    New FLSUN Super Racer, ideas for upgrades?
    2.4k
    • Chiefchamberlainundefined
      Chiefchamberlain
      Re: Plans on getting and upgrading an Flsun Super Racer
      Just picked up an FLSUN Super Racer. Pretty psyched with the overall design, but its definitely lacking in more areas than one. I am looking to replace the extruder, hot end, and hook up a raspberry pi and cam w/Klipper firmware. Anybody have any suggestions for any other upgrades or particular parts I should consider? Any help is greatly appreciated!
      • oliofundefined
        oliof @Chiefchamberlain
        @chiefchamberlain If you wouldn't have said klipper, I would have said smart effector (-: I don't know if klipper supports the smart effector when running it on a Duet board.
        Fred-Yundefined 1 Reply Last reply Reply Quote 0
        • Fred-Yundefined
          Fred-Y @oliof
          @oliof The Smart Effector can work with Klipper, I installed this firmware on my Predator for a few months to test it but I rolled back to RRF during be beta of 3.4 for Input Shaping.
          I don't think it's possible to adjust the sensibility.
          bbergerundefined 1 Reply Last reply Reply Quote 1
          • bbergerundefined
            bberger @Fred-Y
            @fred-y said in New FLSUN Super Racer, ideas for upgrades?:
            That's been solved by now. It's merged in the latest Klipper.
            Fred-Yundefined 1 Reply Last reply Reply Quote 1
            • Fred-Yundefined
              Fred-Y @bberger
              @bberger Thanks for sharing the info!
              I might try again Klipper on one of my Deltas.
              • fmaundefined
                fma
                Hi!
                I just bought a used FLSUN SR, as I have not enough time to work on my CoreXY (this will be for later), and I always wanted to try a Delta 😉
                I plan to replace the electronic with a Duet 3 Mini 5+, and put a direct-drive extruder.
                Did anyone already make such changes? Any advice?
                Thanks,
                Frédéric
                zaptaundefined 1 Reply Last reply Reply Quote 1
                • zaptaundefined
                  zapta @fma
                  IIRC the SR has a nice tethered display. I hope you can preserve it with the new controller.
                  fmaundefined 1 Reply Last reply Reply Quote 0
                  • fmaundefined
                    fma @zapta
                    @zapta Yes, it would be nice!
                    But I guess it would require some custom code on the Duet? Or maybe add some in-between electronic, to convert datas...
                    Frédéric
                    • oliofundefined
                      oliof @fma
                      @fma depends on the way the display connects to the main board. If it is doing serial, it might be possible to port the (last working well with RRF) firmware of the BTT touch screens, if not you may need to do that from scratch /-:
                      • oliofundefined
                        oliof @oliof
                        Alternately, re-use the cable to connect a PanelDue. Making a compatible display case is relatively straightforward.
                        • fmaundefined
                          fma @oliof
                          Hi!
                          So, I used my stock FLSUN SR for several months, and it's now time to switch to Duet3/RRF!
                          I would also like to replace the Bowden extruder by a direct one. Do you have any suggestions? At the same time, I plan to mount a Smart Effector: do you confirm it is compatible with the SR? The arms balls do not seem to be maintained in the same way...
                          Thanks,
                          Frédéric
                          • Fred-Yundefined
                            Fred-Y @fma
                            @fma Yes it can be done.
                            I should still have the adapter I've made to install the smart effector using the stock rods, I did not used it a lot as I switch to a magball setup shortly after - I will dig in my older files and publish it.
                            You can install a direct drive on the smart effector, depending on the extruder you might be able to find an adapter (I remember seeing some for the Sherpa and Orbiter on thingiverse - there is a few post in the forum as well) - That said, in my opinion, a direct drive on a Delta not the best setup because it adds a lot of weight - I prefer a flying extruder.
                            • fmaundefined
                              fma @Fred-Y
                              @Fred-Y Thanks, I'm interested by your adapter, if you can find it...
                              About the flying extruder, I did consider it, but I'm afraid it won't be as good as a direct-drive.
                              Frédéric
