582869.jpg
                        martin7404undefined 1 Reply Last reply Reply Quote 0
                        • martin7404undefined
                          martin7404 @A Former User
                          @sgk From All the writings and photos If I was in your shoes, I would do the following
                          1. Both bed and hotend temp check with external measurement and then calibration
                          2. SFU are stiff, so some kind of anti-wobble device for the nut, it can be nylock nuts or some printed set
                          3. Flow calibration and E steps
                          4. finally X/Y stage, belts tensioning check
                          Muldex IDEX Duet2+Duex5
                          Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                          Sapphire Pro with Duet2, with closed-loop motors
                          custom high temp E3D tool changer with Duet2+Duex
                          A Former User? 4 Replies Last reply Reply Quote 0
                          • A Former User?
                            A Former User @martin7404
                            @martin7404 the sfu i have this
                            https://www.thingiverse.com/thing:4768321?fbclid=IwAR0n1YD84eqXpPBC8l3FB_EwVlQDytEEF3Mr6htjmp5YXfQqavotYp6uZ6I
                            • A Former User?
                              @martin7404 the hotend before I had e3dv6 and a different probe the z of t8 metal and extruder bmg changed to extruder orbitor and I had the same problem and when I touch the adjustment of the belt I have not much difference
                              • A Former User?
                                @martin7404 I wonder if the problem is not related to that because I print a 20x20x20 cube all the dimensions full and on the graphics it is not goingCapture d’écran 2021-12-17 122206.jpg
                                • A Former User?
                                  @martin7404
                                  here it is a graphic of someone who printed the same cube as me, we see that the lines are always the sameCapture d’écran 2021-12-17 122429.jpg
                                  • A Former User?
                                    @sgk
                                    do you know why the time of each layer is not the same while the cube is the same everywhere
                                    A Former User? martin7404undefined 2 Replies Last reply Reply Quote 0
                                    • A Former User?
                                        @sgk If you are sure Your bed is level and there is no wobble in the Z axis
                                        then it is extrusion calibration and temperatures
                                        • A Former User?
                                          @martin7404
                                          I do before each print g29
                                            @sgk ok can you share your bed graph
