    Hollow shaft extruder
    345
    40.5k
    • nikschaundefined
      nikscha @droftarts
      @droftarts said in Hollow shaft extruder:
      @nikscha Do you think there's any way you can reduce the diameter of the large gear? My first impression was that it would be a bit top heavy, though a lighter motor would help with that. @o_lampe 's point about it being a long way from the drive gear to the hot end, particularly for flexible filaments, could also be problematic.
      What is your view on the Archimedes screw extruder?
      Well the diameter of the "wheel" depends on multiple factors, like hypoid offset, gear ratio and number of teeth.
      The hypoid offset is limited by the diameter of the drive wheel, which is the bondtech LGX in my case. gear ratio is aimed at 1:7, and tooth size is limited by the material properties.
      I made all my prototypes from resin gears (Sirayatech white mecha), which were quite brittle, but I've since moved to gears made from IGUS SLS plastics. They're much stronger and more durable, and with them it might be possible to have a smaller wheel and/or a higher reduction ratio.
      While testing I found that the "top heaviness" isn't that much of a problem, I'll post my input shaping results later for proof 😉
      About the Archimedes screw extruder:
      Very neat! And so light! I am jealous!
      But there's no way of tensioning the filament, and loading/unloading can only be done electronically.
      A harder filament will also provide more resistance to deformation which might stall the extruder. A softer filament might slip. There's also only one "teeth" engaging with the filament, so it might slip easier, especially considering that there's no way of tensioning it.
      Abrasive filament will also dull the knife edge.
      Edit:
      A quick calculation shows that at 15degree pitch one revolution of the screw will advance the filament by about 1.5mm (tan15 * 1.75 *pi), the archimedes extruder has (360/1.8)= 200 steps per revolution, so about 133.33 steps per mm, which is not that much.
      Edit2: judging from this: https://youtu.be/YTADdWiFQnI?t=238 my math is wrong, and the archimedes extruder needs about two revolutions to advance the filament by 1.75mm, which implies 1.14 revolutions for 1mm. This is equal to 228 steps/mm
      Stay in school
      • nikschaundefined nikscha referenced this topic
      • o_lampeundefined
        o_lampe @nikscha
        @nikscha Thanks for joining the conversation.
        I've made some small gears with ABS-like resin and also Anycubics tough resin.
        Especially the latter is promising for testing gears. Could you achieve the same ratio with a smaller module? Your hypoid wheel looks like it can lift a car...but there is not much torque to deal with.
        nikschaundefined 2 Replies Last reply Reply Quote 0
        • nikschaundefined
          nikscha @o_lampe
          @o_lampe
          I don't think resin gears are the way forward. You want something abrasion resistant because hypoid bevel gears slightly rub against each other, it's not a pure rolling motion like spur gears for example.
          Instead I'm using SLS printed gears (IGUS).
          One BIG problem that needs solving is the stepper getting hot. Usually this isn't a problem, but with a hollow shaft extruder the filament going through the shaft will get hot. Pla especially will soften quickly. Resin printed pinions that sit on the shaft will soften as well.
          I had to run my old stepper at 600mA, while it's rated at 800, just to prevent overheating. I remedy this by counterboring the shaft from the top, and inserting a thin-walled ptfe tube for insulation.
          The new stepper that has the ptfe tube and Igus gears can run hotter (obviously), but I haven't tested it enough yet.
          If you have a delta printer and a smart effector and want to help me test, please hit me up, I'll gladly sent you a gear pair and custom stepper motor.
          Stay in school
          • nikschaundefined
            nikscha @o_lampe
            @o_lampe
            You definitely could archive the same ratio with a smaller module.
            Don't overestimate the hypoid gears tho, the ratio is only about 1:7, and the stepper is a nema 14, so not much torque here either.
            I should also state again that the diameter of the bigger gear is a function of hypoid shift. Hypoid shift is among other determined by the diameter of the drive wheel, in my case an LGX hardened drive wheel by bondtech. You could use a smaller one, maybe something that's used in the orbiter which is using 12mm diameter drive wheels instead of the LGX 18mm, which makes the hypoid shift 6mm instead of 9mm.
            But this now means that the pinion is so small that you can't have it sit on a stepper motor shaft, it's diameter is now only 4mm instead of the 5.7mm I get with the LGX gears. This means that the red section will be too thin: 131d5f24-8951-4b7b-93f1-248d6200a972-image.png
            Stay in school
            • OwenDundefined
              OwenD
              Interesting concept.
              I'll be interested to see if the resonant frequencies common in hypoid gears have an effect on extrusion.
              nikschaundefined 1 Reply Last reply Reply Quote 0
              • nikschaundefined
                nikscha @OwenD
                @OwenD Could you elaborate? I haven't heard of those resonant frequencies
                Stay in school
                OwenDundefined 1 Reply Last reply Reply Quote 0
                • OwenDundefined
                  OwenD @nikscha
                  @nikscha said in Hollow shaft extruder:
                  My experience with regards to printing has only been with the Zesty nimble.
                  If you search you should find plenty of examples of the artifacts.
                  The V2 version is supposed to have fixed this, but I'd given up by then.
                  Hence my interest to see if this implementation of similar gears will present with the same issues.
                  The older of us would be well familiar with these frequencies on car differentials.
                  There is plenty of research on how these frequencies occur, but the math is well over my head.
                  • nikschaundefined
                    nikscha @OwenD
                    @OwenD
                    I printed @MIHAIDESIGNS extruder test piece and it looks very smooth.
                    Does that answer your question?
                    Stay in school
                    • OwenDundefined
                      OwenD @nikscha
                      @OwenD
                      I don't see the same patterns, but there does seem to be some irregular extrusion in places.
                      It probably looks worse in the photo than in person and is way less than the issue I had.
                      Not trying to hose down the idea, just interested from a mechanics point of view.
                      • nikschaundefined
                        nikscha @OwenD
                        @OwenD
                        You're right, they're not perfect. But close 😁
                        I used to use the Flex3Drive and the Ingenuity extruder is quite a bit more consistent.
                        MirageC made some interesting conclusions in this video, which I tried to consider in my design.
                        The alignment of the gears is constrained by the LGX drive gear and a roller bearing, and the idler is basically flat, so there shouldn't be any lateral forces on the filament: 14c2d011-b54f-4813-9f94-67a9bf1ea79b-image.png
                        Stay in school
                        • o_lampeundefined
                          o_lampe @nikscha
                          It's perfect for testing and the ABS-like resin withstands 200°C+ , way more than the stepper temp will raise.
                          It's also a good starting point if you want to cast a silicone mould and reproduce it in bigger quantities.
                          Although the abrasion of an hypoid gear is an issue without lube or grease. Did you try that?
                          • nikschaundefined
                            nikscha @o_lampe
                            @o_lampe i started with siraya tech white mecha resin which is an abrasion resistant resin, but it was too brittle. I mixxed in 10% siraya tech tenacious to make it tougher. That worked, but under higher temperatures the resin would still soften. For testing I just ran the printer a bit slower and reduced the current, and I'm very happy with the geometry now.
                            For people who want to build their own, a resin printed gear is probably totally fine.
                            I also really like the idea of using a mold, thanks!
                            Yes I usually lubricate the gears which makes them run about 20% smoother. I have also tried running them dry for a while and I haven't seen any significant wear on the gears yet.
                            Stay in school
                            • o_lampeundefined
                              o_lampe
                              I wonder why the VDE100 (archimedes) base has to be so exact? In the video, he had to grind the flanged bearing to a certain diameter to make it work with the base.
                              If the shafts of the bearings would tilt slightly outwards, we could add some springs and have them autoadjust (self tightening) to the right diameter.
                              A ring-lever which would push the bearings against the springs, would release the filament if it needs to be removed.
                              Inserting new filament would be just...inserting.
                              Similar concept we know from the PTFE tube fittings...
                              • nikschaundefined
                                nikscha @o_lampe
                                @o_lampe That's a nice idea. You would need a very stiff but small spring. A disc spring seems ideal.
                                The ring lever is also smart, I'm imagining an inverse "ramp" on the bottom of it which pushes the lever up and down, depending on the position of the lever. The bearings then press/ride against the smooth top of the lever.
                                This could be used to set a maximum tension as well.
                                Stay in school
                                o_lampeundefined 1 Reply Last reply Reply Quote 1
                                • o_lampeundefined
                                  o_lampe @nikscha
                                  @nikscha The original VDE100 files are somewhere on thingiverse, including an (*) FreeCad parametric file.
                                  I really suck with modifying any CAD when it's not my design. Do you volunteer to make a version of our idea?
                                  • The wavy washers might work, but they don't have much room to compress.
                                  • The ring lever should hold a plain washer because the bearings will rotate on it.
                                  • The spring force must be big enough to have working retraction without slip.
                                  Couldn't find it there but on reprap-forum
                                  Carrier#3.FCStd
                                  • nikschaundefined
                                    nikscha
                                    @o_lampe I never used freeCad but maybe I can make a copy of the design in Fusion. Will take a while though.
                                    Stay in school
                                    • o_lampeundefined
                                      o_lampe
                                      I translated the FreeCad data to OpenScad and added a variable "tilt"
                                      Here's a 5° tilt
                                      And the OpenScad file.
                                      carrier_tilted.scad
                                      Reduced carrier diameter and sort-off lever added, just for clarification
                                      • tombrazierundefined
                                        tombrazier
                                        Hi all, I made the VDE-100 video that has been referenced a few times. I have been using the VDE-100 for a long time now and I love it. Several comments in response to the thread above:
                                        @nikscha your maths was correct, tan(15) * 1.75 * pi is the theoretical thread pitch. In reality the knife edges tend to drag a bit through the filament resulting an a somewhat lower pitch.
                                        Loading/unloading is pretty easy but, yes, it is done by instructing the extruder stepper to turn. I have my whole VDE-100 assembly attached via a quick release clip which also helps because occasionally a blob on the end of the filament went retract through the extruder. And the quick release is super cool for dealing with nozzle clogs, etc.
                                        The extruder seems to just work on any filament (e.g. floppy TPU at one end of the scale and hard PLA at the other). But I think definitely avoid abrasive filament. I did print recently with GF filament and specifically swapped out my extruder for another that is not as nice as the VDE but has bondtech gears.
                                        There have been suggestions about tensioning. I played around a lot with tensioning ideas, including using a similar idea to @nikscha's printed spokes. In the end, it just is not needed. The knife edges cut into the filament and that provides the tension. But it does mean you need fairly precise diameters @o_lampe. Since I found a way to cut those even with rudimentary tools, I am satisfied with that. Of course, you also need precise filament diameters, but that's pretty much a given these days.
                                        Steppers getting hot: with the VDE-100 the stepper stays nice and cool because there is so little torque needed and so not much current is needed. I would think Ingenuity would have the same benefit.
                                        Filament twisting in the VDE-100: this is surprisingly far less of a problem than you'd think. The melted plastic in the nozzle provides a fair back torque. And the shorter the part through the heatsink, the better this effect is. Once again, though, precision edge diameter is key. Cut too far into the filament and that creates more torque.
                                        VDE files to play with: I published my files with FreeCAD model on printables.com.
                                        o_lampeundefined nikschaundefined 2 Replies Last reply Reply Quote 3
                                        • o_lampeundefined
                                          o_lampe @tombrazier
                                          @tombrazier With all due respect, but grinding an edge to a flanged bearing is not my favorite evening activity 😉
                                          I want to find an economic way to (mass-) produce the edge.
                                          A self-adjusting design would reduce labour cost significantly. If it also adds a comfortable way to change filament, it's even better.
                                          tombrazierundefined 1 Reply Last reply Reply Quote 0
                                            tombrazier @o_lampe
                                            @o_lampe said in Hollow shaft extruder:
                                            Really? Why? 😁
                                            If you can work out a way of self adjusting I'd be very interested to see it. I didn't really follow the conversation above. I need a picture, I think.
