    Servo Configuration Check
    Using Duet Controllers
    447
    • JRCL
      JRCL last edited by JRCL
      Working on controlling a 5V 2A servo (at stall). It is powered via my 24V supply with a 75W, 24V to 5V DCDC converter.
      The control pin is on GPIO 1 on my Duex 5 attached to my Duet 2 Wifi. Based on everything I read this seems to be the better way to power the servo, but I can't seem to get any movement from it when I send a M280 P0 S90 command through DWC.
      I'm not knowledgeable on servos but should it be locked up when power to the machine is on or should I still be able to push the servo arm until a command is sent to control it. Just trying to figure out how to test/troubleshoot this. Here is the line I used in my config.g file, I just put it under where I called out my drives. Hopefully, it doesn't need to be before any specific line.
      M950 S0 C"duex.gp1" 				; assign servo control to port 0 and link to gpio pin 1 on duex
      Printers: Prusa MK2S, Modified Ender 3 Pro, and Custom Build- RL1 Proto
      JoergS5 1 Reply Last reply Reply Quote 0
        Have you seen this? https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_servos
        JRCL 1 Reply Last reply Reply Quote 0
        • JRCL
          JRCL @Phaedrux last edited by
          @phaedrux Yes! I think that’s just about all I have seen actually 😄
          • fcwilt
            fcwilt last edited by
            @jrcl
            Try one of the Duex5 pins that have pwm in the name. Not all output pins can generate PWM signals.
            !duex.pwm1
            !duex.pwm2
            !duex.pwm3
            !duex.pwm4
            !duex.pwm5
            JRCL 1 Reply Last reply Reply Quote 1
            • JoergS5
              JoergS5 @JRCL last edited by JoergS5
              @jrcl said in Servo Configuration Check:
              a M280 S0 P90 command
              hello, the command is P0 for servo index, not S.
              M280 P0 S90
              (an example of mutliple traps where the letter changes for the same thing)
              • JRCL
                JRCL @JoergS5 last edited by
                @joergs5 Whoops! A mistype on my part in the post the correct command still does nothing. It's been since edited.
                • JRCL
                  JRCL @fcwilt last edited by
                  @fcwilt Gave this a try to no avail. Realized that my BL Touch was assigned to S0 so changed to
                  M950 S1 C"!duex.pwm2"
                  and after sending a M280 P1 S90, still got no response.
                  alankilian 1 Reply Last reply Reply Quote 0
                    Please try M950 S1 C"!duex.pwm2" but without the !
                    And you're for sure using the pwm2 header?
                    Photo of your wiring?
                    https://docs.duet3d.com/duet_boards/duet_2_expansion/duex_wiring_v0.11_d1.0.png
                    • alankilian
                      alankilian @JRCL last edited by
                      @jrcl
                      Do you have the ground of the 5 Volt output connected to the ground on the Duet?
                      If it's isolated then you would need the grounds tied together.
                      (somewhat unlikely, but who knows)
                      • JRCL
                        @phaedrux Tried without the ! and here is my wiring diagram and circled the pin on the duex to be safe. Still no dice.
                        • JRCL
                          JRCL @alankilian last edited by JRCL
                          @alankilian just posted my abridged wiring diagram above. I don't think that's isolated, but maybe?
                          fcwilt alankilian 2 Replies Last reply Reply Quote 0
                          • fcwilt
                            fcwilt @JRCL last edited by
                            Do you perhaps have an oscilloscope you could check the PWM signal with? It may not be meeting the requirements for your servo.
                            • JRCL
                              @fcwilt I don't unfortunately. I'm no electrical engineer, but could I use some sort of amplification module on the signal? Not sure if PWM signals work like that/or can be amplified like that.
                              JRCL fcwilt 2 Replies Last reply Reply Quote 0
                              • JRCL
                                JRCL @JRCL last edited by
                                Managed to find the control signal specs. What are the PWM signals on the Duex able to supply?
                                • fcwilt
                                  A PWM signal as used to drive a servo is a fixed frequency, typically 50 Hz, with a varying duty cycle.
                                  While you could possible hear via an audio amplifier with suitable frequency range it wouldn't tell you if the signal met the needs of your servo.
                                  You can get a fairly nice combo multimeter and oscilloscope which would do the job for $100 off of Amazon. A useful tool for working on 3D printers.
                                    Phaedrux Moderator @JRCL last edited by
                                    You've circled the PWM3 header, but the command you posted was for PWM2 M950 S1 C"!duex.pwm2"
                                    Which is it?
                                    Assuming it matches and it was just a typo, does the servo make any noise or get warm when you try and activate it?
                                    Can you send M950 S1 by itself and report back the reply?
                                    Can you try with some different PWM frequencies by adding a Q parameter to the M950 command?
                                    M950 S1 C"!duex.pwm2" Q50 perhaps
                                    • alankilian
                                      @jrcl
                                      Can you post the manufacturer and part number for your 24-to-5 Volt converter?
                                      • JRCL
                                        @phaedrux Are they not grouped like this? I figured it was just a naming convention for the pin (E3_PWM) went with the PWM number (PWM2) and I saw this on the pin name table too and thought I still called C"duex.pwm2" though the control pin is called E3_PWM
                                        • JRCL
                                          @alankilian Tobsun EA75-5V
                                          • alankilian
                                            @jrcl
                                            I can't tell if that's isolated or not.
                                            If you've got everything else figured out, try connecting the two grounds together at the converter.
                                            fcwilt 1 Reply Last reply Reply Quote 0
                                            • fcwilt
                                              fcwilt @alankilian last edited by
                                              @alankilian said in Servo Configuration Check:
                                              @jrcl
                                              Without knowing how the unit is designed that might be unwise.
                                              JRCL alankilian 2 Replies Last reply Reply Quote 0
                                              • JRCL
                                                @fcwilt Agreed, it's a buck converter if that makes any difference, but it does seem like that would allow the full power load to pass through the Duex and potentially fry the rail. Ordering the recommended MG995, from the servo wiki, to test against at least for now.
                                                • fcwilt
                                                  It could be fine, it could be destructive - without word from the manufacturer you just don't know.
                                                  Since it seems you have no test equipment even the lack of destruction would not insure it was actually working - it might just shutdown if wired incorrectly.
                                                  I went ahead and ordered one. I should be able to determine if the output is isolated. If so you would need to connect the grounds together. I will let you know what I find.
                                                  • JRCL
                                                    @fcwilt You're too kind, appreciate the above and beyond support on this
                                                    • fcwilt
                                                      Glad to be of help when I can.
