    2 different brushes for 4 printheads
    581
    • Mike 1undefined
      Mike 1
      I use a E3D tool changer. Core xy, Duet 2 Wifi with extension board V3.45.
      I do have 2 V6 and 2 Hemera extruders. This makes it due to geometricl issues nessesary to use a brush on the left and right side.
      Is there a way to impement a if case depending on the active extruder which macro to use?
      Thanks!
      Mike
        jay_s_uk @Mike 1
        @MIke-1 why not call the macro as part of tpost?
        Otherwise query the current tool in the object model and then run the appropriate commands
        Mike 1undefined 1 Reply Last reply Reply Quote 0
        • Mike 1undefined
          Mike 1 @jay_s_uk
          @jay_s_uk
          Oh, I am not sure if I understand the sentence correctly. Do you mean that I shall call the makro in one of the tool changes skripts? That's what I am doing now. But I would like to wipe on layer change controlled by superslicer.
            jay_s_uk @Mike 1
            @MIke-1 then call the macro at later change and have an if statement to check the current too in the object model and if tool 0 and 1 do this else if 2 or 3 do that
            • Mike 1undefined
              Mike 1 @jay_s_uk
              @jay_s_uk said in 2 different brushes for 4 printheads:
              That's what I need, but how does it work?
                jay_s_uk @Mike 1
                @MIke-1 see https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands and https://docs.duet3d.com/en/User_manual/RepRapFirmware/Object_Model
                Mike 1undefined 1 Reply Last reply Reply Quote 1
                • Mike 1undefined
                  Mike 1 @jay_s_uk
                  @jay_s_uk
                  OK, did my best and got this error message:
                  T0
                  Error: in file macro line 2 column 21: meta command: unknown value 'active'
                  if tools[0].state = active
                  M98 P"brush_right.g"
                  elif tools[1].state = active
                  M98 P"brush_left.g"
                  elif tools[2].state = active
                  elif tools[3].state = active
                  M98 P"brush_left.g"
                  else
                  continue
                  OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    are you using indentation with your statements?
                    Perhaps you could use
                    state.currentTool
                    Number of the currently selected tool or -1 if none is selected
                    and then check for the tool number and act accordingly.
                    • OwenDundefined
                      OwenD @Mike 1
                      @MIke-1
                      Try something like this
                      The indentation is important
                      if state.currentTool != -1 ; check if a tool selected
                        if state.currentTool < 2 ; must be 0 or 1
                          M98 P"leftbrush.g"
                        else
                          M98 P"rightbrush.g ; must be 2 or higher
                        dc42 administrators @Mike 1
                        @MIke-1 the reason that doesn't work is that you need to put "active" in double quotes. But an easier way is to use state.currentTool as @OwenD suggests.
                        • Mike 1undefined
                          Mike 1 @OwenD
                          @OwenD
                          Oh, I can't use this version because my tools are alternating.
                          OwenDundefined 1 Reply Last reply Reply Quote 0
                          • Mike 1undefined
                            Mike 1 @dc42
                            Oh thanks! Now it is working fine!
                            You are all awsome!
                            • OwenDundefined
                              OwenD @Mike 1
                              @MIke-1 said in 2 different brushes for 4 printheads:
                              @OwenD
                              Apologies
                              I missed that
                              • Mike 1undefined
                                Mike 1 @OwenD
                                @OwenD
                                Thanks anyway!
                                • OwenDundefined
                                  OwenD @Mike 1
                                  @MIke-1
                                  My clumsy effort was mainly to prompt you to try to condense your code if possible.
                                  Whilst manually creating an if / elif for every tool works, it's often more efficient in code and easier to read if you look for a pattern that will work regardless of the number of tools (or heaters or whatever).
                                  In your case, one pattern is whether the tool selected is an odd or even number.
                                  We can check that using mod()
                                  What I should have posted was something like this.
                                    if mod(state.currentTool,2) = 0 ; tool must be even number or zero
                                    else
                                      M98 P"brush_left.g" ; must be odd numbered tool
                                  else
                                    echo "no tool selected"
                                  You do however have to ensure that there is indeed a tool selected, otherwise state.currentTool is -1 and it would resolve to false and run the brush left macro
                                  mod(-1,2)=0 is false
                                  Whereas in your code, you don't have a condition for -1, so that wouldn't occur.
                                  If the code works, it's not wrong and it terms of lines of code there's not much difference in this case, so there's no reason for you to change what you have now.
                                  Mike 1undefined 2 Replies Last reply Reply Quote 1
                                  • Mike 1undefined
                                    Mike 1 @OwenD
                                    @OwenD
                                    Sorry for the late reply, I did not expect an answer.
                                    But your code hepled me to better understand how the coding here works 🙂
                                    I used the first line to make homing more save, as I can only do homing without a tool attached to the printheard.
                                    I will keep my code because it ist more simpple to read and allows me to select a 3rd or 4th macro with different bush settings. It might get interesting, if I will use a vulacono hotened in the future.
                                    Thanx!
                                    • Mike 1undefined
                                      Mike 1 @OwenD
                                      @OwenD said in 2 different brushes for 4 printheads:
                                      else
                                      else
                                      Can I use 2 commands after an if? How do I know when the if ends? I am missing () or endif to understand when something ends 🙂
                                      • gloomyandyundefined
                                        gloomyandy @Mike 1
                                        @MIke-1 The meta commands in RRF use indentation to indicate which statements are part of the body for conditional statements so for instance
                                            G28 X
                                            G28 Y
                                        Makes both home commands conditional but in
                                            G28 X
                                        G28 Y
                                        only the G28 X is conditional
                                        See: https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#conditional-construct
                                        • Mike 1undefined
                                          Mike 1 @gloomyandy
                                          @gloomyandy
                                          Thanx!
                                          Topic can be closed 🙂
