    I could use some help
    682
    63.5k
    • A Former User?
      A Former User @fcwilt
      @fcwilt I'm still considering your M92 edit (moving it to ABOVE the M350 line). Can I simply copy and paste? Will the form renumber itself?
      fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @A Former User
        @mac said in I could use some help:
        Yes, you can cut-and-paste a line of code with no problems.
        • A Former User?
          A Former User @A Former User
          @droftarts
          M574 X1 S1 P"!io5.in"                              ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !io5.in
          M574 Y1 S1 P"!io6.in"                              ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !io6.in
          M574 Z1 S1 P"io2.in"                                       ; configure Z-probe endstop for low end on Z
          • fcwiltundefined
            @droftarts
            Great!
            Now execute the M119 again and let us know what is reports.
            • A Former User?
              @droftarts new M119: X not stopped, Y not stopped, Z at min stop, Z probe not stopped
              A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
              • A Former User?
                @droftarts the print head's six inches off the bed
                • fcwiltundefined
                  Great!
                  Notice that it says Z at min stop - was the Z endstop switch actually closed when you ran the M119?
                  • fcwiltundefined
                    I just asked a related question about the Z endstop switch.
                    Now you need to find a way to execute the M119 while both the X and Y endstop switches are closed - maybe with a bit of tape or a rubber band?
                    • A Former User?
                      @fcwilt the only thing that would close the z endstop is if the X axis came down and closed it.
                      • A Former User?
                        @fcwilt wait, fcwilt? not droftarts? jeeze you guys are ganging up on me!
                        • fcwiltundefined
                          OK that's good to know.
                          If the white wire is actually connected to the NO connection of the Z endstop switch it should not be indicating Z at min stop.
                          Find a way to close the Z endstop switch and execute M119.
                          I want to see if it still reports Z at min stop or if it reports something different.
                          • A Former User?
                            @droftarts @fcwilt if we're going to work on this together, I need to know you two are in agreement before I do anything.
                            Do you both agree that I should tape X and Y closed? Then M119 again?
                            fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                            • fcwiltundefined
                              No - it just gets confusing when posts overlap in time.
                              I'm typing, your typing, droftarts is typing - and things get a bit out of order - time wise.
                              • fcwiltundefined
                                Mac! You've cut me to the quick! Have you no faith in me! 😉
                                I've only been doing this stuff for years.
                                • A Former User?
                                  @fcwilt @droftarts I closed the z-endstop with my left finger, and hit M110 Send with my right finger. M119 reported Z: at end stop, Z probe: not stopped.
                                  I'm not making this up, guys.
                                  • A Former User?
                                    @fcwilt @droftarts I'm just trying to be respectful to Ian and you.
                                      droftarts administrators @A Former User
                                      @mac I’m not able to reply promptly now, I’m away from my computer. @fcwilt knows what he’s doing, though please keep it simple, Frederick!
                                      • fcwiltundefined
                                        fcwilt @droftarts
                                        @droftarts said in I could use some help:
                                        I try to keep it simple, I really do.
                                        • A Former User?
                                          @fcwilt @droftarts
                                          M569 P0.0 S1                                       ; physical drive 0.0 goes forwards
                                          M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
                                          M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
                                          M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
                                          M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
                                          M92 X40.00 Y40.00 Z2000.00 E420.00                 ; set steps per mm
                                          M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                                          M203 X6000.00 Y6000.00 Z600.00 E1200.00            ; set maximum speeds (mm/min)
                                          M201 X500.00 Y500.00 Z200.00 E250.00               ; set accelerations (mm/s^2)
                                          M906 X600 Y600 Z600 E600                           ; set motor currents (mA)
                                          M84 S0                                             ; Disable motor idle current reduction
                                          • A Former User?
                                            @mac M92 cut and pasted to before M350, board rebooted.
