    How to connect a PanelDue
    395
    • CrazyCreatorundefined
      CrazyCreator
      my PanelDue is running perfect on my Duet3 MB6HC ... I connect to IO_0
      But i have see a picture on a cheap Chinese Shop Site ( 😉 ) the PanelDue is connected to OUT 6 ???
      Will this work too?
      http://www.crazycreatorcube.com
        jay_s_uk @CrazyCreator
        @crazycreator it will not
        CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
          CrazyCreator @jay_s_uk
          @jay_s_uk
          I thought so.
          Because in the documentary it's also quite different.
          Stupid guys 😉
            Silly cloners....
            https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Duet_3_all_main_boards
              CrazyCreator @Phaedrux
              You're absolutely right
              • zaptaundefined
                zapta
                @jay_s_uk said in How to connect a PanelDue:
                The photographer decided that this connector will give the best picture composition. 😉
                  droftarts administrators @zapta
                  @zapta I think they didn't know where to plug it in, because the PanelDue has a 4 pin molex shell on it's wire, when it needs a 5-pin shell to plug in on the MB6HC mainboard. So chose a header where it fitted. The screen content looks like a piece of paper placed on top of the PanelDue; the red bar at the top looks wobbly, like it's curling up! But then the board has got no power, so how can it be showing anything, anyway?
                  Phaedruxundefined Billsherenowundefined 2 Replies Last reply Reply Quote 1
                    Phaedrux Moderator @droftarts
                    @droftarts said in How to connect a PanelDue:
                    Photoshop is hard, let's fake it in camera! A+ for thinking outside the box.
                    • Billsherenowundefined
                      Billsherenow @droftarts
                      @droftarts I was looking for info on the wiring of my 7" screen when one place tells me to connect the ribbon cable with the 10 pin plug. When i've had the 4 wire plugged in and it works as far as the screen responding to the touch. But not seeming to make any changes or movements to the printer. So do I need the both of them plugged in at the same time?
                        Phaedrux Moderator @Billsherenow
                        @billsherenow It's usually either or. The 10 pin cable allows you to use the SD card slot in the PanelDue for Duets that support it. Otherwise the 4 wire cable is usually the better option.
                        https://duet3d.dozuki.com/Wiki/PanelDue#Section_Connecting_a_PanelDue
