Is filament chnage required?
Hello to all,
I always get the following message:
<Is filament change reuqired? navigate to the macros tab and press filament Change.> Where are the values defined?
How can we disable that.
How can I reset the values to zero and define when the message comes??
etc..I´m using 5kg filament.
Thx
for your help -
If i click on filaments
there is nothing listed.
At the right bottom i get an orange box with the following mesages:
<Failed to get filelist directory 0:/filaments not found> Dieter
@icy_snake said in Is filament chnage required?:
OK that is what I wanted to know. But it means that message about requiring a filament change is coming from somewhere else.
In your System folder do you have any files like these?
@fcwilt yes have them
tfree0.g empty
tfree1.g empty
tpost0.g M116 P0
tpost1.g M116 P1
tprep0.g empty
tprep1.g empty -
tfree0.g empty
tfree1.g empty
tpost0.g M116 P0
tpost1.g M116 P1
tprep0.g empty
tprep1.g emptyI don't think having an empty file would lead to that message. And the M116 is just waiting for the tool heater to reach temp.
Maybe that code is in your slicer. You are using IdeaMaker?
@fcwilt yes i am using ideamaker
I don't use that but I have it. I will take a look at its code generation and see if it could be the source of that message.
In IdeaMaker under Filament Settings there is this place for Custom GCode. Do you have anything there?
This sounds like a modix macro. When and where do you see this message?
@fcwilt Good morning, no i have nothing there
@phaedrux I pretty sure there is no macro.
I see the message during printing. -
Can you zip up your full config file set and share it here?
That message is coming from somewhere. Possibly a filament sensor?
Is it coming continuously when printing?
@phaedrux yes it is coming always.
@phaedrux I cannot upload a zip or rar file??
Morning.
IdeaMaker uses what they call Templates. Templates have several places where code can be entered.
For whatever template is being used when you get the filament message check all of the possible code places shown below:
@fcwilt said in Is filament chnage required?:
All tabs are empty, already checked.
Well this is curious. I'm running out of ideas.
Do you have a start.g file?
you can change the extension to .txt and upload it or use a file sharing cloud service.
@phaedrux
ok here as a txt
icy_modix60_setup .txtHey it worked.
