    beta 3.5b2 no wifi re connection after emergency stop
    Beta Firmware
    569
    • moth4017undefined
      moth4017
      this has happened a few times now after an emergency stop , DWC will not reconnect, have to reboot the duet3 mini 5 board to get reconnected.
      • T3P3Tonyundefined
        T3P3Tony administrators @moth4017
        @moth4017 is that using the emergency stop button in DWC? if possible can you connect a USB cable and see if you can reproduce it, then send M552 and M122 over USB and report the results here.
        www.duet3d.com
        moth4017undefined 2 Replies Last reply Reply Quote 0
        • moth4017undefined
          moth4017 @T3P3Tony
          @T3P3Tony i would do this but for some reason i can no longer get the com port to work
          can i use M929 to log the info required?
          • moth4017undefined
            moth4017 @T3P3Tony
            @T3P3Tony
            eventlog.txt logfile if you look at the logfile i hit the "emergency stop" button in DWC after the "homez.g"
            • T3P3Tonyundefined
              @moth4017 that shows the WiFi module starting and reconnecting
              www.duet3d.com
              moth4017undefined 1 Reply Last reply Reply Quote 0
              • moth4017undefined
                moth4017 @T3P3Tony
                @T3P3Tony the resart was me pushing the reset button on the duet 3mini5 so I could get access to the log file via DWC , I could just pull the SD card and get the data with out a restart
                • moth4017undefined
                  moth4017
                  @T3P3Tony
                  Data from SD card after the "Please stand by...." message ion DWC
                  in the log file "emergency stop" in DWC was pressed during the home z.g macro
                  eventlog1.txt
                  • terabyteundefined
                    terabyte
                    I am very happy with 3.5b2 so far, but suddenly, I've realized that I have the same issue on the mini5 Ethernet. I have to reboot the board to reconnect DWC.
                    I'll do some more tests later tonight if I have a chance.
                    • moth4017undefined
                      moth4017 @terabyte
                      @terabyte
                      Hi , i have lost my usb connection but could you see if you can do what Tony suggested
                      If possible can you connect a USB cable and see if you can reproduce it, then send M552 and M122 over USB and report the results here.
                      • Alex.crundefined
                        Alex.cr
                        I can also confirm this is a problem for me as well. I am using a 6HC with SBC. I have to power cycle the whole machine to get it through the issue. Simply rebooting the Pi4 will not solve the problem.
                        Here is an M122 after reboot.
                        m122
                        RepRapFirmware for Duet 3 MB6HC version 3.5beta2 (2023-02-08 15:27:50) running on Duet 3 MB6HC v1.0 or earlier (SBC mode)
                        Board ID: 08DJM-956L2-G43S4-6J1FD-3SJ6T-TB6QH
                        Used output buffers: 1 of 40 (17 max)
                        Static ram: 154344
                        Dynamic ram: 85824 of which 2892 recycled
                        Never used RAM 99556, free system stack 200 words
                        Tasks: SBC(ready,0.7%,418) HEAT(notifyWait,0.0%,325) Move(notifyWait,0.0%,342) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,340) TMC(notifyWait,6.0%,90) MAIN(running,92.5%,160) IDLE(ready,0.8%,30), total 100.0%
                        Owned mutexes: HTTP(MAIN)
                        Last reset 00:01:45 ago, cause: power up
                        Last software reset at 2023-03-10 21:36, reason: User, Gcodes spinning, available RAM 99556, slot 1
                        Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                        Error status: 0x00
                        Step timer max interval 132
                        MCU temperature: min 23.5, current 24.4, max 37.5
                        Supply voltage: min 0.2, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                        12V rail voltage: min 0.2, current 12.2, max 12.2, under voltage events: 0
                        Heap OK, handles allocated/used 99/15, heap memory allocated/used/recyclable 2048/1472/1232, gc cycles 0
                        Events: 0 queued, 0 completed
                        Driver 0: standstill, SG min 0, mspos 8, reads 52289, writes 11 timeouts 0
                        Driver 1: standstill, SG min 0, mspos 8, reads 52289, writes 11 timeouts 0
                        Driver 2: standstill, SG min 0, mspos 8, reads 52282, writes 18 timeouts 0
                        Driver 3: standstill, SG min 0, mspos 8, reads 52282, writes 18 timeouts 0
                        Driver 4: standstill, SG min 0, mspos 8, reads 52282, writes 18 timeouts 0
                        Driver 5: standstill, SG min 0, mspos 8, reads 52283, writes 18 timeouts 0
                        Date/time: 2023-03-11 11:47:31
                        Slowest loop: 2.36ms; fastest: 0.06ms
                        === Storage ===
                        Free file entries: 20
                        DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                        no step interrupt scheduled
                        === DDARing 0 ===
                        === DDARing 1 ===
                        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                        Heater 1 is on, I-accum = 0.0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon* is idle in state(s) 0
                        Aux2 is idle in state(s) 0
                        File2 is idle in state(s) 0
                        Queue2 is idle in state(s) 0
                        Q0 segments left 0, axes/extruders owned 0x80000003
                        Code queue 0 is empty
                        Code queue 1 is empty
                        === Filament sensors ===
                        Extruder 0: no data received
                        === CAN ===
                        Messages queued 892, received 4517, lost 0, boc 0
                        Longest wait 3ms for reply type 6053, peak Tx sync delay 49166, free buffers 50 (min 49), ts 528/400/0
                        Tx timeouts 0,0,127,0,0,0 last cancelled message type 30 dest 127
                        === SBC interface ===
                        Transfer state: 5, failed transfers: 0, checksum errors: 0
                        RX/TX seq numbers: 3297/3297
                        SPI underruns 0, overruns 0
                        State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x26934
                        Buffer RX/TX: 0/0-0, open files: 0
                        === Duet Control Server ===
                        Duet Control Server version 3.5.0-beta.2 (2023-02-08 11:47:09)
                        Code buffer space: 4096
                        Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                        Full transfers per second: 14.41, max time between full transfers: 286.2ms, max pin wait times: 34.3ms/7.2ms
                        Codes per second: 0.60
                        Maximum length of RX/TX data transfers: 4505/804
                        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                        PetrKroupaundefined 1 Reply Last reply Reply Quote 0
                        • PetrKroupaundefined
                          PetrKroupa @Alex.cr
                          Same here. After Emergency stop, DWC stuck in please wait. Presing reset buton on 6HC bring machine back to life.
                          6HC + 1LC, SBC.
                          BigOne:Duet3 6HC +1LC + Rpi5 +SSD, mosquito hotend, 400x400x420
                          SmallOne : Duet3 6HC +1LC + Rpi5 +SSD, mosquito hotend, 210x250x210
                          Petr
                          • moth4017undefined
                            moth4017
                            if you refresh the browser you still get the "Please stand by "........ message , i still carnt get my USB to connect so i carnt grab the data.
                            • moth4017undefined
                              moth4017
                              Also i have noticed that i cannot connect to the printer, if the printer is on before the PC which i use to connect to the printer . pressing the reset button on the printer then gets a connection .
                              • moth4017undefined
                                moth4017
                                ive also tried this on a stm board running 3.5b2 same issue if you press "emergency stop" in DWC you get the "Please stand by "........ message untill you reset the control board.
