    Keenovo silicone heater reaply
    450
    • martin7404
      martin7404 last edited by martin7404
      Hi , all
      During some upgrade on my idex printer I notice that my bed keenovo heater have a big air poket in the middle.
      Any body have experience how to solve this.
      Or how to remove it without damging it.
      If it is removed successfully I think I can attach it back with high temp RTV.
      Any advice would be much apreciated
      Muldex IDEX 3d printer Duet2+Duex5+Paneldue 7i
      Custom CoreXY 600x400 Hemera , Duet3+toolboard v1.1, Paneldue 7i
      Mod Sapphire Pro with Duet2 , with closed-loop motors
      voron v0.1 and cr10s both running klipper; stock Bambu lab X1CC, X1C and P1P
      A Former User zapta 2 Replies Last reply Reply Quote 0
      • A Former User
        A Former User @martin7404 last edited by A Former User
        This post is deleted!
        martin7404 1 Reply Last reply Reply Quote 0
        • jens55
          jens55 last edited by
          Is the heater still working? A lot of times the heater gets damaged if there isn't a way to conduct the heat away from the heat pad. At minimum you will have a scorched heater and you may have trouble with the pad even if you re-attach it successfully. It is certainly worthwhile trying but you should be prepared to have to replace the heat pad.
          Also, if you end up busting things during the pad removal, you can confidently say to yourself that it was damaged anyway. In other words you don't need to feel too badly about breaking the pad.
          martin7404 1 Reply Last reply Reply Quote 1
          • martin7404
            martin7404 @Guest last edited by
            @arnold_r_clark thank you
            That was my initial thought
            • martin7404
              martin7404 @jens55 last edited by
              @jens55 😉
              I did already ordered new one but it is at least 3 weeks delivery, so I will try tonsave this one to use it until new one gets here
                Citrus oil cleaner works well for dissolving the glue. Then soap and water for cleaning off the citrus residue.
                • mrehorstdmd
                  mrehorstdmd last edited by mrehorstdmd
                  Keenovo's instructions for removing the heaters involves heating it up to soften the adhesive and then peeling/scraping.
                  If there's an air bubble under the heater there's a good chance it is scorched and should not be reused.
                  This is what mine looked like after it developed a bubble when the adhesive let go:
                  I replaced it with the same type heater without the adhesive. I used high temperature silicone to mount it and it has been holding for at least 3 years. I don't think it's ever going to let go.
                  jens55 1 Reply Last reply Reply Quote 0
                  • jens55
                    jens55 @mrehorstdmd last edited by
                    @mrehorstdmd said in Keenovo silicone heater reaply:
                    I used high temperature silicone to mount it and it has been holding for at least 2 years. I don't think it's ever going to let go.
                    Just curious about how you you proceeded with the silicone. How did you end up getting a thin (but not too thin) coat onto the build plate. Did you end up rolling out any excess silicone? How did you get out any air bubbles (or did you not worry about that)? Did you proceed like with the normal adhesive, attach a bit, roll out any air bubbles etc etc and work your way across attaching a little bit at a time until you got all the way across the heater? Did you clamp the assembly for curing?
                    mrehorstdmd 1 Reply Last reply Reply Quote 0
                    • mrehorstdmd
                      mrehorstdmd @jens55 last edited by mrehorstdmd
                      @jens55 I applied as even a layer of silicone as I could to the plate, then put down one corner and rolled it down as I slowly worked it until the whole thing was attached. I finally stacked some weight on top and let it sit for a couple days to cure.
                      I considered vacuum bagging it but the silicone needs air to cure. Maybe vacuum bagging to squish it down hard, then taking it out of the bag and letting it sit for a couple days would work.
                      • jens55
                        @mrehorstdmd Thanks for the details !
                        • martin7404
                          So mine is not good
                          jay_s_uk 1 Reply Last reply Reply Quote 0
                          • jay_s_uk
                            jay_s_uk @martin7404 last edited by
                            @martin7404 time for a new one then
                            • zapta
                              zapta @martin7404 last edited by
                              Apropos sticker removers, I wonder how this magic formula will be effective in removing the Keenovo/3M adhesive.
                              https://www.youtube.com/watch?v=wjIy2PJ8y-Q
                              • martin7404
                                martin7404 @jay_s_uk last edited by
                                @jay_s_uk Yes, i ordered one with lower power density. And also to make it smaller than the bed in order to apply some RTV frame around. As far in EU delivery from keenovo will be slow I also ordered fermio labs one 300x300 with built in 150 deg C protection that is good price 49 EUR and fast delivery. IT also produced by keenovo.
                                Original one 300x400 was 900 wats, the fermio one is 500 W. With the original one hotend fan was havinf hard time
                                Also to balance things I am adding 250 W chamber heater with fan for abs and other warping materials
