    tuning LW-PLA
    1.5k
    • nick9one1undefined
      nick9one1
      I've followed a couple of guides to tune the input shaping and pressure advance. . the PA results look like this
      (same part but with light behind)
      The bottom two bands look the best, which are S0.20, and S0.25.
      There is still quite a bulge at the end of the layer. How do I reduce that further?
        What are your retraction settings?
        nick9one1undefined 1 Reply Last reply Reply Quote 0
          nick9one1 @Phaedrux
          @Phaedrux 2.5mm with this filament. Its a very short direct drive extruder.
          I've just tried bumping 'extra length on restart from 0.15 to 0.25 to see if it will reduce the gaps after the layer change.
          This test was from S0.10, and S0.30.
            nick9one1 @nick9one1
            I had a feeling z-hop was compounding the issue so I turned it off, as I dont use it with most filaments.
            This is exactly the same print as my previous post, but 0 z-hop
              2.5mm on a very short direct drive extruder seems like a lot. Try 1mm
              I'd turn off wipe while retracting as well since it can interfere with pressure advance.
              Looks much better without zhop.
              Once you have retraction working better try retuning pressure advance again.
              0.2 and 0.25 is actually quite a lot with a short direct drive. Try something like S0.025 Note the extra zero.
              Please share your config.g so we can see your extruder speed settings.
                nick9one1 @Phaedrux
                @Phaedrux
                thank you.
                ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
                ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Jul 01 2021 17:21:30 GMT+0100 (British Summer Time)
                G90                                              ; send absolute coordinates...
                M83                                              ; ...but relative extruder moves
                M550 P"BLV MGN Cube"                             ; set printer name
                M669 K1                                          ; select CoreXY mode
                M80 C"nil"									     ; ATX PS_ON on
                M552 S1                                          ; enable network
                M586 P0 S1                                       ; enable HTTP
                M586 P1 S1                                       ; enable FTP
                M586 P2 S0                                       ; disable Telnet
                G4 S1   										 ;wait for expansion boards to start
                M569 P0.0 S0 D2                                  ; X motor runs forwards
                M569 P0.1 S1 D2                                  ; Y motor runs forwards
                M569 P0.2 S1 D2                                  ; physical drive 0.2 goes backwards
                M569 P0.3 S1 D2                                  ; physical drive 0.2 goes backwards
                M569 P0.4 S1 D2                                  ; physical drive 0.2 goes backwards
                M569 P121.0 S1 D2                                ; physical drive 121.0 goes backwards
                M584 X0.0 Y0.1 Z0.2:0.3:0.4 E121.0               ; set drive mapping
                M671 X0:290:290 Y155:62:255 S3 		 		     ; leadscrews at rear left, front middle and rear right
                M350 X16 Y16 Z16 I1                              ; configure microstepping with interpolation
                M350 E16 I0                                      ; configure microstepping with interpolation
                M92 X200.00 Y200.00 Z3200.00 E700       	     ; set steps per mm
                M566 X2000.00 Y2000.00 Z150.00 E150.00           ; set maximum instantaneous speed changes (mm/min) (Jerk)
                M203 X30000.00 Y30000.00 Z300.00 E2000.00        ; set maximum speeds (mm/min)
                M201 X9000.00 Y9000.00 Z200.00 E200.00           ; set accelerations (mm/s^2)
                M906 X1400 Y1400 Z900 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
                M84 S30                                          ; Set idle timeout
                ; Pressure advance
                ;M572 D0 S0.30
                M208 X-3:305 Y0:305 Z0.0:500.0  							 ; set axis limits
                M574 X1 S1 P"121.io1.in"                         ; configure active-high endstop for low end on X via pin io0.in
                M574 Y2 S1 P"io6.in"                             ; configure active-high endstop for HIGH end on Y via pin io6.in
                M564 H1											 ; allow jog without homing
                M950 S0 C"^121.io0.out"                          ; create servo pin 0 for BLTouch
                M558 P9 C"^121.io0.in" H3 F120 T10000            ; set Z probe type to bltouch and the dive height + speeds
                G31 P500 X0 Y66 Z2.30                            ; set Z probe trigger value, offset and trigger height (-0.15)
                M557 X-10:293 Y65:300 P8                       	 ; define mesh grid
                M308 S0 P"temp0" Y"thermistor" T100000 B3950     ; configure sensor 0 as thermistor on pin temp0
                M950 H0 C"out0" T0                               ; create bed heater output on out0 and map it to sensor 0
                M307 H0 R0.291 C1127.4 D26.90 S1.00				 ; Set PID for bed values
                M140 H0                                          ; map heated bed to heater 0
                M143 H0 S100                                     ; set temperature limit for heater 0 to 100C
                M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 	; configure sensor 1 as thermistor on pin 121.temp0
                M950 H1 C"121.out0" T1                           			; create nozzle heater output on 121.out0 and map it to sensor 1
                M307 H1 B0 R3.089 C258.2:154.4 D5.95 S1.00 V23.7 			; Set PID for hotend values
                M143 H1 S280                                     			; set temperature limit for heater 1 to 280C
                M950 F0 C"121.out2" Q80                          ; create hotend fan 0 on pin toolboard out1 and set its frequency
                M106 P0 S0 H1 T45 C"Hotend Fan"                  ; set fan 0 value. Thermostatic control is turned on
                M950 F1 C"121.out1" Q250                         ; create cooling fan 1 on pin toolboard out1 and set its frequency
                M106 P1 S0 H-1 B1 C"Part Cooling Fan"            ; set fan 1 value. Thermostatic control is turned off
                M563 P0 D0 H1 F1   					 			 ; define tool 0
                G10 P0 X0 Y0 Z0 								 ; set tool 0 axis offsets
                G10 P0 R0 S0 									 ; set initial tool 0 active and standby temperatures to 0C
                M563 P1 D0 H1 F1 						  		 ; define tool 1
                G10 P1 X0 Y0 Z0 								 ; set tool 1 axis offsets
                G10 P1 R0 S0 									 ; set initial tool 1 active and standby temperatures to 0C
                ; Accel
                M955 P121.0 I10
                ;Input shaping
                ;M593 P"ei3" F90  ; use EI3 input shaping to cancel ringing at 90Hz
                ;M593 P"ei3" F50
                ; Screen
                M575 P1 B57600 S1
                extruder is an nf-sunrise.
                https://3dprintbeginner.com/mellow-nf-sunrise-review/
                  You may want to try altering your extruder settings for speed, jerk, and acceleration as follows and then retuning again.
                  M566 E3000
                  M203 E6000
                  M201 E2000
                  • o_lampeundefined
                    o_lampe
                    Am I assuming correctly, that this LW-PLA is meant to foam up while extruded?
                    That would explain why the long retraction is necessary. It not only oozes out of the nozzle, but also expands.
                    But it only expands once and after a retract/unretract you miss some material.
                    So I guess you're on the right path.
                    Our regular PLA settings won't work here.
                    What does the manufacturer say about settings? They must have testet this stuff before selling it.
                      nick9one1 @o_lampe
                      @o_lampe said in tuning LW-PLA:
                      Yes and no, There are two types of foaming PLA.
                      from the manufacturers website;
                      FAQ
                      What is the difference between active foaming and passive foaming?
                      PolyLite™ LW-PLA is not an active foaming filament, which means it will not foam when extruded from the nozzle depending on the temperature. PolyLite™ LW-PLA is already pre-foamed.
                      What are the pros and cons between active and passive foaming?
                      Active foaming:
                      You need to heavily modify your printing settings depending on the temperature and setup to compensate the foaming expansion of the material when printing.
                      You need to print at very high temperature to achieve light weight results (~250_), these high temperatures will create a lot of defects on the print such as stringing and blobs.
                      At very high temperature, active foaming can achieve lighter print than passive foaming however the print may suffer of serious stringing defects.
                      Passive foaming:
                      You do not need to change any settings from your regular PLA settings (slight increase retraction) as PolyLite™ LW-PLA will offer light weight results even when printing at very low temperature (~190_C).
                      The lower the temperature the higher quality the print.
                        @nick9one1
                        Unfortunately those settings seem to have some undesirable effects;
                        Left is ;
                        M566 E3000
                        M203 E6000
                        M201 E2000
                        Right is;
                        M566 E150
                        M203 E2000
                        M201 E200
                          what were the rest of the settings from that test? PA, retraction, etc?
                            nick9one1 @Phaedrux
                            @Phaedrux
                            I've decided to start from scratch. It's been some time since I've printed anything, so I think a combination of firmware, and slicer updates have broken something.
                            I've reinstalled a fresh copy of prusa slicer, configured a generic printer, with the generic pla profile, with my original start and end gcode. The only thing I changed was retraction from 2mm to 0.4mm.
                            ;Start
                            M104 S[first_layer_temperature] ; set extruder temp
                            M140 S[first_layer_bed_temperature] ; set bed temp
                            M109 S[first_layer_temperature] ; wait for extruder temp
                            M190 S[first_layer_bed_temperature] ; wait for bed temp
                            M557 X{first_layer_print_min[0]}:{first_layer_print_max[0]} Y{first_layer_print_min[1]}:{first_layer_print_max[1]} S20 ; define probe area
                            M98 P"bed.g" ; perform bed leveling
                            G92 E0 ; reset extruder
                            ;End
                            G91 ; Switch to relative mode for the rest of end.g
                            G1 F2000 Z5 ; move bed down
                            G28 XY ; move head to home on XY
                            M104 S0 ; turn off extruder,
                            M140 S0 ; turn off bed,
                            M84 ; disable motors
                            M107 ; turn off part cooling fan
                            M81 S1 ; shutdown after all thermostatic fans have turned off
                            I'm also using standard pla now.
                            This is how a single wall cylinder prints;
                            sebkritikelundefined 1 Reply Last reply Reply Quote 0
                            • sebkritikelundefined
                              sebkritikel @nick9one1
                              @nick9one1 could you upload that exact print file (gcode)? Thanks!
                              Large(ish?) IDEX - 6HC, 1HCL
                              Stratasys Dimension 1200es to 6HC Conversion
                                nick9one1 @sebkritikel
                                @sebkritikel sure, here you go.
                                Shape-Cylinder.gcode
                                  @nick9one1 Thanks! File looks good - no tricks with coasting, no retraction etc.
                                  Off topic perhaps, but why do you have interpolation disabled on the extruder?
                                  Here is something quick I would do to start troubleshooting the extruder (specifically that gap). For now, I think keep pressure advance at 0
                                  1. Do a print, changing the extruder max speed to M203 E6000. Check if there are any changes.
                                  2. If there are NO changes to the print quality, keep the max speed at M203 E6000. Change acceleration from M201 E200 to M201 E3000. I'm going to guess you'll see a physical change to the print once you change the extruder acceleration.
                                  3. Depending on how things are looking, try extruder jerk at M566 E3000 again.
                                  I think we want to eliminate that gap (partly), adjusting extruder jerk/accel, then play around again with PA.
                                  I have some python post-processing scripts that can simultaneously tune things like pressure advance + jerk, etc. Can share them later.
                                    nick9one1
                                    @sebkritikel
                                    Thanks, Things are looking a little better...
                                    I found a config.g for my printer here https://github.com/FYSETC/FYSETC-BLV-MGN-CUBE/blob/main/Firmware/config3.x/sys/config.g although I think that version uses a V6 clone.
                                    After updating my config.g with those settings my print is looking a little better.
                                    config.g
                                    This is printed with the above config.
                                    The first 10 layers are normal, after later 10 I sent M203 E6000 in the console while it was printing. Then after another 10 I sent M201 E3000, then after another 10 I sent M566 E3000.
                                    I can't really see any discernible change in the print.
                                    this is the cylinder gcode. Shape-Cylinder (1).gcode
                                    nick9one1undefined sebkritikelundefined 2 Replies Last reply Reply Quote 1
                                      @nick9one1
                                      I also came across this that may help. This is my exact printer and extruder (although volcano), with settings for klipper.
                                      https://www.blvprojects.com/post/klipper-ultra-fast-printing-9000acc-500mm-s
                                        @nick9one1 Cool! So looking at the new config.g, I see a few changes.
                                        • M566 changes, jerk was reduced for X, Y, Z, and increased slightly for E. I would go back and increase the Z jerk, as a low Z jerk can cause issues with X-Y travel moves (stuttering) if you use mesh bed compensation.
                                        • Max speeds were reduced for X and Y, increased for Z
                                        • Acceleration was reduced for X, Y, and Z, increased for E
                                        I've found that with higher acceleration values for X and Y, I have to change pressure advance settings. Based on your before/after print after your new config.g, I think the reduction in X and Y acceleration has 'improved' the seam.
                                        My suggested config.g changes:
                                        M566 X600.00 Y600.00 Z150.00 E3000.00              ; set maximum instantaneous speed changes (mm/min) - increased Z and E
                                        M203 X20000.00 Y20000.00 Z2000.00 E6000.00       ; set maximum speeds (mm/min) - increased E
                                        I would also see if you're happy with the Z acceleration value (your new 100 vs old 200. probably too small to notice or care).
                                        I think once you make the above changes, you can then start tweaking pressure advance settings. Here is the same print file from above, but I varied PA from (Starting with whatever your default is for the first 10% of the file) .001 to .35.
                                        pa-shape-cylinder.gcode
                                        You can try out the file python file here, change your file name/location as needed.PS pa.py
                                        import re
                                        min_pressure_advance = 0.001  # set minimum pressure advance
                                        max_pressure_advance = 0.35  # set maximum pressure advance
                                        no_tune_pct = 10  # set the percentage of layers to not tune
                                        input_filename = r"C:\Users\Jared\Downloads\1704556218097-shape-cylinder.gcode"
                                        output_filename = r"C:\Users\Jared\Desktop\pa_1704556218097-shape-cylinder.gcode"
                                        # read the input file
                                        with open(input_filename, 'r') as f:
                                            in_gcode = f.readlines()
                                        max_print_height = 0
                                        for line in in_gcode:
                                            match = re.match(r';Z:(\d+(\.\d+)?)', line)
                                            if match:
                                                current_height = float(match.group(1))
                                                max_print_height = max(max_print_height, current_height)
                                        # calculate the pressure advance range and increment
                                        pressure_advance_range = max_pressure_advance - min_pressure_advance
                                        pressure_advance_increment = pressure_advance_range / (max_print_height - max_print_height * no_tune_pct / 100)
                                        # iterate through the input file and modify pressure advance as needed
                                        out_gcode = []
                                        current_print_height = 0
                                        for line_num, line in enumerate(in_gcode):
                                            # check if this is a Z comment indicating the current layer height
                                            if line.startswith(';Z:'):
                                                current_print_height = float(line.split(':')[1])
                                                # check if we should tune this layer based on print height
                                                if current_print_height > max_print_height * no_tune_pct / 100:
                                                    # calculate the pressure advance for this layer based on print height
                                                    pressure_advance = min_pressure_advance + (current_print_height - max_print_height * no_tune_pct / 100) * pressure_advance_increment
                                                    # replace the Z comment with a modified one that includes the pressure advance command
                                                    out_gcode.append(f";Z:{current_print_height:.3f}\nM572 D0 S{pressure_advance:.3f}\nM572\n")
                                                else:
                                                    out_gcode.append(line)
                                            else:
                                        # write the modified file to disk
                                        with open(output_filename, 'w') as f:
                                            f.writelines(out_gcode)
                                          @sebkritikel
                                          Thanks again. I';ve made the changes you suggested.
                                          I'm still seeing small gaps after de-retraction, It's not quite so obvious without a light source behind the image;
                                          I did a test here; the top trint is with your latest suggestions. And the the descond print has 0.5mm extra length on deretraction. That's quite a lot, but visually I can barely tell any difference.
                                          Another image even closer, seems to show the layer change looking ok. The gaps happen after the de-retraction and when it starts to print the new layer?
                                          o_lampeundefined sebkritikelundefined 2 Replies Last reply Reply Quote 0
                                          • o_lampeundefined
                                            o_lampe @nick9one1
                                            @nick9one1 Stupid question, but did you check the grubscrew of the extruder shaft? A loose screw would explain the bulge and gap.
                                            nick9one1undefined 1 Reply Last reply Reply Quote 1
