    Replaced old with new duet2 wifi, cant get nozzle heater working
    521
    • brianundefined
      brian
      Replaced the old board, and managed to get everything working except heater for nozzle. In the DWC temp reads 24.4 but will not move up when temp set higher. Have set to e0temp in rrf config tool. The config.g is;
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @brian
        @brian People are going to ask for your complete config.g as well as the results from M98 P"config.g" and M122
        brianundefined 1 Reply Last reply Reply Quote 0
        • brianundefined
          brian @alankilian
          @alankilian ok here's the complete config.g;
          ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 02 2022 11:48:28 GMT-0800 (Pacific Standard Time)
          M550 P"Brian's Build 3" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M350 X32 Y32 Z32 E32 I0 ; configure microstepping without interpolation
          M92 X320.00 Y320.00 Z2500.00 E420.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X430 Y410 Z650 S0 ; set axis maxima
          M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M557 X15:215 Y15:195 S20 ; define mesh grid
          a
          M563 P0 S"Hot End" D0 H1 F0 ; define tool 0
            alankilian @brian
            @brian It looks like you are currently missing all your heater definitions.
            Maybe just a cut-n-paste error?
            Also, click on the </> button and paste your config.g in there and it will look
            like this!
            • brianundefined
              brian @alankilian
              @alankilian sorry, here's the M122
              m122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
              Board ID: 0JD0M-9P6B2-NJ4S8-6JKF6-3S86R-1A7GL
              Used output buffers: 3 of 24 (12 max)
              Static ram: 23876
              Dynamic ram: 74956 of which 176 recycled
              Never used RAM 15408, free system stack 184 words
              Tasks: NETWORK(ready,14.0%,229) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.9%,383) IDLE(ready,0.0%,29), total 100.0%
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:03:12 ago, cause: power up
              Last software reset at 2022-02-02 11:23, reason: User, GCodes spinning, available RAM 12464, slot 2
              Error status: 0x08
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 28.9, current 30.4, max 30.7
              Supply voltage: min 11.2, current 11.5, max 11.5, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: position 0, standstill, SG min/max not available
              Driver 1: position 0, standstill, SG min/max not available
              Driver 2: position 0, standstill, SG min/max not available
              Driver 5: position 0
              Driver 6: position 0
              Driver 7: position 0
              Driver 8: position 0
              Driver 9: position 0
              Driver 10: position 0
              Driver 11: position 0
              Date/time: 2022-02-02 12:09:14
              Slowest loop: 4.30ms; fastest: 0.17ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 3.2ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 200.14ms; fastest: 0.09ms
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is active
                Failed messages: pending 0, notready 0, noresp 1
                WiFi firmware version 1.23
                WiFi MAC address e0:98:06:22:8f:44
                WiFi Vcc 3.43, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 22920
                WiFi IP address 192.168.1.67
                WiFi signal strength -37dBm, mode none, reconnections 0, sleep mode modem
                Clock register ffffffff
              • brianundefined
                brian @brian
                @brian and the config.g again
                • brianundefined
                  brian @brian
                  @brian 2/2/2022, 12:14:04 PM M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  • brianundefined
                    brian @brian
                    @brian sorry , i dont follow this " click on the </> button and paste your config.g in there"
                    deckingmanundefined alankilianundefined 2 Replies Last reply Reply Quote 0
                    • deckingmanundefined
                      deckingman @brian
                      @brian I think you need to PID tune the heater. You have disabled bang bang mode but there are no PID parameters in your M307.
                      Edit. Unless you are using config-overide and have missed out the command to read those stored values (I'm using my phone but I think it's M501 that you need in config.g to read config-overide.g).
                        alankilian @brian
                        @brian
                        See at the top of the posting entry window where there are a bunch of symbols like:
                        Click the </> button and you'll get something in the posting entry window.
                        code_text
                        Then if you replace the code_text with your config.g it will be formatted nicely.
                        Here's my config.g
                        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 09 2021 13:21:24 GMT-0500 (Eastern Standard Time)
                        G90                                                     ; send absolute coordinates...
                        M83                                                     ; ...but relative extruder moves
                        M550 P"alan"                                            ; set printer name
                        M665 R132.5 L291.06 B132.5 H400                         ; Set delta radius, diagonal rod length, printable radius and homed height
                        M666 X0 Y0 Z0                                           ; put your endstop adjustments here, or let auto calibration find them
                        M552 P0.0.0.0 S1                                        ; enable network and acquire dynamic address via DHCP
                        ; Testing external driver
                        ;M569 P5 S1 T4:4:4:4                                     ; physical drive 5 goes forwards
                        ;M584 X0 Y1 Z2 E3 U5                                     ; set drive mapping
                        ;M350 X16 Y16 Z16 E16 U16 I1                             ; configure microstepping with interpolation
                        ;M92 X100.00 Y100.00 Z100.00 U100.00 E91.00              ; set steps per mm
                        ;M566 X1200.00 Y1200.00 Z1200.00 U1200 E1200.00          ; set maximum instantaneous speed changes (mm/min)
                        ;M203 X18000.00 Y18000.00 Z18000.00 U18000E1200.00       ; set maximum speeds (mm/min)
                        ;M201 X1000.00 Y1000.00 Z1000.00 U1000E1000.00           ; set accelerations (mm/s^2)
                        ;M906 X1000 Y1000 Z1000 E800 U1000I30                    ; set motor currents (mA) and motor idle factor in per cent
                        M584 X0 Y1 Z2 E3                                        ; set drive mapping
                        M350 X16 Y16 Z16 E16 I1                                 ; configure microstepping with interpolation
                        M92 X100.00 Y100.00 Z100.00 E91.00                      ; set steps per mm
                        M566 X1200.00 Y1200.00 Z1200.00 E1200.00                ; set maximum instantaneous speed changes (mm/min)
                        M203 X18000.00 Y18000.00 Z18000.00 E1200.00             ; set maximum speeds (mm/min)
                        M201 X1000.00 Y1000.00 Z1000.00 E1000.00                ; set accelerations (mm/s^2)
                        M906 X1000 Y1000 Z1000 E800 I30                         ; set motor currents (mA) and motor idle factor in per cent
                        M208 Z0 S1                                              ; set minimum Z
                        M574 X2 S1 P"xstop"                                     ; configure active-high endstop for high end on X via pin xstop
                        M574 Y2 S1 P"ystop"                                     ; configure active-high endstop for high end on Y via pin ystop
                        M574 Z2 S1 P"zstop"                                     ; configure active-high endstop for high end on Z via pin zstop
                        M558 P1 C"zprobe.in" H10 F3000 T6000                    ; set Z probe type to unmodulated and the dive height + speeds
                        G31 P500 X0 Y0 Z-0.1                                    ; set Z probe trigger value, offset and trigger height
                        M557 R132 S40                                           ; define mesh grid
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4388 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
                        M140 H0                                                 ; map heated bed to heater 0
                        M143 H0 S120                                            ; set temperature limit for heater 0 to 120C
                        M308 S1 P"e0temp" Y"thermistor" T100000 B4385           ; configure sensor 1 as thermistor on pin e0temp
                        M950 H1 C"e0heat" T1                                    ; create nozzle heater output on e0heat and map it to sensor 1
                        M307 H1 B0 S1.00                                        ; disable bang-bang mode for heater  and set PWM limit
                        M950 F0 C"fan0" Q500                                    ; create fan 0 on pin fan0 and set its frequency
                        M106 P1 S0.7 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
                        M563 P0 D0 H1 F0                                        ; define tool 0
                        G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
                        G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
                        ; Custom settings
                        M501                                                    ; Load config-overrides.g
                        ;T0                                                      ; Select tool zero
                        M912 P0 S3.5                                            ; MCU temperature calibration
                        M591 D0 P3 C"e0_stop" S1                                ; Configure filament monitor
                        After I boot, I can see the heaters like this:
                        If I click on Tool 0 and then enter a temperature, it starts to heat up like this:
                        What happens when you do that?
                        Phaedruxundefined brianundefined 2 Replies Last reply Reply Quote 0
                          Phaedrux Moderator @alankilian
                          Are you selecting the tool first before trying to heat it?
                          Add T0 to the end of your config.g to select the tool automatically at startup.
                          • brianundefined
                            brian
                            @phaedrux No i was not selecting tool first. But now it is heating up when i send a print. However, now its not homing z properly. Have added the T0 at end, no result as yet.
                            • brianundefined
                              brian @brian
                              @brian ok i see that i have to click the tool to make it active, who wouldnt thunk it?
                              • brianundefined
                                brian @alankilian
                                @alankilian said in Replaced old with new duet2 wifi, cant get nozzle heater working:
                                config.g
                                config.g   Thanks, found it.
                                • brianundefined
                                  brian @brian
                                  @brian So this is now working.
                                  Config.g
                                  ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 02 2022 14:20:11 GMT-0800 (Pacific Standard Time)
                                  M92 X320.00 Y320.00 Z2500.00 E1050.00           ; set steps per mm
                                  M208 X0 Y0 Z0 S1                               ; set axis minima
                                  M574 Z2 S2                                     ; configure Z-probe endstop for high end on Z
                                  M558 P1 C"zprobe.in+!pson" H5 F120 T6000       ; set Z probe type to unmodulated and the dive height + speeds
                                  G31 P500 X0 Y0 Z0.5                            ; set Z probe trigger value, offset and trigger height
                                  ;T0
                                  • brianundefined
                                    brian @brian
                                    @brian thanks for everyone's help
