    Closed-Loop tuning on CL57T stepper driver
    1.5k
    • V.A.M.P printing snprojundefined
      I currently got new closed looped stepper drivers and got the printer homing correctly while the drivers are set to open loop. What is the next step to start tuning the drivers to begin printing with them? Ill post my confige file below.
        This post is deleted!
          It will not let me post my config file but at the start of a print it crashes into the side of the frame of the printer.
          alankilianundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
          • alankilianundefined
            alankilian @V.A.M.P printing snproj
            @v-a-m-p-printing-snproj
            OK, you won't start closed-loop tuning by starting a print right away.
            You'll need to go one-axis-at-a-time and get them moving properly first.
            • Put everything in open-loop and make sure you can move each axis back-and-forth small moves using G1 commands before going the next step.
            You can start up and home everything in open-loop mode.
            Then switch to closed-loop mode and try a short move.
            If you encoder is hooked up backwards, the axis will run full-speed and smash into a hard stop. Be prepared for that
            • Start with the X axis and make sure you can home in open-loop mode, that you can move 10mm forward, 10mm backwards and that the head moves about 10mm each time and THEN switch to closed-loop and try the 10mm moves again.
            PLEASE be super careful not to get hurt. closed-loop tuning on a newly-wired-up system can be SUPER dangerous.
            Send us the commands you entered and the results you got.
            V.A.M.P printing snprojundefined 1 Reply Last reply Reply Quote 0
              V.A.M.P printing snproj @alankilian
              @alankilian Everything was homing fine in open loop so I switched to closed loop on the X and Y. Using the web controllers movement controls i began moving the x in small increments of 1mm each way and it moved fine so I tried 10mm and it continued moving fine. I then tried homing X and it also homed without any issue. I did the same for the Y and everything worked fine. I then homed all and it did without any issues.
              alankilianundefined 1 Reply Last reply Reply Quote 0
                OK, so you have the encoders hooked up properly and everything is setup to start tuning.
                I would start by printing a box that is one wall thick and about 30mm square at a VERY SLOW speed.
                This will show how well your motors are following the commanded position at setting #0 on the rotary switch S1 on the CL57T V4.0.
                After that, you should increase the speed to where you want it to be and if everything is OK, you're done!
                  Phaedrux Moderator @V.A.M.P printing snproj
                  @v-a-m-p-printing-snproj said in Closed-Loop tuning on CL57T stepper driver:
                  Try again?
                    V.A.M.P printing snproj @Phaedrux
                    @phaedrux ; Configuration file for Duet WiFi (firmware version 2.03)
                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 15 2021 15:55:39 GMT-0400 (Eastern Daylight Time)
                    M550 P"VAMP" ; set printer name
                    M669 K1 ; select CoreXY mode
                    M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M569 P3 S0 ; physical drive 3 goes forwards
                    M569 P5 S1 T2.5:2.5:5:5 ; physical drive 5 goes forwards
                    M569 P6 S1 T2.5:2.5:5:5 ; physical drive 6 goes forwards
                    M569 P7 S0 T2.5:2.5:5:5 ; physical drive 7 goes backwards
                    M569 P8 S0 T2.5:2.5:5:5 ; physical drive 8 goes backwards
                    M569 P9 S0 T2.5:2.5:5:5 ; physical drive 9 goes backwards
                    M584 X5 Y6 Z7:8:9 E3 ; set drive mapping
                    M92 X80.5234 Y79.6020 Z800.00 E95.00 ; set steps per mm
                    M566 X900.00 Y900.00 Z60.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z20.00 ; set accelerations (mm/s^2)
                    M906 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X415 Y415 Z440 S0 ; set axis maxima
                    M574 X1 Y2 S1 ; set active high endstops
                    M574 Z1 S2 ; set endstops controlled by probe
                    M307 H6 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                    M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                    G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                    M557 X15:215 Y15:195 S20 ; define mesh grid
                    M305 P0 T100000 B3950 R4700
                    M305 P1 T4700000 B5140 R4700 ; set thermistor + ADC parameters for heater 1
                    M143 H0 S180 ; set temperature limit for heater 0 to 100C
                    M143 H1 S490 ; set temperature limit for heater 1 to 490C
                    M501
                      @alankilian
                      Okay ill do that and let you know how it goes. Since I had to change my home all coordinates for the Y position when the Z axis is homing, will this effect coordinates for a print?
                        I don't know,
                        Home the printer and then use G1 to move to someplace.
                        Then measure the distance from the printer's origin to that location and see if it matches.
                          I think it should only matter if you've changed M208.
                            @phaedrux Okay my only concern before starting a print is before i changed my drivers, in front of the rear lead screw it was reading that Y was at 85 and now it is reading at 315 at that lead screw. Also when i look at the code for a print it has Y coordinates less than 315 which isnt on my build plate.
                              You should do some careful positioning testing before starting a print.
                              https://docs.duet3d.com/en/User_manual/Tuning/Bed_origin
                              V.A.M.P printing snprojundefined 1 Reply Last reply Reply Quote 1
                                @phaedrux Okay sounds good thanks!
                                  V.A.M.P printing snproj @V.A.M.P printing snproj
                                  Okay so I've been messing around with movement on my printer and notice the distance the printer head is moving is not correct. Before my maximum for the x and y was 415, but when i would try to go to X0 Y0 it could go to Y0. So I set the maximum to 115 for both the X and Y and now it can go to X0 Y0. Why is the distance my print head is traveling reading differently now?
                                    I don't quite understand, I'm sorry.
                                    If you can type in the exact GCODE commands you are typing and tell us what you expect to happen and what actually happens it will help understand what's going wrong.
                                      @alankilian
                                      My bed length and width is 415mm but after getting everything going in the right direction when I command the printer to move to X115 Y115 it will travel to what should be 415mm.
                                        I still don't understand because you didn't follow my instructions telling me what GCODE commands you enter.
                                        But I'll guess (Which wastes all our time)
                                        OK, you ask the printer to move 115mm in X and 115mm in Y and is actually moves 415, in X and 415mm in Y?
                                        That would mean you are commanding too many steps.
                                        Maybe change
                                        to:
                                        M350 X4 Y4 Z16 E16 I1 ; configure microstepping with interpolation
                                        And see if it gets closer to the right move length.
