    Purgeline on Delta
    3D Printing General Chat
    409
    • tecnoundefined
      tecno
      Hi, I use Simplify3D and would like to have following in start gcode.
      Purgeline to go anticlockwise from 9 o'clok to 6 o'clock.
      G3 X0 Y-85 R85 will not work so what am I doing wrong?
      Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
      • Rushmere3Dundefined
        Rushmere3D @tecno
        @tecno Do you not need an E value?
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @Rushmere3D
          @rushmere3d
          G28
          G1 X-80 Y0 Z0.4 F3000 ; move to arc start
          G3 X0 Y-80 R80 Z0.4 E40 F400 ; lay arc stripe 90deg
          No arc as you can see
          alankilianundefined 1 Reply Last reply Reply Quote 0
          • alankilianundefined
            alankilian @tecno
            @tecno said in Purgeline on Delta:
            I use ncviewer.com and I do get an arc.
            Also, when I run on my Rostock Max V3.2 with a DUet2/Ethernet, I get an arc.
            • tecnoundefined
              tecno @alankilian
              @alankilian
              It looks like SF3D is not working with R.
              So how to write same with I and J ??
                alankilian @tecno
                @tecno
                For this arc, you can replace the R80 with I80 and get the same arc.
                Unfortunately, the S3D preview doesn't show that either. 😞
                The gcode previewer I linked to works perfectly for your experiments.
                  alankilian @alankilian
                  @tecno Also, it doesn't really matter that S3D preview doesn't show the arc, the printer will perform the action even if the previewer doesn't.
                  So, I would put the purge line in S3D's starting script and just remember it's there for when you don't want a purge line.
                  tecnoundefined 1 Reply Last reply Reply Quote 1
                  • tecnoundefined
                    tecno @alankilian
                    @alankilian
                    OK, thanks for this Alan. Will have to try this out then.
