    Parallel Scara based on Morgan.
    My Duet controlled machine
    772
    • Phospherusundefined
      Phospherus
      Wanted to build a Morgan so instead of trying to convert the pipes used in it I built my frame from 2020 rail and made by own bearing blocks and some other bits.
      T3P3Tonyundefined 1 Reply Last reply Reply Quote 4
      • o_lampeundefined
        o_lampe
        Looks nice and solid.
        If you're planning to post a few details, it would be better to move the thread to "my Duet controlled machine" section...just ask a mod for it.
        • T3P3Tonyundefined T3P3Tony moved this topic from Off Topic
        • T3P3Tonyundefined
          T3P3Tony administrators @Phospherus
          @Phospherus nice, and this is probably not "off topic" so I have moved it as suggested by @o_lampe
          www.duet3d.com
            Phospherus
            Bit of an update firmware seems solid but unfortunately I thought 15mm diameter carbon fiber tube would be strong enough for the rotational forces and i was wrong. I have some twisting which causes a springiness on the inner shaft. Now going to 25mm for the inner shaft which is the diameter the outer used to be and 30mm for the outer.
            I also purchased a set of https://www.amazon.com/gp/product/B0BQ728M9F/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
            These are 30:1 with 0.6 degree steppers. Supposed to have 2 Arcmin back lash which is 0.03 degree so should be plenty accurate. I thought about going true 5 bar with those mounted 45mm apart I would have the same print area as I do now. Anyone have any experience with these?
            • o_lampeundefined
              o_lampe @Phospherus
              @Phospherus said in Parallel Scara based on Morgan.:
              The way I read it, it's a regular 1.8° motor and the 30:1 reduction results in 0.06°step angle
              Phospherusundefined 1 Reply Last reply Reply Quote 0
                Phospherus @o_lampe
                @o_lampe I see now thanks for pointing that out. I hope they are decent quality and good enough.
                JoergS5undefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                • JoergS5undefined
                  JoergS5 @Phospherus
                  @Phospherus I'd wish you open it in a iFixit style and post some images to discuss the quality. Unfortunately - I completely understand it - you'll not want to do it because of the guarantee. But if it's damaged in the future, this would be valuable. They are out of stock and a bit too expensive to buy it just for testing.
                  • o_lampeundefined
                    o_lampe @Phospherus
                    @Phospherus It surprised me, that they took a short NEMA17 motor with low torque for it. I guess a full size motor would exceed the max. output torque of the harmonic drive.
                      Phospherus
                      First printing with the Scara looking good so far. No z endstop so set it with piece of paper and no heated bed as my PSU mount is printing so running off a 5 amp 24V power pack. Using a Bondtech BMG for bowden drive with a Phaetus BMO hotend. Link to youtube video below. This is my first time ever uploading to youtube so if it does not work I apologize and will fix it.
                      https://youtu.be/9VRnl9GF-Sk
                      o_lampeundefined 1 Reply Last reply Reply Quote 2
                      • o_lampeundefined
                        o_lampe @Phospherus
                        This post is deleted!
                        Phospherusundefined 2 Replies Last reply Reply Quote 0
                          Phospherus @o_lampe
                            Phospherus @o_lampe
                            @o_lampe Video link should work now.
                            • o_lampeundefined
                              o_lampe @Phospherus
                              @Phospherus Looks good for a first print on a cold bed. 👍
                                Phospherus
                                A couple pictures of the first print complete. I am amazed how good it came out without part cooling even.20230309_121359.jpg 20230309_121421.jpg
                                  Phospherus
                                  Finally got a test set of arms printed and a mount for the Nema 17 harmonic drives. Here it is in action. https://youtube.com/shorts/bj47uQ08zV0?feature=share
                                  o_lampeundefined 1 Reply Last reply Reply Quote 1
                                  • o_lampeundefined
                                    o_lampe @Phospherus
                                    @Phospherus It's always hard to qualify mechanics from a video. The first impression is good, no visible backlash or springiness.
                                    Will be interesting to see it work, maybe with a feltpen for starters?
                                    Would you use a direct drive extruder as toolhead or is it strictly Bowden-setup? How much does the head sag?
