    Duet 3 Scanning Z probe
    88
    6.0k
      T3P3Tony administrators @zapta
      @zapta I see what you mean. It would be slower than the scanning mesh on many machines (depending on Z speed) but would give the Z positions where the sensor reads the same all over the bed. I still don't think it will necessarily be any more accurate though.
      zaptaundefined 1 Reply Last reply Reply Quote 1
      • zaptaundefined
        zapta @T3P3Tony
        @T3P3Tony, I see.
        I am trying to find a way to speed up touch sensors such as BL Touch but this approach should apply also to other sensors types. My hypothesis is that if instead of a binary state they provide a small hysteresis-free continuous region around a known point, the meshing can be speed up significantly since it requires only minor Z adjustments during the scan to tack that point. Not much different from the mesh compensation during the actual printing.
        Will see how it goes.
        • CR3Dundefined
          CR3D
          I want to setup a Scanning Tool for our printers but can not find a wiring schematic in the documentation
          Can you tell me how to connect pls?
          Thank you in advance
          Christian from CR-3D
          Homepage:
          www.cr-3d.de
          Facebook:
          https://www.facebook.com/cr3d.official
          Our Discord Server
          https://discord.gg/SxRaPNuRdA
          Thingiverse Profile:
          https://www.thingiverse.com/cr-3d_official/about
          oliofundefined bricorundefined 2 Replies Last reply Reply Quote 0
          • oliofundefined
            oliof @CR3D
            @CR3D the PCB silkscreen points out what the pins are, I can see GND to the left, and C_L (CAN low) and C_H (CAN high) to the right. Second from the left is VCC then, this tracks with the connection description on the documentation page https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Scanning_Z_Probe#description-of-connections
            The source for 5V depends on the board you use, on the Duet 3 mini 5+ I would choose 5V and GND from IO 4 due to proximity to the CAN header.
            • bricorundefined
              bricor @CR3D
              @CR3D
              Disregard this post
              see later post
              Wrong board version
                droftarts administrators @bricor
                @bricor That is a V0.1 development board (see PCB bottom right corner). The silkscreen has the CAN_H and CAN_L the other way around.
                @CR3D The V1.0 boards are:
                GND - 5V - CAN_L - CAN_H
                bricorundefined 1 Reply Last reply Reply Quote 0
                • bricorundefined
                  bricor @droftarts
                  @droftarts
                  Thank you for the correction. I grabbed the pic from the current doc.
                    @bricor I know, I was going to do the same thing until I noticed it was different! So I took a picture of the one I had on my desk that I received earlier this week. @T3P3Tony will put up a proper wiring diagram soon, hopefully.
                    Edit: I've updated the documentation with the above picture: https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Scanning_Z_Probe#physical-connections
                    CR3Dundefined 1 Reply Last reply Reply Quote 1
                    • CR3Dundefined
                      CR3D @droftarts
                      Thanks to all! 🙂
                      Homepage:
                      www.cr-3d.de
                      Facebook:
                      Our Discord Server
                      • Killercdsundefined
                        Killercds @ofliduet
                        @ofliduet said in Duet 3 Scanning Z probe:
                        Is the STL / STEP for the probe holder availalbe that I see in the picture of the Revo toolboard?
                        Any updates on the availability of this specific mount?
                        It seems like it's a modified version of the PCB spacer
                        I would really like to integrate it into my E3D ToolChanger setup
