    Duet 3 Scanning Z probe
    88
    6.0k
    • CR3Dundefined
      CR3D
      I want to setup a Scanning Tool for our printers but can not find a wiring schematic in the documentation
      Can you tell me how to connect pls?
      Thank you in advance
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
      oliofundefined bricorundefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @CR3D
        @CR3D the PCB silkscreen points out what the pins are, I can see GND to the left, and C_L (CAN low) and C_H (CAN high) to the right. Second from the left is VCC then, this tracks with the connection description on the documentation page https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Scanning_Z_Probe#description-of-connections
        The source for 5V depends on the board you use, on the Duet 3 mini 5+ I would choose 5V and GND from IO 4 due to proximity to the CAN header.
        • bricorundefined
          bricor @CR3D
          @CR3D
          Disregard this post
          see later post
          Wrong board version
            droftarts administrators @bricor
            @bricor That is a V0.1 development board (see PCB bottom right corner). The silkscreen has the CAN_H and CAN_L the other way around.
            @CR3D The V1.0 boards are:
            GND - 5V - CAN_L - CAN_H
            bricorundefined 1 Reply Last reply Reply Quote 0
            • bricorundefined
              bricor @droftarts
              @droftarts
              Thank you for the correction. I grabbed the pic from the current doc.
                @bricor I know, I was going to do the same thing until I noticed it was different! So I took a picture of the one I had on my desk that I received earlier this week. @T3P3Tony will put up a proper wiring diagram soon, hopefully.
                Edit: I've updated the documentation with the above picture: https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Scanning_Z_Probe#physical-connections
                CR3Dundefined 1 Reply Last reply Reply Quote 1
                • CR3Dundefined
                  CR3D @droftarts
                  Thanks to all! 🙂
                  Homepage:
                  www.cr-3d.de
                  Facebook:
                  Our Discord Server
                  • Killercdsundefined
                    Killercds @ofliduet
                    @ofliduet said in Duet 3 Scanning Z probe:
                    Is the STL / STEP for the probe holder availalbe that I see in the picture of the Revo toolboard?
                    Any updates on the availability of this specific mount?
                    It seems like it's a modified version of the PCB spacer
                    I would really like to integrate it into my E3D ToolChanger setup
