    NeoPixel wrong Color
    1.2k
    • Heartleander81undefined
      Heartleander81
      I've had a problem with the NeoPixels since the 3.4.0 stable update.
      For example if I
      M150 R255 U255 B235 P128 S60
      enter then I have a colorful LED bar, but it should be white.
      No matter which RGB I use, there is no pure color.
      With 3.4 Beta 8 was all good and work correct.
      Have anyone a tip for me?
      o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @Heartleander81
        @heartleander81
        From my understanding, you have to add F0 or F1 to make the command complete.
        What do you mean with colorful? Is it random color?
        Did you set M150 X? Q??? before you send the line?
          dc42 administrators @Heartleander81
          @heartleander81 have you selected correctly whether you are using RGB or RGBW Neopixels?
          Heartleander81undefined 1 Reply Last reply Reply Quote 0
            Heartleander81
            I have in my config.g M150 X1 for RGB neoPixel. That have I use with 3.3, 3.4 Beta 7 and with 3.4.0 .
            But with the stabel Version is the issuses.
            • T3P3Tonyundefined
              T3P3Tony administrators @Heartleander81
              @heartleander81 can you try addressing just 1 pixel first in each colour and then in all 3. Then expand the test to 10.
              www.duet3d.com
                Heartleander81
                I have forget to write I have a Duet 3 6HC with sbc , toolboard v1.1 and PanelDue 5" V3. All Firmware at new Release.
                  Heartleander81
                  That I understand correctly.
                  pixel 1 in white then 3 pixels in white and then 10 in white?
                    Heartleander81
                    insane..
                    Now that I've made a pixel on white, everything works as usual again.
                    I asked 1 pixel white that was white.
                    3 pixels were also white, 10 were also white and then 60 were also white.
                    Hope the error is gone.
                    I did another sudo apt-get update & upgrade today, maybe I don't know if there was a change accordingly.
                      Heartleander81
                      After off and on Problem is back. Test 1 Pixel white is this green
                      3 Pixel 1=Blue 2=withe 3=off
                      10 Pixel 1=Blue 2=withe 3=green 4=jellow 5=green 6=blue 7=blue 8=Red 9=off 10= off
                      After a Printjob is all good. After a New start is this not.
                      • o_lampeundefined
                        @heartleander81
                        Maybe there are some unwanted signals to the LED-strip at startup? Can you try to clear all LEDs before the white?
                        Could be in the same line with the configuration.
                          Heartleander81 @o_lampe
                          @o_lampe how clear i all LED?
                          M150 P0 S60 ? That use I to make it off.
                          Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
                          • Rushmere3Dundefined
                            Rushmere3D @Heartleander81
                            @heartleander81
                            I was having issues with RGB LED's on my Voron, adding a 1.5K resistor to the Data line at the strip end fixed it.
                            Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
                              Heartleander81 @Rushmere3D
                              @rushmere3d dotstar ore neopixel? Neopixel have 1 data line not 2
                                @heartleander81 Neopixels and I'm aware of that maybe didn't explain it right.
                                Where the 3 wires attach to the strip, disconnect the data and solder a resistor to the wire then the other end to the data connection on the strip. I didn't say anything about 2 data lines?
                                  @rushmere3d sorry then I misunderstood. But unfortunately I don't have anything like that at home and what surprises me before the update to 3.4 I had no problem with it.
                                    Heartleander81 @dc42
                                    @dc42 @ I use M150 X1 for RGB NeoPixel
                                      Heartleander81
                                      Issused found. How Can I close ore delet this thread?
                                        @heartleander81
                                        Care to share? What it was and how you fixed it.
                                        You need to mark it as a question, then mark it as solved.
                                        • dc42undefined dc42 marked this topic as a question
                                          @rushmere3d
                                          I clamped the line for the signals between the ramen and the motor and I suspect that I have generated interference signals.
