    Panel due went blank.
    641
    • anthony1mundefined
      anthony1m
      Panel due 5i issue screen just went blank . It was on a mini5 , Also tested on my duet wifi with currently has a working panel due. It was working fine then just blanked out. purchased 3/17/23
      elmoretundefined 1 Reply Last reply Reply Quote 0
      • elmoretundefined
        elmoret @anthony1m
        Have you reflashed the firmware? And if so, what file did you use?
        anthony1mundefined 1 Reply Last reply Reply Quote 0
          Can you tell if the backlight is still on?
          If you shine a bright light at the screen can you tell if there is actual content on it, just without backlight?
          Does it make a beep when you touch it?
          How do you have it connected? Have you checked the wiring?
            anthony1m @Phaedrux
            @Phaedrux the back light is on currently , Wiring is correct no beeps or response.
              anthony1m @elmoret
              @elmoret I was able to reflash using bossa still not working the screen is just white back light on.
              • elmoretundefined
                elmoret @anthony1m
                @anthony1m how about the second question?
                  What firmware version is the Duet running?
                  Exactly which file did you flash to the panel?
                    anthony1m @Phaedrux
                    @Phaedrux 3.5.0 panel due fw 3.4.1 dwc on the mini5
                      anthony1m @elmoret
                      @elmoret it was working fine, I did not update and have issues it was all the latest fw when I put the machine together changed nothing after that my other panel due works fine on either machine
                        anthony1m @anthony1m
                        @anthony1m rc3v2-5.0.bin
                          Try flashing it again with this file.
                          https://github.com/Duet3D/PanelDueFirmware/releases/download/3.4.1/PanelDueFirmware-logo-3.4.1-5.0i.bin
                          https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue#firmware-update-via-usb
                          • elmoretundefined
                            elmoret @anthony1m
                            @anthony1m that’s the wrong firmware, you have a 5i so you need firmware written for a 5i
                              anthony1m @Phaedrux
                              @Phaedrux No Change I flashed that same just a white screen
                                anthony1m @elmoret
                                @elmoret did not work still blank white screen no response or change.
                                  You've pressed the erase and then reset buttons?
                                  In bossa You MUST check the Erase all, Lock, and Boot from flash boxes.
                                  Does the flash finish successfully and the verify as well?
                                    anthony1m @Phaedrux
                                    @Phaedrux I erased and reset, Correct boxes checked flashed and verified with file sent. Still no change
                                      @anthony1m What is the next step to getting this working or replaced ?
                                        Thanks for checking. The most common reason for a blank white screen is the wrong firmware being flashed.
                                        Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                                        anthony1mundefined elmoretundefined 2 Replies Last reply Reply Quote 0
                                          anthony1m @Phaedrux
                                          @Phaedrux Thank you very much you guys are great help much appreciated.
                                          • elmoretundefined
                                            elmoret @Phaedrux
                                            @Phaedrux To close the loop on this one, PanelDue 5i was received, white screen on powerup, reflashed the firmware, is working normally.
