    please help me blv setting
    129
    7.9k
    • A Former User?
      A Former User @A Former User
      @sgk IMG_20211218_182649_edit_169907502282926.jpg IMG_20211218_182614_edit_169921141748549.jpgIMG_20211218_190726_edit_171302484032192.jpg
      • A Former User?
        new cube test with the bed off? and new pid what do you think?
        mor setting z.
        still so bad I am always so badly depressed.
        frankly friends i am really losing hope.😭 😭
        how do you manage to have beautiful pieces?
        Nuramoriundefined 1 Reply Last reply Reply Quote 0
        • Nuramoriundefined
          Nuramori @A Former User
          @sgk you’re showing signs of overextension. To give you some idea, even though I have calibrated the extrusion, I still have my extrusion volume at 80% in my slicer (Cura). You can easily experiment with your settings to dial this down.
          The banding that’s evident can be a number of factors, but I would look at securing the top of your ball screws and verifying that your belt tensions are equal and high enough in tension. I would also look at your extrusion temperature.
          • A Former User?
            A Former User @Nuramori
            @nuramori
            hello and thank you for your answers do you have a cura config to share? i will make the part for the top of the rod 1204👍
            • A Former User?
              @sgk IMG_20211220_112813_edit_203782506463694.jpg IMG_20211220_112656_edit_203821483563167.jpg IMG_20211220_112919_edit_203764703782968.jpg
              with the bk support at the top I have this quality.
              on the cube it is as if there is a lack of material as seen in the photo.
                Have you tried to print a temp tower? It looks like your temps may be too high. The surface is very glossy. This can also lead to the messy walls and give the appearance of over extrusion.
                • A Former User?
                  A Former User @Phaedrux
                  @phaedrux thank you for your answer indeed I have the impression that the walls are not right I do not know where it can come from your an idea?
                  what does it mean?
                    Phaedrux Moderator @A Former User
                    @sgk said in please help me blv setting:
                    what does it mean?
                    The simplest way would be to print that same cube, but every so often reduce the temperature by 5c
                    You may also find this calibration guide helpful.
                    https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                    A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    • A Former User?
                      @phaedrux yes I printed at 190 to 195 200 205 210 215 220 but the result is almost the same not much difference.
                      but not continuously.
                        How low of a temp can you set and still reliably extrude?
                        What kind of thermistor do you have and what parameters have you set for it in your config? If those values are very wrong for the thermistor your temps could be wildly off.
                        If you can extruder PLA much below 180 I think that may be part of the problem.
                        • A Former User?
                          @phaedrux it is true that I have not tried 180 or even 175.
                          M350 X16 Y16 Z16 E16 I1                            ; Configure microstepping with interpolation
                          M92 X201.00 Y201.00 Z800 E693.55                 ; Set steps per mm for orbiter
                          M566 X500 Y500 Z800 E600                          ; Set maximum instantaneous speed changes (Jerk) (mm/min)
                          M203 X20000 Y20000 Z600 E3600                      ; Set maximum speeds (mm/min)
                          M201 X1000 Y1000 Z100 E600 	                   ; Set accelerations (mm/s^2)
                          M906 X1500 Y1500 Z1000 E500 I10                   ; Set motor currents (mA) and motor idle factor in per cent
                          ;M84 S30                                            ; Set idle timeout
                          ;M350 E16 I1 ;micro stepping set to 16 with interpolation
                          ;M92 E690 ;steps/mm - you may need to finetune it
                          ;M203 E3600 or E7200 ;max speed mm/min
                          ;M566 E600 ;instantaneous speed change mm/min
                          ;M201 E600 or E800 ;acceleration mm/s^2
                          ;M906 E500 or E1200 I10 ;motor current mA idle current 10%
                                                        ; ===================== Axis Limits ========================
                          M208 X-23 Y0 Z0 S1                                                             ; Set axis minima
                          M208 X320 Y320 Z350 S0                                                         ; Set axis maxima
                                                        ; ======================== Z-Probe =========================
                          M558 P1 C"^zprobe.in" H5 F200 T9000 I0 R0.5                  ; Set Z probe type mini ir sensor
                          G31 P500 X-2.24 Y-20.81 Z1.300                                 ; Set Z probe trigger  value, offset and trigger height
                          M557 X20:270 Y20:270 S240			   	        ; Define mesh grid
                                                       ; ======================== Heaters =========================
                          M308 S0 P"bed_temp" Y"thermistor" T100000 B3950                   ; define bed temperature sensor
                          M950 H0 C"bed_heat" T0                                            ; heater 0 uses the bed_heat pin, sensor 0
                          M307 H0 R0.272 C388.6 D16.77 S1.00 V23.6                          ; Heatbed PID
                          M140 H0                                                 	      ; map heated bed to heater 0
                          M143 H0 S120                                            	      ; set temperature limit for heater 0 to 120C
                          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8            ; define E0 temperature sensor
                          M950 H1 C"e0heat" T1                                              ; heater 1 uses the e0heat pin and sensor 1
                          M307 H1 B1 R2.466 C168.0:167.2 D4.81 S1.00 V23.5		          ; Hotend PID .4mm
                          M143 H1 S260							                          ; set temperature limit for heater 0 to 260C
                          M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" 		              ; Configure MCU sensor
                          • A Former User?
                            @sgk ; ======================== Tools ===========================
                            M563 P0 S"T1" D0 H1 F1 ; Define tool 0
                                                      ; ========================= Fans ===========================
        hotend fan/ hotend
                            M106 P1 S1 H1 C"hotend" T45 ; set fan 1 value. Thermostatic control is turned on 100% at 45deg
        Tool Fan/ Layer Fan
                            M106 P0 S0.5 H-1 C"Layer fan" ; set fan 0 value. Thermostatic control is turned off
                            M950 F2 C"fan2" Q250 ; create fan 2 on pin fan2 and set its frequency
                            M106 P2 S0.15 H-1 F250 C"AC alimentation" ; set fan 2 value. Thermostatic control is turned off
                                                        ; ===================== Custom settings ====================
                            M572 D0 S0.015 ;pressure advance Set bowden extruder elasticity compensation for E0
                            M207 S1.5 F3600 Z0.01 ; Set firmware retraction parameters
                            M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
                            • A Former User?
                              @sgk
                              I also put in bangbang b1 born the same.but why I have the walls that are not straight as if the extruder the filament does not come out permanently.
                                This looks like the values for the E3D semitek thermistor. Is that what you have? From your previous post it seems so.
                                are normal when I do the pid my fan does not cut hotend?
                                What command did you use to PID tune the hotend?
                                M303 T0 S220?
                                • A Former User?
                                  @phaedrux i have hotend dragon + thermistor semitec 104
                                  M303 T0 S220 Where 205
                                    Phaedrux Moderator @Phaedrux
                                    @phaedrux said in please help me blv setting:
                                    I would suggest that going through this guide first would be helpful to help use know if your extruder is properly calibrated first.
                                    • A Former User?
                                      @phaedrux
                                      I tried a lot of things but I can find the problem even changing a lot of things it's depressing
                                      • A Former User?
                                        @sgk
                                        I calibrated several times the extruder made tests
                                        • A Former User?
                                          @sgk
                                          thank you very much I will look for I will redo the extruder test thank you
                                            can you show us a video of the printer in action?
                                            Maybe share a sliced gcode file so we can see the slicer settings?
