    PanelDue Firmware 3.5.0-rc6 released
    PanelDue
    809
    • mfs12undefined
      mfs12
      Hey people,
      a new release candidate is build and available on github.
      Firmware images and detailed release notes as usual on github.
      https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.5.0-rc6
      Visit me on github at https://github.com/mfs12/
      OwenDundefined 1 Reply Last reply Reply Quote 3
      • mfs12undefined mfs12 referenced this topic
      • OwenDundefined
        OwenD @mfs12
        @mfs12
        For me this fixes the issue where thumbnails were not displaying on PD. 👍
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @OwenD
          @OwenD said in PanelDue Firmware 3.5.0-rc6 released:
          @mfs12
          Sadly it did not for me 😮‍💨
          OwenDundefined 1 Reply Last reply Reply Quote 0
          • OwenDundefined
            OwenD @Exerqtor
            @Exerqtor
            I have run some tests with the files you uploaded.
            The difference I see is that you are using Prusa Slicer.
            By default it includes the bed image in the thumbnail. There doesn't seem to be an option to turn it off.
            I am using SuperSlicer.
            I had it set NOT to include the bed in the thumbnail.
            If I set it to include the bed and generate the400x400 image first, then the thumbnail does not display.
            This tells me that with the bed included, the thumbnail is likely larger than the amount that PD is parsing to find it.
            These two files are the same except in one the bed is included and in the other it is not.
            test-superslicer-with-bed.gcode
            test-superslicer.gcode
            • mfs12undefined
              mfs12
              @Exerqtor did you update RRF as well. As @dc42 mentioned there was a second problem with RRF thumbnail parsing. I am not sure if this fix already available.
              • Exerqtorundefined
                Exerqtor @mfs12
                @mfs12 I'm on 3.5b3+ atm, i don't think it's an newer version thats publicly avalible yet? 🤔
                  dc42 administrators @Exerqtor
                  @Exerqtor said in PanelDue Firmware 3.5.0-rc6 released:
                  3.5b3+
                  Please provide the GCode file concerned so that I can test it before we release 3.5beta4.
                  mfs12undefined OwenDundefined 2 Replies Last reply Reply Quote 0
                  • mfs12undefined
                    mfs12 @dc42
                    @dc42 this are the testfiles from @Exerqtor
                    https://mega.nz/folder/1VcgnA7A#3FFCNqOrY9yk6ODI-c6ABQ
                    • OwenDundefined
                      OwenD @dc42
                      @dc42 @mfs12
                      It seems to be related to the detail of the thumbnail.
                      A thumbnail with 400x400 and 160x160 values of this works as expected on PD
                      ; thumbnail_QOI begin 400x400 86248
                      ; thumbnail_QOI begin 160x160 19260
                      The 400x400 started on line 15 and finished on 1122
                      The 160 x 160 started on line 1126 and finished on line 1374
                      Whereas this will not display on PD
                      ; thumbnail_QOI begin 400x400 89288
                      ; thumbnail_QOI begin 160x160 19600
                      The 400x400 started on line 15 and finished on 1161
                      The 160 x 160 started on line 1126 and finished on line 1418
                      To test it I placed a cylinder on the slicer bed. 10 x 10 x 10
                      Then right click and select "fill bed with instances"
                      You can then play with the height of the cylinder (instance 1) until you find the tipping point.
                      As I noted above, Prusa Slicer by defaults includes the image of the bed as part of the thumbnail, so it's got more detail.
                      In super slicer you can turn that off so you're only dealing with the print objects.
                      All files display properly in DWC
                      I also tried reversing the order the thumbnails were generated and the results remained the same.
                      EDIT
                      After some further testing, the tipping point for my test can be seen in these two files.
                      At 9.56mm high the file works.
                      At 9.58mm high it doesn't display in PD
                      remove the .txt from the end
                      test 9-58.zip.txt
                      dc42undefined 2 Replies Last reply Reply Quote 2
                        dc42 administrators @OwenD
                        @OwenD which version of RRF are you using?
                        • OwenDundefined
                          OwenD @dc42
                          @dc42 said in PanelDue Firmware 3.5.0-rc6 released:
                          @dc42 I'm running
                          RRF 3.5.0b3+
                            @OwenD both those files work for me (thumbnail is displayed on PanelDue) using a slightly more recent build of RRF than 3.5beta4, with the 3.5.0-rc6 PanelDue firmware. However, the second thumbnails finish on lines 1376 and 1381, and the 160x160 come before the 400x400, which is not what you said in your post. Did you post the wrong files?
                            • OwenDundefined
                              OwenD @dc42
                              When I did the original post I had the 400x00 first.
                              When I did all the extra testing I tried 160x160 first.
                              I failed to edit the line numbers.
                              However I've just realised in amongst all the different tests I must have flashed the wrong version onto PD so that testing to find the "tipping point" is invalid 😡
                              With RC6 both those files work.
                              However if you check these files, you should find that the one with 160x160 first works and the one with 400x400 first doesn't display on PD
                              EDIT
                              Every file I've tested that had the160x160 thumbnail first works fine, so I'm not really seeing it as a bug. I don't think it's unreasonable to specify the order.
                              test-superslicer-with-bed-400-160.zip.txt
                              test-superslicer-with-bed-160-400.zip.txt
                              • ComedianTF2undefined
                                ComedianTF2
                                Testing out Paneldue firmware 3.5.0-rc6 (paneldue 7i) in combination with RepRapFirmware 3.5.0-beta.4 (on a Duet 2 WiFi) is giving a weird issue, in that after a certain amount of time, the paneldue stops responding to any kind of inputs on the LCD. I can still see updates coming from the display like temperature changes and homing status, but touching the screen does nothing.
                                Unplugging and re-plugging in the cable makes it work again temporarily, but after a bit of time (around a minute or so), it stops working again.
                                It doesn't seem to be linked to the screensaver, I have the screensaver at 120 seconds, and it stops working before the screensaver kicks in
                                Rolling back to 3.4.1 on the paneldue seems to fix the problem
                                  droftarts administrators @ComedianTF2
                                  @ComedianTF2 Thanks for your report, @mfs12 may have to have a look at this. Are these Duet3D or clone boards? Please can you check the wiring connections are all good. Are you using the ribbon cable or 4-wire cable?
                                  ComedianTF2undefined 1 Reply Last reply Reply Quote 0
                                    ComedianTF2 @droftarts
                                    @droftarts These are official Duet boards, wiring connections are all good. Using a long ribbon cable, have not tested it out using the 4 pin cable
                                    With the 3.4.1 firmware there are no problems at all
                                    • mfs12undefined mfs12 locked this topic
