    Hotend heater does not show up in DWC
    Duet Web Control
    8
    22
    999
    • foesiundefined
      foesi
      Hallo, I want to use a Duet 3 mini 5+ as controller for a Tronxy X5SA-600 and therfore I want to have one bed heater and one hotend heater.
      I have them configured in config.g like this:
      M308 S0 P"temp0" Y"thermistor" T10000 B4100 ; configure sensor 0 as thermistor on pin temp0
      M143 H0 S105 ; set temperature limit for heater 0 to 105C
      M308 S1 P"temp1" Y"thermistor" T10000 B4100 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M140 H1 ; map EXTRUDER HEATER to heater 1
      M143 H1 S310 ; set temperature limit for heater 1 to 310C
      But in DWC there is just the bed heater displayed (picture).DWC-24082022.PNG
      I tried to type in M98 p"config.g" which gives me this output:
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      Did I miss something obvious or can someone tell me what to try?
      jumpedwithbothfeetundefined Norderundefined 2 Replies Last reply Reply Quote 0
      • jumpedwithbothfeetundefined
        jumpedwithbothfeet @foesi
        @foesi have you mapped the tool in config.g using M563?
        foesiundefined 1 Reply Last reply Reply Quote 1
          Post your full config.g
          jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
          • Norderundefined
            Norder @foesi
            @foesi said in Hotend heater does not show up in DWC:
            The M140 command is for bed heating only.
            You can remove this command for the hotend.
            Info:
            M140 (GCode Dictionary)
            DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
            Thingiverse
            foesiundefined 1 Reply Last reply Reply Quote 0
            • foesiundefined
              foesi @jumpedwithbothfeet
              @jumpedwithbothfeet No, I haven't. I put the M563 P0 D0 H1 just now into config.g and it worked!
              The other strange thing is that the extruder and bed temperatures are at -21°C. What could be the cause of that?
              Norderundefined 1 Reply Last reply Reply Quote 0
              • foesiundefined
                foesi @Norder
                @norder I saw this in another config.g and gave it a try 😉
                  jumpedwithbothfeet @Phaedrux
                  @foesi as phaedrux mentioned you should post your config.g along with your config-override.g files, I have seen the -21 issue before but for the life of me I cant remember the cause, best to check your using the correct settings for you hotend/bed thermistors/heaters before using them, are they stock parts or have you changed them?
                  @phaedrux said in Hotend heater does not show up in DWC:
                  • Norderundefined
                    Norder @foesi
                    Make a T100000 out of the T10000 in the M308 command lines, i.e. one more 0.
                    P.S.:
                    But you didn't copy the settings for the thermistors from someone else's config.g ? 🤔
                    You should already enter the thermistors that you have installed.
                    Otherwise errors could occur or, in the worst case, your printer could catch fire and then there is a risk of death !
                    If everything works, you should do a PID tuning for the bed and the hot end so that the temperatures are kept stable.
                    Thingiverse
                    • foesiundefined
                      @jumpedwithbothfeet config.g-25082022.txt config.g.bak.txt
                      The thermistors and heaters are stock parts - I have only changed the controller board to the duet 3 mini 5+ because the tronxy board was not reliable and made strange things during printing - after I had it for 4 months. Then I bought the duet because the tronxy support could not figure out what the problem was and I have another duet 2 wifi for 2 1/2 years now which works reliable on my own built printer.
                      • foesiundefined
                        foesi @Norder
                        @norder The change to T100000 made the difference - but I have put 84000 there wich is the resistance I measured at around 18°C and that made no difference.
                        And no I did NOT just copy someone else's config.g 🙂 . I just saw the line in the config.g and gave it a try 😉 . I will definetly do a PID tuning for both - because I need to do this twice a year due to the fact that the temperatures of winter and summer are quite different in Austria.
                        Thank you for your effort!
                        mendenmhundefined 1 Reply Last reply Reply Quote 1
                        • foesiundefined
                          foesi
                          Another thing which is not a problem but could be done better is the value of the Z-Probe.
                          I got it to work whith a trigger value of 1000 and the usual value is 964.
                          Is there a way to get the normal value down to 0?
                          cosmowaveundefined 2 Replies Last reply Reply Quote 0
                          • cosmowaveundefined
                            cosmowave @foesi
                            @foesi Which type of z-probe do you use?
                            config?
                            Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                            • foesiundefined
                              foesi @cosmowave
                              @cosmowave I use the orignal Tronxy TR leveling sensor.
                              https://www.tronxyonline.com/Tronxy-Black-TR-Auto-Leveling-Sensor-p1486299.html
                              I run it with 12V because I have not connected it to the 5V or the 3.3V of the IO port.
                              • Norderundefined
                                Norder
                                @droftarts said in Hotend heater does not show up in DWC:
                                With the comment he meant his Z-Probe.
                                Not the thermistor.
                                Thingiverse
                                  droftarts administrators @Norder
                                  @norder oops! Thanks, reading on phone screen, I missed that! I’ve deleted my reply.
                                    cosmowave @foesi
                                    An analog sensor needs at minimum a bit offset.
                                    How is the sensor configured in config.g?
                                    Can you exactly describe your wiring please.
                                      This post is deleted!
                                      • foesiundefined
                                        foesi @cosmowave
                                        @cosmowave the sensor is configured like this:
                                        M558 P1 C"!io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
                                        G31 P999 X-41 Y5 Z5 ; set Z probe trigger value, offset and trigger height
                                        M557 X50:550 Y50:550 S50 ; define mesh grid
                                        I have connected the signal to the io3.in of the IO_3 port. The + and - are connected to the 12V port in the center of the board.
                                        cosmowaveundefined 1 Reply Last reply Reply Quote 0
                                          cosmowave @foesi
                                          @foesi For me, the config and wiring seems ok.
                                          Perhaps it helps when you insert a resistor into the signal line from probe to io3 pin to get a lower value?
                                          But i'm not completely sure if this will work...
                                          • mendenmhundefined
                                            mendenmh @foesi
                                            @foesi
                                            "but I have put 84000 there which is the resistance I measured at around 18°C"
                                            That's a really unlikely resistance for a 100k thermistor at 18C. It should be well above 100k, close to 150k, at that temperature. These thermistors are specified at 25C, and have a negative temperature coefficient, which means the resistance is higher at lower temperatures.
                                            Is it possible you used your fingers to hold the meter leads on the thermistor, and got a reduced reading due to leakage through your skin?
                                            Anyways, use the nominal 100k value in your calibration. It is probably very close to correct.
