    Z 0 is positive
    1.1k
    • tecnoundefined
      tecno
      I have new printbed and have issues to get levelling to work.
      I get positive values with G30 S-1. What can I have done wrong?
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @tecno
        Here another odd number, where does it come from? Trigger height 7.843
        • tecnoundefined
          tecno @tecno
          I have managed to get a negative Z0
          Config = G31 P100 X0 Y0 Z-0.557
          When I run G30 S-1 after reboot I get following result that is confusing.
          So what is wrong here?
            Can you give us some more context to your method?
            tecnoundefined luca Massimilianoundefined 2 Replies Last reply Reply Quote 0
            • tecnoundefined
              tecno @Phaedrux
              @Phaedrux
              https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
              Calibrate the Z probe trigger height
              • luca Massimilianoundefined
                luca Massimiliano @Phaedrux
                @Phaedrux said in Z 0 is positive:
                SEND ME MORE MATERIAL
                • tecnoundefined
                  tecno @luca Massimiliano
                  @luca-Massimiliano
                  Hi Luca, what material?
                  • tecnoundefined
                    tecno @tecno
                    M558 B1 P8 R0.4 C"io3.in+io4.out" H15 F1500 T12000
                    M557 R225 S100
                      How are you setting Z0 before measuring the probe offset?
                      How are you determining Z0 before creating the mesh?
                      • tecnoundefined
                        tecno @Phaedrux
                        @Phaedrux
                        home
                        move z down to get 0
                        g92z0
                        A few g30 s-1 to see that it is same
                        open config.g
                        edit G31 line with offset
                        save and M999
                        See to that no compensation is active M561
                        G29
                        luca Massimilianoundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                          luca Massimiliano @luca Massimiliano
                          @luca-Massimiliano NO IT'S NOT ENOUGH I WANT TO SEE THE POINT QUOTAS OF YOUR PRINTING PLATE EACH POINT YOU SEE CORRESPONDS TO 3 CORDINATES OK?
                          luca Massimilianoundefined 1 Reply Last reply Reply Quote 0
                            luca Massimiliano @tecno
                                @luca-Massimiliano EVERY POINT IS THE POINT WHERE THE PROBE BEATS OK FRIEND?
                                    @luca-Massimiliano FRIEND SORRY I HAVE TO GO NOW EXCUSE ME BYE
                                      @luca-Massimiliano Phaedrux KNOWS MUCH MORE THAN I
                                        Phaedrux Moderator @tecno
                                        @tecno said in Z 0 is positive:
                                        save and M999
                                        G29
                                        Try doing a single G30 at the center of the bed before sending G29 to create the mesh.
                                        You should probably also redo your G32 first.
                                        • tecnoundefined
                                          tecno @Phaedrux
                                          @Phaedrux
                                          After a lot of tweaking this looks to be the best I can get.
                                          Every adjustment of the plate (3-points) a G32 is a must, G30 and then G29.
                                          Picture below is with 60°C heated bed.
                                          New 8mm thick fine milled cast aluminium plate Ø600mm, what can I expect to get in flatness?
                                          Cheers
                                          Bengt
                                          infiniteloopundefined 1 Reply Last reply Reply Quote 0
                                          • infiniteloopundefined
                                            infiniteloop @tecno
                                            @tecno
                                            That’s a good flatness, except of the front/left and rear/right - hmmm - "corners"?. For a Delta, a square grid as you’ve pictured is inappropriate. See M557: Set Z probe point or define probing grid for details. Instead of defining the grid by X/Y, use R to set a radius.
