    Hi my fans dont work i cant find answer ho to run them
    267
    • bartekpundefined
      bartekp
      HI my fans dont start on print iwen when maschine not run when hotend is hot i checked the fans they are ok and wires wer to look up ?
      M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
        Can you send M122 and M98 P"config.g" and share the results?
        Can you show how you have the fans connected?
        How did you test the fans to know they are working?
        Fan0 should be gcode controllable, or with the slider in DWC, and Fan1 and Fan2 should turn on when heater1 is above 45c based on your config snip.
        bartekpundefined 1 Reply Last reply Reply Quote 0
        • bartekpundefined
          bartekp @Phaedrux
          @Phaedrux said in Hi my fans dont work i cant find answer ho to run them:
          M98 P
          M122 connection lost
          M98 P
          M98 P"config.g"
          Warning: Heater 1 predicted maximum temperature at full power is 822°C
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          bartekpundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • bartekpundefined
            bartekp @bartekp
            @bartekp ![alt text](Zrzut ekranu 2024-03-03 200641.png image url)
            I cchecked with external power source that they work , connection is ok the first connection from top on image is hotend
              jay_s_uk @bartekp
              @bartekp check the fan fuse
                Phaedrux Moderator @bartekp
                @bartekp said in Hi my fans dont work i cant find answer ho to run them:
                I think you might have sent M112 instead of M122?
                • bartekpundefined
                  bartekp @Phaedrux
                  @Phaedrux m122 corect looks like m112 both do the same
                  Exerqtorundefined 1 Reply Last reply Reply Quote 0
                  • Exerqtorundefined
                    Exerqtor @bartekp
                    @bartekp no they aren't supposed to:
                    M112
                    M122
                    Edit: Worded the sentence badly.
                    • gloomyandyundefined
                      gloomyandy @Exerqtor
                      @Exerqtor Well perhaps more accurately they shouldn't.
                      @bartekp If you are sure that running M122 (not M112) causes a connection lost, then you need to look into that more fully. So for instance: What connection is being lost here? How are yin running M122? Is it via the DWC console, a USB terminal, a panelDue?
                      bartekpundefined 1 Reply Last reply Reply Quote 1
                      • bartekpundefined
                        bartekp @gloomyandy
                        @gloomyandy via DWC fun running solved
                        • dc42undefined dc42 marked this topic as a question
