    Hollow shaft extruder
    345
    40.5k
    • tombrazierundefined
      tombrazier @nikscha
      @nikscha said in Hollow shaft extruder:
      I'll do some testing with lower currents to see how little torque is actually required.
      The trick will be to figure out at what speed your extruder's flow rate hits the wall. Then tune current so that the E stepper does not start losing steps before that point.
      nikschaundefined 1 Reply Last reply Reply Quote 1
      • nikschaundefined
        nikscha @tombrazier
        @tombrazier fair I could do that, but isn't that highly dependent on nozzle-dia, meltzone length, filament etc? I would get a number that works for me but maybe not for others, right?
        Maybe I could test how much weight the LGX mini and the Orbiter (I have both) can lift and compare that to the Ingenuity. Then I have a rough estimate of what is "expected", and I can adjust the torque according
        Stay in school
        • nikschaundefined
          nikscha @tombrazier
          @tombrazier I'd think that a bigger included angle actually makes grip worse. My train of thought is that Bondtech can get away with 90° because more than 1 tooth is engaged in the filament, and they choose 90 degrees because it holds up better against abrasive filament.
          It makes sense that you don't need the second ring with the speeds you're going at. But I'm surprised that you don't print faster with such a lightweight extruder. That seems to be the biggest advantage to me. What other reasons are there to use your extruder instead of the Orbiter for example? You mentioned something about ease of disassembly earlier I think?
          Stay in school
          mrehorstdmdundefined tombrazierundefined 2 Replies Last reply Reply Quote 0
          • mrehorstdmdundefined
            mrehorstdmd @nikscha
            How about the print artifacts attributed to dual drive gear extruders? I suspect the screw-type extruder doesn't suffer the same problem.
            nikschaundefined 1 Reply Last reply Reply Quote 0
            • nikschaundefined
              nikscha @mrehorstdmd
              @mrehorstdmd yeah I don't see how that would be possible. There's way less moving parts and no gears at all.
              @tombrazier did you print mihaidesigns extruder test piece? I'd be curious whether any patterns show up there.
              Stay in school
              o_lampeundefined tombrazierundefined 2 Replies Last reply Reply Quote 0
              • o_lampeundefined
                o_lampe @nikscha
                I found a simple way to deal with the BMG gear issue, would be interesting to print the extruder test.
                I added a screw to adjust the gear-mesh no matter how the tension spring is set.
                Do you have a link?
                First I thought, I had to become patron, but he offers the test file for free on his HP
                nikschaundefined 1 Reply Last reply Reply Quote 2
                • nikschaundefined
                  nikscha @o_lampe
                  @o_lampe Interesting, do you have a picture of it in CAD? I'm not familiar with the sherpa, so it's hard to tell what I'm looking at 😅
                  Thanks also for the link for the extruder test piece.
                  Stay in school
                    tombrazier @nikscha
                    That was my expectation too - mainly informed by how grip works on ice skates. The closer to vertical the side of the blade is, the more grip there is. But the thread widening effect acts like a plough wheel. It's not grip that is the problem but rather that a furrow is being ploughed through the plastic. You can actually see this and it really does look like ploughed earth with a little ridge piled up parallel to the thread. I am now wondering whether different plough wheel profiles would have different ploughing effects. I notice plough wheels tend to be thin. So if I don't actually want to plough, what if I used a more wedged shaped wheel?
                    I tend to prefer a maximum 0.15mm layer height and often print at 0.1mm and sometimes at 0.05mm. This needs fast X and Y movement but does not need high extrusion rates.
                    Ease of disassembly is also a feature I value.
                    The killer features for me were the steps/mm ratio and the simplicity. I started with a cloning a Prusa extruder which drives a pair of bondtech gears with no gearing and with a significant sideways force applied to the end of the stepper shaft, which adds a lot of friction. My recycled E stepper often just could not produce enough torque to drive this configuration. Then I played with a printed split ring orbital gear assembly which was wonderful when it worked but sometimes would start spitting out bits of gear tooth mid-print. In comparison the VDE-100 was extremely light, needed very little current so there were no heat problems and just works.
                    And, as @mrehorstdmd suggests, the VDE-100 eliminates the artifacts related to the bondtech gears and the step size of the E stepper.
                    It's printing now.
                    • o_lampeundefined
                      o_lampe
                      I made my first tilted VDE-100 carrier yesterday and tried to put some 10mm bearings on. Surprisingly they don't really cut it.
                      I tried several different setups, with or without washer underneath, 1,2 or 3 flanged bearings with flange up or down.
                      My impression is, that it would work better with 8mm bearings, so I wrote another sketch to draw the bearings instead of the carrier.
                      Now I can see much clearer, how deep the flange would cut into the filament at a given offset and tilt-angle.
                      cut.scad
                      As a sidenote: the idea to push the bearings up with a ring lever will need extreme force, but one step at a time.
                      tombrazierundefined 1 Reply Last reply Reply Quote 0
                        tombrazier @o_lampe
                        @o_lampe Yes, 10mm is too large. The bearings interfere with each other. I am now using MR85ZZ flanged bearings and a MF95ZZ pressure bearing. Even the MF95ZZ is a bit big and I have shaved the corners down a little to prevent interference.
                        And while I'm talking about bearings, ABEC rated bearings are a really good idea. Rq3 uses ABEC-5 and I have been using ABEC-3.
                        Your carrier appears to have all three bearings cutting the filament at the same height. This will create three grooves very close together and experience shows that that tends to just grind up the filament. I arrange my two knife-edged bearings so they run in the same groove.
                        Also note that the axis of rotation of each bearing needs to be positioned so that it comes to its closest point to the axis of the filament at the exact height where the knife edge cuts the filament.
                          tombrazier @nikscha
                          Here's a picture.
                          There is a very slight pattern but I found it really difficult to photograph. I have indicated with an arrow where you can see it in the photo.
                          • o_lampeundefined
                            o_lampe @tombrazier
                            @tombrazier said in Hollow shaft extruder:
                            I agree, there is a downside with this arrangement, but each bearing has two opponent bearings and the filament has no way to move or flex.
                            I'm under the impression that the flanged bearing idea is not the best solution.
                            Maybe it's better to have three rotating shafts with blades at different heights and the ends of the shafts run in bearings.
                            These shafts could easily be CNC'd on a lathe and would cost next to nothing (thinking big)
                              tombrazier @o_lampe
                              @o_lampe rq3 tried lots of those kinds of variations, including diamond dust glued to the bearings. Flanged bearings won handily. The problem with stacked blades is that there is only one point along the axis of the bearing/shaft that is the correct point for interfacing with the filament. It's the point I mentioned above where the axis of the bearing/shaft is closest to the axis of the filament. I would have to stop and think now to remember why that was so important, but I remember it was important.
                              [Edit: But do experiment. I experimented a lot as well and repeated a lot of rq3's findings. But there's always scope for finding something we've missed.]
                              • o_lampeundefined
                                o_lampe @tombrazier
                                @tombrazier
                                I quickly sketched something that looks like it could work. The blades are each 0.5mm different in height. That should be correct, when they are 120° apart and the advance is 1.5mm? Somehow it looks wrong, but it's just a matter of adapting the formula.
                                tombrazierundefined nikschaundefined 2 Replies Last reply Reply Quote 0
                                  tombrazier @o_lampe
                                  @o_lampe I see I misunderstood you. I thought you meant multiple blades per shaft.
                                  The extruder you show with three blades is pretty much what I have been using for the last year, except I only have two blades and the third bearing is just a plain one that acts as am idler for the two blades. And, yes, the vertical spacing would be something like 0.5mm each for a 1.5mm thread pitch. For me this was really easy to implement using flanged bearings once I worked out an easy way of grinding the bearings. But shafts with blades as you suggest would work just as well and I agree it's more a matter of what is easier to manufacture.
                                  • nikschaundefined
                                    nikscha @tombrazier
                                    I see. Do you have a macro shot of the filament after it has been extruded? Would also be interesting to see the difference between filament that has been extruded with a "load" applied vs without. Probably the pitch will change then? And/or the amount of "plow"? Maybe even steps/mm will change depending of load/resistance from the nozzle?
                                    I also don't understand why you only grind one of the 3 bearings, wouldn't all 3 be better? Is there some mechanical constraint? Or is 1 just enough for the purposes of the extruder?
                                    It's printing now.
                                    Awesome!
                                    Edit: I just saw that my question about the 3 cutting bearings was answered already!
                                    Stay in school
                                    • nikschaundefined
                                      nikscha @tombrazier
                                      @tombrazier that's basically non-existent. I'd say the VDE-100 passes with flying colors.
                                      Stay in school
                                      • nikschaundefined
                                        nikscha @o_lampe
                                        @o_lampe Neat! But how would you attach the blades? Or make it from a single piece?
                                        Stay in school
                                          mrehorstdmd
                                          Maybe replacement cutting wheels for this sort of tubing cutter could be used:
                                          • pakarundefined
                                            pakar
                                            Just wanted to jump in as the video says that the motors was special-order.
                                            There seems to be both nema 8/14/16/17 motors available with hollow shafts with a 3mm ID.
                                            The nema 8 comes in at 50g weight while still providing 1.5Ncm.
                                            https://www.omc-stepperonline.com/dual-shaft-nema-8-hollow-shaft-stepper-motor-bipolar-1-5ncm-2-12oz-in-0-49a-20x20x27mm-8hs12-0494h
                                            https://www.omc-stepperonline.com/nema-14-hollow-shaft-stepper-motor-bipolar-18ncm-25-5oz-in-0-8a-35x35x34mm-14hs13-0804sh
