cannot connect to duet 2 Wi-Fi or board
@Blunt2007
@Blunt2007 please repost your pictures in a size <4mbs so they upload.
@T3P3Tony The resolution that I'm uploading them with is the lowest that's my phone will take the photo in I uploaded them before with some help I don't have a photo editor
Sorry that's the best I can do right this time -
@Blunt2007 take a screenshot and post that
@droftarts I'm sorry My misunderstanding I did not know I needed to open a new ticket with this new board so I contacted printed solid to open a new ticket 42307
Did Printed Solid replace your board already?
undefined Phaedrux referenced this topic
@Phaedrux Yes Prince solutions already replaced the board this is a new board and I'm still not able to connect USB and the Wi-Fi will not connect to duet web connect and if I do connect it loses signal and will not reconnect
@Phaedrux wow it's connected today so I'm going to try running some updates and level in my bed with a BL touch
@Phaedrux having problem connecting to duet Web connect it was working fine for the 2 weeks and I printed a calibration cube and it came out pretty good I had to take two weeks off to take care of my dad and now I'm trying to reconnect to duet web connect and now it will not connect I tried turning off the board turning it back on I tried turning off the computer rebooting the computer several times I tried turning off Wi-Fi and turn it back on no matter what I do it will not connect to the wet web connect
Can you remind me if you were able to get a USB terminal connection going through the YAT software?
@Phaedrux no I had never had been able to connect via USB since I got the board I had to add a file to systems with my Wi-Fi information I haven't tried that yet this time I figured it was working fine when I last used it but now it doesn't work at all no matter what I do I cannot connect to duet web connect
Were you connecting to the DWC by an IP address?
It's possible that after a few weeks the IP address lease from your router has expired, and the IP address the Duet has now is different.
The only way to check this is to either connect by USB terminal to ask the Duet what IP address it currently has and to see if it's otherwise working, or to connect to your wifi router and see if the Duet has connected and what IP address it is using now. This is also the place where you would tell the router to reserve that IP address for the Duet so that it doesn't change in the future. This is called a DHCP reservation, but may have a different name on your router.
Having a working USB connection to the Duet is very useful in cases like this, so I would suggest going through the guide I linked again and seeing if you can get YAT to connect to the Duet. Figuring our how to reserve the IP address in your router would be a good next step.
@Phaedrux I did reserve a IP address in my router for the duet board on my screen when I go under settings it shows that IP address and the screen connects to that router number
@Blunt2007 I will try connecting by USB again I will give you an update in a little bit I got to go to lunch with my mom and dad
@Phaedrux I will try connecting via USB again I will give you an update in a little bit I got to go to lunch with my mom and dad I'll do it when I get back so probably about an hour or so
 @Phaedrux  I tried connecting by USB and it will not connect still I checked my router and it is connecting to the designated IP address that I signed to it to make sure that it was I turned it off checked my router and then turned it on and it came up with the correct IP address connected
@Phaedrux no I am unable to connect by USB still
@Phaedrux no matter what I try I cannot connect to duet Web contro DWC I tried reloading in systems "runonce.g"and I still can't connect I had enough with duet3D it's been 3 months now and I'm still not able to use my 3D printer with duet 3D I tried this board on three different computers and it's not working I want out of duet 3D I want a refund for my monitor and for my board this is so frustrating too bad your product doesn't work for me this project might not be for me because no matter what I do it does not work on none of the computers I have so I want out of duet 3D please refund my money there's nothing I can do about the 3 months that I'd spent trying to get this thing working
Sorry to hear you're still having so many issues. If you'd like to seek a refund please reach out to PrintedSolid to arrange returning the board.
