    Is there NO WAY to connect to DWC?????
    duet web control firmware update duet 3 mini 5+
    1.7k
    • A Former User?
      A Former User
      This is day 4 of my effort to prepare a brand new legit Duet 3 Mini 5+. At this rate, I'll print something by the end of 2022, may-be.
      The address for DWC: 192.168.1.90 is not working for me, or my board. I've used Firefox, Chrome, and Safari, none have worked. I've done the same with http://duettest.local/.
      I read the note about mDNS support. Really? You're expecting me to understand that gibberish?
      I bought this board to print things with, not to become a programmer.
      After the last three days, I was ready to chuck this board back to the seller. But I don't like quitting.
      I understand (or I think I do) that I need to access DWC so I can put all the new firmware that's available on the board. That's going to be another big hump to get over, but right now, I'm stuck once more
      If you can help, I would really appreciate it.
      Mark
      Rushmere3Dundefined alankilianundefined 2 Replies Last reply Reply Quote 0
      • Rushmere3Dundefined
        Rushmere3D @A Former User
        @corlissmedia
        So I take it you've followed this guide https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet correct?
        The address given is an example not the actual address of your board, you should have been given the address in a previous step.
        Can you access your home network router? This will show the address being used.
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
        • alankilianundefined
          alankilian @A Former User
          @corlissmedia We don't even know if it's Ethernet or WiFi, so it's a little hard to help.
          • A Former User?
            A Former User @Rushmere3D
            @rushmere3d that’s interesting. I’ll check it out thank you.
            • A Former User?
              A Former User @alankilian
              @alankilian wifi
              alankilianundefined 1 Reply Last reply Reply Quote 0
                @corlissmedia OK, good to know.
                Please scroll down to section 5 on THIS PAGE and let us know what you see compared to the document.
                What do you get to the M552 commands as you turn off your WiFi?
                What to you get from your M587 command to configure your WiFi?
                What do you get to the M552 commands as you turn on your WiFi?
                • Do you get "WiFi is connected to access point (whatever you access point is using for its SSID) , IP address is xxx.yyy.zzz.www?
                A Former User? 2 Replies Last reply Reply Quote 1
                • A Former User?
                  A Former User @A Former User
                  @corlissmedia
                  • A Former User?
                    @alankilianWiFi module is idle
                    M552
                    WiFi module is changing mode
                    ok
                    WiFi reported error: Wrong password while trying to connect to NETGEAR83_2GEXT
                    WiFi module is idle
                    M552 S-1
                    WiFi module stopped
                    ok
                    M552
                    WiFi module is disabled
                    ok
                    M552 S0
                    M552
                    ok
                    • A Former User?
                      @alankilian WiFi module is idle
                      WiFi module is connected to access point NETGEAR83, IP address 192.168.0.XX
                        Phaedrux Moderator @A Former User
                        @corlissmedia said in Is there NO WAY to connect to DWC?????:
                        I think we found the problem.
                        Does your password contain any special characters?
                        What terminal software are you using the set the password?
                        See the notes here: https://docs.duet3d.com/User_manual/Reference/Gcodes#notes-96
                          OK, you should have gotten an actual IP address and not one ending in "XX"
                          I have NO IDEA how in the heck that could have happened.
                          I'm 100% baffled.
                          • A Former User?
                            @alankilian that was something I did to hide the numbers. I have the numbers, but I thought they should remain mine, and not published here.
                            • A Former User?
                              A Former User @Phaedrux
                              @phaedrux the password looks like this, only the letters have been changed in this example: anduyrt789
                              How is that wrong?
                                How is that wrong?
                                That's between you and your wifi router.
                                The error message says your router rejected your password.
                                If there are no unusual characters. All lower case and numbers, there should be no issue there, so that just leaves the password being incorrect.
                                What terminal software are you using? Mac? If so, the password command will need to be typed correctly all in one go without stopping or back spacing.
                                Alternatively you can create a small text file with the command and place it on the SD card in the sys folder, call it addwifi.g Then from the terminal you can send M98 Paddwifi.g and it will execute the command for you without the terminal software getting in between.
                                • A Former User?
                                  @phaedrux I’m on a Mac, yes. I’m not using the Mac Terminal to enter the password? I’m using SerialTools to enter the password?
                                  I’ve redone the entry a number of times. I’ve used software from Netgear to verify the password. I’m sure I’ve entered the correct password for that extended network.
                                  One thing that concerns me: when I use system preferences, then Network to see the networks I have, NETGEAR93 (not 83) shows up. So I think at some point I typed something after the M587 command that caused some confusion. I don’t know how to delete that phantom network. I do know that I can long on to it, but when I try to do that, it asks for a password. I’ve tried the password I thought was for it, and the password for the 5G network. Neither has worked.
                                  My apologies, but your last suggestion made no sense whatsoever to me. Since I can’t access the fils on the card, which are on the board I still can’t use DWC to view, how does that work?
                                  Great suggestions and help, though. Thank you.
                                  fcwiltundefined engikeneerundefined 2 Replies Last reply Reply Quote 0
                                  • fcwiltundefined
                                    fcwilt @A Former User
                                    He is talking, I think, about doing what I do.
                                    I remove the SD card from the Duet and insert it into a device I have connected to my computer which allows me to read/write an SD card.
                                    I keep a standard, minimum config.g file on my computer. It has the bare minimum commands to get a Duet up and running with WiFi
                                    This is what I do:
                                    • modify the standard config.g file for the needs of the given WiFi connection
                                    • write the modified file to the SD card.
                                    • remove the SD from the device connected to my computer
                                    • insert the SD card back into the Duet.
                                    Of course I don't remove or insert the SD card with the Duet powered on.
                                      addwifi.g
                                      Yes, exactly. You'd need to remove the SD card from the Duet and put it in your Mac to edit the files on it.
                                      I've attached a sample macro you can use. Edit it and change the M587 command to use your SSID and password and copy the file to the sys folder on the SD card. Then put it back in the Duet and reconnect by USB terminal. Now send the command M98 P"addwifi.g" which will run that file and execute your command and hopefully get you connected to the wifi network.
                                      Contents of the file:
                                      ; Add default wifi network
                                      M552 S0			; Disable network module
                                      G4 S5			; wait 5 seconds
                                      M587 S"NETWORKNAME" P"PASSWORD"			; Add duet wifi SSID to remembered networks list
                                      M552 S1			; reenable wifi module
                                      A Former User? 2 Replies Last reply Reply Quote 0
                                      • engikeneerundefined
                                        engikeneer @A Former User
                                        @corlissmedia you can also use this command to remove all remembered networks from the WiFi module.
                                        M552 S0 ; set wifi to idle
                                        M588 S"*" ; forget all networks
                                        i3 clone with a bunch of mods
                                        • A Former User?
                                          @phaedrux Thank you, I will try to do exactly what you’re suggesting tomorrow morning. But first I will try once more to verify the Ssid and password.
                                          I do wish I didn’t have this Netgear AC1900 EX7000 extender.
                                          • A Former User?
                                            A Former User @engikeneer
                                            @engikeneer are you saying I can use that code in SerialTools? My SerialTools doesn’t look like that. Are you using the colors feature to get that look? Thank you.
                                            engikeneerundefined 1 Reply Last reply Reply Quote 0
