    Duet Wifi Dead ?
    1.8k
    • SIamundefined
      SIam
      Last Sunday i have printed the last Time and all was fine! after this print i have switch off my Printer.
      On Sunday night i wantet start a New Print but i can't reach the Duet by Web 😞 The same Problem with USB no connection
      So i have try to change the SD-Card but without suxess.
      After that i have checked the Powersupply this is stable with 24 Volts.
      Normaly if i switch on The printer the Fans will start and stop after view seconds this don't work now the next Problem i have found is that the hotend and the head Bed will power on when i switch on The printer !
      In the last day I have checked all the Cable but i don't find some error.
      When i switch on the Printer all LED's are on and nothing else happens i can Press the Reset or The erase Button without any reaction here is a picture you can see the Board
      https://photos.app.goo.gl/K27brzMQEDzCa80O2
      is there any thing what i can do ?
      regards
      Andy
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
        If the heaters turn on when you apply power, then unfortunately it sounds as though there has been a severe over voltage event on the 5V or 3.3V rail that has blown the mosfet driver chip and probably the processor too. Is the processor or any other chip getting hot? What type of Z probe do you use?
        • SIamundefined
          SIam
          Hello
          this sounds not good 😞 on the board is nothing what is hot. I think you mean the z endstop ? this is a mechanical micro switch.
          • SIamundefined
            SIam
            hi,
            now i have controlled the Board Power on the 5 V i have 4.88V and on the 3.3 V i Have 3.1 Volts
              That's an odd failure mode. I've seen a couple of boards where the 5V or 3.3V rail appears to have been shorted to +12V or +24V, and in both cases the heaters turned on all the time AND some chips were getting hot (usually the 3.3V regulator, processor, and sometimes the 74HCT02 or 74HC125). If the 3.3V rail is only at 3.1V, that does suggest that the 3.3V rail is overloaded, in which case I would expect at least the 3.3V regulator to get hot.
              • SIamundefined
                SIam
                Today i have checked again all the kable in the hope to find a blank or lose connection which can cause a short circuit something must have happened but i can't find it.
                The only part of the printer which are supplied with 24 V and 3.3V is the hot end but even there I found nothing I'm going crazy.
                I'm an electronics technician myself and this makes it twice bad that i can't find any error
                At one point we agree that the board seems to be defective what may have ever happened is there a way to get this board repaired? if yes how? this board is 2 months old
                • SIamundefined
                  SIam
                  so far so good the printer works with a new Duet (except Y port) now is only the question what hav i to do to get the first board repaired ? can i send it directly or should i go to my German Seller?
                    @SIam:
                    It's not uncommon for the cartridge heater in a hot end to develop a short between the element and the case, sometimes only when is hot. This puts the entire hot end metalwork at +12V or +24V. So you only need a short from the metalwork to something else on the hot end assembly to feed +12V or +24V to somewhere that it shouldn't be. The thermistor connections on the Duet are protected against this, but not the 3.3V pin on the Z probe connector that provides power to the Z probe. What type of Z probe do you have, and is there any possibility that it could have shorted against the hot end metalwork?
                    • SIamundefined
                      SIam
                      i don't use a z Probe i only have an Z-endstop switch.
                      here are some photos from the hotend : https://photos.app.goo.gl/GfxbeygkryZRTKCE2
                        So is there any 3.3V wiring on the hot end apart from the thermistor wires?
                        • elmoretundefined
                          elmoret
                          Looks like a large DSUB connector, perhaps a stray wire inside that connector shorted +24v to +3.3v?
                          • SIamundefined
                            SIam
                            on the first photo you see a gray flat cable this is the only 3.3V to the optical x endstop This cable goes directly to the Duet the other cable (fan/hotend and Thermistor) goes to the sub D connector and then to the Duet.
                            All used pins in The sub D case are isolated with shrinking tube
                              Please put in a warranty claim to your supplier.
                              • SIamundefined
                                SIam
                                ok Thank You i will contact my supplier
