    Solved My PanelDue7i Keep Says "connecting"
    PanelDue
    paneldue
    302
    • TRATOON
      TRATOON last edited by
      Hello, I connected a PanelDue7i using the 10-Pin 300mm Ribbon Cable I received along with the PanelDue in the CONN_SD slot on both the PanelDue and my Duet 2 Wifi. I used a FLUKE multimeter to perform a continuity check on each wire of the ribbon cable (all wires passed the check). I also made sure the baud rates on both the Duet 2 Wifi and PanelDue 7i were 57600. However, the PanelDue still says "connecting." Please Help.
        What firmware are you running on the Duet and PanelDue respectively?
        Does your config.g contain the command to enable the PanelDue?
        Do you have a 4-wire cable to test with as an alternative?
        • TRATOON
          I am running PanelDue fw 3.4.0 and RepRap 3.3 my config.g has M575 P1 S1 B57600 and I don't have a 4 wire cable right now. However I can make one in 10 minutes.
            3.4 on the Panel and 3.3 on the Duet should probably work, but just in case, you can update the Duet as well. You should be on 3.4 anyway.
            Upload this zip file as is to the system tab:
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/Duet2and3Firmware-3.4.0.zip
            If that doesn't help, please try a 4-wire cable. If you don't plan on using the SD card slot on the PanelDue the 4-wire cable is preferred anyway.
            If you're still having troubles after trying that please post your full config.g and the results of M122 and M98 P"config.g". Also post the exact firmware version of the PanelDue as shown on the setup tab.
            • TRATOON
              TRATOON last edited by TRATOON
              Done. I uploaded the files.
              TRATOON 1 Reply Last reply Reply Quote 0
              • TRATOON
                TRATOON @TRATOON last edited by
                Exact Panel Due fw version: 3.4.0
                M122 Results: === Diagnostics ===
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
                Board ID: 0JD0M-9P6M2-NW4SS-6JKD8-3SN6Q-1UWMK
                Used output buffers: 3 of 24 (17 max)
                Static ram: 23868
                Dynamic ram: 74300 of which 0 recycled
                Never used RAM 13912, free system stack 184 words
                Tasks: NETWORK(ready,14.1%,218) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) MAIN(running,85.4%,444) IDLE(ready,0.5%,30), total 100.0%
                Owned mutexes:
                Last reset 00:03:17 ago, cause: software
                Last software reset at 2022-04-22 00:04, reason: User, GCodes spinning, available RAM 13912, slot 1
                Error status: 0x00
                Aux0 errors 0,0,1
                Step timer max interval 0
                MCU temperature: min 32.4, current 34.5, max 34.6
                Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                Events: 0 queued, 0 completed
                Driver 0: standstill, SG min n/a
                Driver 1: standstill, SG min n/a
                Driver 2: standstill, SG min n/a
                Driver 3: standstill, SG min n/a
                Driver 4: standstill, SG min n/a
                Driver 5:
                Driver 6:
                Driver 7:
                Driver 8:
                Driver 9:
                Driver 10:
                Driver 11:
                Date/time: 2022-04-22 09:19:25
                Slowest loop: 6.32ms; fastest: 0.18ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 4.3ms, write time 0.0ms, max retries 0
                DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                === AuxDDARing ===
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is assembling a command in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty
                === Network ===
                Slowest loop: 16.13ms; fastest: 0.00ms
                Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is active
                  WiFi firmware version 1.26
                  WiFi MAC address e0:98:06:a4:42:62
                  WiFi Vcc 3.36, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 24320
                  WiFi IP address 192.168.1.148
                  WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
                  Clock register 00002002
                  Socket states: 4 0 0 0 0 0 0 0
                M98 Results:
                M98 P"config.g"
                HTTP is enabled on port 80
                FTP is disabled
                TELNET is disabled
                Warning: Macro file config-override.g not found
                And I do plan on using the SD slot. However for testing purposes, I will go make a 4-wire cable right now
                  Phaedrux Moderator @TRATOON last edited by
                  @tratoon said in My PanelDue7i Keep Says "connecting":
                  https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
                  You can try the latest pre-release paneldue firmware as well.
                  https://github.com/Duet3D/PanelDueFirmware/releases
                  • TRATOON
                    TRATOON @Phaedrux last edited by
                    @phaedrux Updating the firmware didn't work it still says connecting.
                      Can you post your full config?
                      • TRATOON
                        TRATOON @Phaedrux last edited by TRATOON
                        @phaedrux The four wire worked. However, I would like SD functionality. What do you suggest? Should I ask my distributor for a new cable?
                        • TRATOON
                          However, I checked the continuity of the ribbon cable and it was continuous. So what else could be the problem?
                            It's getting power through the ribbon cable, but it seems like the data connection is not working.
                            Can you also check the resistance of the ribbon cable wires?
                            Can you also inspect the socket on the board for solder defects?
                            • TRATOON
                              @phaedrux Will do thank you
                              • Topic has been marked as a question  TRATOON TRATOON
                              • Topic has been marked as solved  TRATOON TRATOON
