    Surfacing Macro
    CNC
    11
    28
    2.6k
    • chimaeraghundefined
      chimaeragh @sinned6915
      @sinned6915 I have modified the macro for an Ooznest Workbee with their latest Firmware (RRF3.3). M3 starts the router and M5 stops it.
      ; Constants
      var Debug = false;
      var ProbeThickness = 5;
      var CoordSystem	= 20;
      var StepOver = 10;
      var DepthOfCut = 0.2;
      var FeedRate = 8000;
      var ZClearanceHeight = 25;
      ; Variables
      var StartX = 0;			; The X starting position
      var StartY = 0;			; The Y starting position
      var EndX = 0;			; The X ending position
      var EndY = 0;			; The Y ending position
      var YDir = 0;			; The direction to go in Y
      var YDist = 0;			; The distance to go in Y
      var YPos = 0;			; The position in Y to move to
      var YDistLeft = 0;		; How much we have left to move in Y
      var ZDepth = 0;			; How far down we should be in Z
      var XSorE = "End"		; Whether X should move towards the start or the end position
      ; If the printer hasn't been homed, home it
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
         G28
      ; Adjust probe for low speed probing
      M558 K0 P8 C"!e0stop" H20 F120 T300					; Z probe number - Z probe switch type - probe recovery 1s probe speed and travel speed
      G31 K0 P500 X0 Y0 Z0								; Set trigger value - set offset and trigger height - Z probe number
      M291 P"Insert your surfacing bit into your spindle and position it above the probe plate" R"Probing" S3 X1 Y1 Z1
      ; Set bit above center of probe
      G91	; relative positioning
      ; Probe Z component
      G38.2 Z{move.axes[2].userPosition - (var.ProbeThickness + 2.25)}			; seek until the probe circuit is closed Z-axis 25 mm
      G0 Z{var.ZClearanceHeight}													; rapid move Z axis 5 mm
      G10 P1 L{var.CoordSystem} Z{var.ProbeThickness + var.ZClearanceHeight}		; store relative probe offset for coordinates system 1
      G90	; Absolute positioning
      M291 P"Move to the starting X Y position for surfacing" R"Start Position" S3 X1 Y1 Z0
      set var.StartX = move.axes[0].userPosition;
      set var.StartY = move.axes[1].userPosition;
      if var.Debug
         M118 P0 S{"StartX = " ^ var.StartX} L2
         M118 P0 S{"StartY = " ^ var.StartY} L2
      M291 P"Move to the ending X Y position for surfacing" R"End Position" S3 X1 Y1 Z0
      set var.EndX = move.axes[0].userPosition;
      set var.EndY = move.axes[1].userPosition;
      if var.Debug
         M118 P0 S{"EndX = " ^ var.EndX} L2
         M118 P0 S{"EndY = " ^ var.EndY} L2
      M291 P"Are you ready to begin surfacing?" S3 X0 Y0 Z0
      ; Figure out which direction in Y we are going
      if var.EndY < var.StartY
         set var.YDir = -1;
      elif var.EndY > var.StartY
         set var.YDir = 1;
      else
         set var.YDir = 0;
      if var.Debug
         M118 P0 S{"YDir = " ^ var.YDir} L2
      set var.YDist = {abs(var.StartY - var.EndY)};
      if var.Debug
         M118 P0 S{"YDist = " ^ var.YDist} L2
      ; Begin surfacing loop
      while true
         if var.Debug
         	M118 P0 S"Begin Layer Loop" L2;
         set var.ZDepth = {var.ZDepth - var.DepthOfCut};
         set var.YDistLeft = {var.YDist};
         ; go to the start X and Y position then down to Z Depth
         if var.Debug
         	M118 P0 S{"Move to start X" ^ var.StartX ^ ",Y" ^ var.StartY} L2
         T1
         M3 S17500 ;M42 P1 S1
         G0 X{var.StartX} Y{var.StartY}
         if var.Debug
         	M118 P0 S{"Move to start Z" ^ var.ZDepth} L2
         G1 Z{var.ZDepth}
         ; we should be at the Start X position so move to the End X position
         if var.Debug
         	M118 P0 S{"Move to X" ^ var.EndX} L2
         G1 X{var.EndX} F{var.FeedRate}
         set var.XSorE = "Start"
         while var.YDistLeft > var.StepOver
         	if var.Debug
         		M118 P0 S"Begin Y Loop" L2
         	; move in Y by StepOver
         	set var.YPos = {move.axes[1].userPosition + (var.StepOver * var.YDir)}
         	if var.Debug
         		M118 P0 S{"Move to Y" ^ var.YPos} L2
         	G1 Y{var.YPos} F{var.FeedRate}
         	set var.YDistLeft = {var.YDistLeft - var.StepOver}
         	if var.XSorE == "Start"
         		; move X to the start position
         		if var.Debug
         			M118 P0 S{"Move to X" ^ var.StartX} L2
         		G1 X{var.StartX} F{var.FeedRate}
         		set var.XSorE = "End"
         	else
         		; move X to the end position
         		if var.Debug
         ; move in Y the rest of the distance left
         set var.YPos = {move.axes[1].userPosition + (var.YDistLeft * var.YDir)}
         if var.Debug
         ; one last move in X
         	if var.Debug
         else
         	if var.Debug
         G0 Z{var.ZClearanceHeight}					; get out of the way
         M400										; wait for the movement buffer to catch up
         M5 ;M42 P1 S0
         M291 P"Surface another layer?" S3 X0 Y0 Z0	; then prompt the user if they want to do another layer
      Duet 2 Wifi, Ooznest Workbee CNC 1510
      sinned6915undefined 1 Reply Last reply Reply Quote 0
      • sinned6915undefined
        sinned6915 @chimaeragh
        @chimaeragh thank you. i am downloading now and will try it again.
        chimaeraghundefined 1 Reply Last reply Reply Quote 0
          @sinned6915 Line 89 selects the tool (T1). If your spindle is set to tool 0 (T0) change it accordingly. Line 90 sends the M3 command to start the spindle.
          • CthulhuLabsundefined
            CthulhuLabs @sinned6915
            @sinned6915 sorry for the late reply. Have not been on this forum for a while. No I am not using a PanelDue. I am using a Pi with an HDMI touch screen monitor. As for spindle I am using a Brushless Dewalt Trim Router with the ESC replaced with an ODrive. It currently requires running commands from odrivetool on the Pi.
            @chimaeragh what all did you change in your version? I just upgraded to an ODrive Pro and can finally use an ADC input to control my spindle.
              chimaeragh @CthulhuLabs
              @cthulhulabs My DeWalt is configured as a spindle and is automated via a relay. So I can use M3 to start it and M5 to stop it. (Already modified my Vectric postprocessor for this)
              I added M3 and M5 commands into the surfacing loop at line 89 and line 148 of the macro.
              T1 ; selects the spindle Tool 1
              M3 S17500 ; starts tool
              CthulhuLabsundefined 1 Reply Last reply Reply Quote 0
                CthulhuLabs @chimaeragh
                @chimaeragh Cool. There is a variable at the top for the spindle RPMs. Now that my spindle RPM can be controlled by the Duet I plan to add it. You should probably use that in your M3 command.
                I am thinking of rewriting this Macro to only cut in one direction to give a more uniform surface finish. Basically cut from Left to Right, raise up, rapid to the next cut, lower and repeat. There would be a flag in it to change it between Left to Right and Right to Left. Might also add a flag to go from top to bottom or bottom to top.
                nikki-mundefined 1 Reply Last reply Reply Quote 0
                • nikki-mundefined
                  nikki-m @CthulhuLabs
                  @CthulhuLabs I use your surfacing.g code on a regular basis. Love it.
                  But is there any way to modify it so that the Depth of Cut could be adjusted by user input?
                  It would be nice to be able to enter a different value each time I use this macro, without having to edit the code. It would be even nicer if the DOC could be modified on each susbequent pass ("run again"). Perhaps also to limit the input value to between 0.1mm and 3.0mm?
                  HebigTundefined 1 Reply Last reply Reply Quote 0
                  • HebigTundefined
                    HebigT @nikki-m
                    @nikki-m
                    I know you can pass parameters to a macro in the macro call itself (e.g. depth of pass)
                    Manually choosing this value on each run of the macro may be possible now using M291 on 3.5 beta firmware.
                    • nikki-mundefined
                      nikki-m @HebigT
                      @HebigT Yes, I did look into the M291 function, but sadly, I am still on the v3.3 (awaiting any update from Ooznest)!!
                      Does this mean that there is no other way to program in a variable DOC? Apart from setting up numerous versions of the macro, each with a different value for the doc?
                      • HebigTundefined
                        HebigT @nikki-m
                        @nikki-m
                        With 3.3 you should still be able to pass a parameter in the macro call. You’ll just have to modify the macro (hopefully only once!) to assign that parameter to the DOC variable (e.g. var DepthOfCut= {param.y} )
                        It’ll still be a manual process of entering the parameter each time you start the macro, but it should save you the trouble of having to change the DOC variable within the macro each time.
                        See the macro parameter section at this link:
                        https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands
                        • nikki-mundefined
                          nikki-m @HebigT
                          @HebigT @HebigT I'm not sure I understand what you are saying here.
                          Is there an actual command (and presumably through a screen interaction) in v3. 3 which allows a user to type in and enter a value, and to then assign this value to an existing variable?
                          I still cannot find any means of entering an external value. I am still having to resort to having multiple versions of this macro, each wirh different values for doc.
                          OwenDundefined 1 Reply Last reply Reply Quote 0
                          • OwenDundefined
                            OwenD @nikki-m
                            @nikki-m
                            For RRF 3.3 and later you can pass parameters using M98
                            So you can call your macro using M98 P"mymacro.g" Y0.002
                            and in the macro you access the parameter using param
                            e.g.
                            var depthOfCut = 0.001
                            if exists(param.Y)
                                set var.depthOfCut = param.Y
                            • Nightowlundefined
                              Nightowl
                              I'm not sure if I'm being a bit too simplistic here, but this is what I do, after producing the GCode toolpath for surfacing, usually with a 0.15mm depth of cut, or sometimes more...
                              Run the toolpath. Once complete, if there are still low spots, lower the spindle/motor to Z0, then lower it again to the toolpath's cut depth (0.15mm), reset Z0 and rerun the toolpath.
                              Continue as necessary, but as you get closer to 'flat', you could reduce the 0.15mm accordingly.
                              Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
                              I'm still on my learning curve, so take everything I say with caution!
                              RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
                              • o_lampeundefined
                                o_lampe @OwenD
                                @OwenD
                                Isn't there a way to start the macro by doubleclicking and ask for the DOC-value from within the macro?
                                • OwenDundefined
                                  OwenD @o_lampe
                                  @o_lampe
                                  Not unless you update to RRF version 3.5.0b1
                                  Then you can ask for input use M291 as mentioned above
                                  nikki-mundefined 1 Reply Last reply Reply Quote 1
                                  • nikki-mundefined
                                    nikki-m @OwenD
                                    Thank for all your ideas, guys. I does seem that I can't achieve what I want whilst on v3.3.
                                    So I am in the hands of Ooznest and will have to wait to see when / if they decide to release a later version of their firmware.
                                    Of course, this macro would make a great plug-in, and so getting around this data input issue!
                                      CthulhuLabs @nikki-m
                                      So I am working on a new version of this Macro that will prompt for user input with the M291 command. It will make the Macro far more interactive for things like DepthOfCut, RPM, FeedRate, etc. One of the prompts I want to add is to ask if it should work in Pass mode or Depth mode.
                                      In pass mode it will prompt you for the number of passes to take. It will then do that many passes before prompting you whether to surface another layer. Default will obviously be 1.
                                      In Depth mode it will prompt you for how much material to remove. So if your DepthOfCut is say 0.3mm and you enter a depth of 1mm the Macro will do three passes at 0.3mm and then a fourth pass at 0.1mm for a total of 1mm.
                                      • CthulhuLabsundefined CthulhuLabs referenced this topic
