    i'm afraid my next raspberry pi is going to die soon.
    762
    • spllgundefined
      spllg
      hello,
      indications:
      • sporadic loss of wifi connection. the connection will be restored after ~1 minute.
      • sporadic loss of connection rpi -> mb6hc. the connection will be restored after several seconds.
      i have already lost 2 raspberries in conjunction with my duet3 board. death has announced itself in the same way as described above.
      i am operating 2 other raspberries for years without interruption and never observed any loss of wifi connection.
      what can i do to protect my raspberry?
      thanks in advance for your answer.
      OwenDundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
      • OwenDundefined
        OwenD @spllg
        @spllg
        How is the Pi powered?
        And probably more importantly, how is it turned off?
        I can't think how being connected to the duet makes a difference unless the power to the pi is cut off without a proper shutdown.
        Perhaps something like this shutdown button is in order?
        spllgundefined 2 Replies Last reply Reply Quote 0
        • spllgundefined
          spllg @OwenD
          @OwenD
          1. powering: i will check later today.
          2. shutdown: i connect to the rpi using ssh and execute 'shutdown -h 0' on it before i cut off power.
          forgot to mention: the two dead rpis do not boot from any other sd-card but a new rpi booted from the sd card of the dead rpis.
          • oliofundefined
            oliof @spllg
            @spllg its probably a bit late for the dead RPis, but you could try switching your current RPi to boot from USB
            • spllgundefined
              spllg @oliof
              @oliof that' what i'm already considering but eve if the rpi will be bootable from usb after it refuses booting from sd card this will not cure the root cause of my issue.
                jay_s_uk
                its been years since i've properly shutdown a pi and not corrupted one yet... opens can of worms and walks away...
                • T3P3Tonyundefined
                  T3P3Tony administrators @spllg
                  @spllg i have heard of some people having issues with SD cards being corrupted on dieing in Pis, but from what you are saying that's not the core issue.
                  With that in mind i would rather ask how your Pi is cooled, and what else you have plugged into it?
                  I use heatsink case+ fans on my Pi 4s (but not on the 3b+) and have not managed to get any of them to die in the many years i have been using them. Maybe yours are running very hot?
                  www.duet3d.com
                  spllgundefined 1 Reply Last reply Reply Quote 1
                  • spllgundefined
                    spllg @T3P3Tony
                    @T3P3Tony
                    cooling: heat sinks without fan - going to check temperature tonight
                    plugged devices: camera + hdmi display
                    • T3P3Tonyundefined
                      @spllg ok so yes, cooling is important but as others have pointed out getting a proper 5.1V 3A+ power supply with all that extra load of the screen will be important too.
                      www.duet3d.com
                      • spllgundefined
                        spllg @OwenD
                        @OwenD & @T3P3Tony
                        • the rpi is powered by the genuine rpi powersupply
                        • the duet is powered via internal 5v (jumpers: internal 5v en = closed, 5v -> sbc = open, sbc -> 5v = open)
                        • after printing ~1hour none of the rpi-chis is hot - i could touch it with a finger for a long time, so i guess, the temperature is below 45-50 C
                        i forgot to mention -
                        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet 3 MB6HC v1.0 or earlier FIRMWARE_DATE: 2022-11-30 19:35:23
                        • spllgundefined
                          spllg @oliof
                          @oliof could the death of 2 rpis be related to the fact that i have a Duet 3 MB6HC v1.0 (newer boards seem to have a different 5v powering design).
                          Rushmere3Dundefined dc42undefined oliofundefined 3 Replies Last reply Reply Quote 0
                          • Rushmere3Dundefined
                            Rushmere3D @spllg
                            @spllg I have an earlier version and haven't killed any Pi's.
                            Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
                              dc42 administrators @spllg
                              @spllg said in i'm afraid my next raspberry pi is going to die soon.:
                              If using an earlier version 6HC, you could avoid any possible issues with the Pi and the Duet being powered at different times by powering the Duet 5V from the Pi instead of from the internal regulator.
                              spllgundefined 1 Reply Last reply Reply Quote 0
                              • oliofundefined
                                oliof @spllg
                                @spllg I never killed any rPis with my early release Duet3 MB6HC, but I did switch to external power eventually because the 5v from my Duet board tended to dip deep into undervoltage.
                                • spllgundefined
                                  spllg @dc42
                                  @dc42 just to be sure: in order to power the 6hc 5v from the pi the jumpering is
                                  internal 5v en = open, 5v -> sbc = open, sbc -> 5v = closed
                                  is this correct?
                                  • spllgundefined
                                    spllg @spllg
                                    @spllg no, it's not correct - https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6HC_Hardware_Overview : Alternatively, the SBC can provide 5V for the Duet using the "SBC -> 5V" jumper. Note that the Duet's in-built protection is bypassed. In this case the "5V->SBC" and the "SBC->5V*" jumpers should both be fitted, but remove the jumper from "Int 5V EN".
                                    i have jumpered it accordingly and hopefully my rpi will survive with this configuration.
                                    dc42undefined 1 Reply Last reply Reply Quote 1
                                      @spllg that sounds good.
                                      The other thing to check is that there are no ground loop issues between the PSUs supplying the Pi and and Duet. If you use an official Raspberry Pi PSU as I do, that PSU has no ground connection, so there is no problem. If the PSU powering the RPi does have a ground connection, then you should power that PSU and the Duet PSU from the same mains socket. Even better, use a single mains input to your machine and connect the mains grounds to those PSUs internally.
                                      • spllgundefined
                                        spllg @dc42
                                        @dc42 thanks for your answer. as i am using an official rpi psu a ground loop should not be an issue and my rpi should not be in danger.
                                        still kind of concerned.
                                        rgds, g.
