    Text input boxes
    Duet Web Control wishlist
    13
    17
    1487
    • mchiriciuc
      mchiriciuc last edited by
      I often found myself trying to set exact values for Extrusion Factors and Speed Factor using the sliders and not being able to set it from the first try.
      I would love to have a text box for both controls where I could input the value needed and just press enter.
      Thank you,
      Mircea
      • deckingman
        deckingman last edited by
        You can enter M220nnn and M221nnn from the Console if it helps. https://duet3d.com/wiki/G-code#M220:_Set_speed_factor_override_percentage
        • mchiriciuc
          Thnak you Ian, I know that. That's what I'm using right now.
          • hayseed_byte
            hayseed_byte last edited by
            @mchiriciuc:
            Thank you,
            Mircea
            Seconded. Sliders seem like a terribly imprecise way to control something with as fine tolerances as a 3d printer.
            https://wildbot.me/wildbot
            Gcode Definitions for VSCode extension: https://github.com/hayseedbyte/rrf-gcode-definitions
            • kingfisher
              kingfisher last edited by
              I've accidentally moved the siders when viewing progress on my phone in the past. A text box would prevent this and improve precision.
              • totalitarian
                totalitarian last edited by
                @kingfisher:
                Me too, very frustrating
                • fma
                  fma last edited by
                  Maybe a SpinBox? You can set the value with the keyboard and still change it with mouse. Maybe less easy with touchscreen, though.
                  Frédéric
                  • dintid
                    dintid last edited by
                    @mchiriciuc:
                    Thank you,
                    Mircea
                    I would love this too. Same for fan speed etc. Maybe a checkbox somewhere, where users can enable/disable text and slider input, and even have both options available.
                    RepRapFirmware supported G-codes: https://duet3d.com/wiki/G-code
                    • hayseed_byte
                      Anyone working on an alternative? The sliders really are super annoying. 😄
                      • Lakko
                        Lakko last edited by
                        On the smartphone, I always inadvertently move the fan slider
                        • DjDemonD
                          DjDemonD last edited by
                          +1 for dumping the sliders and replacing them with something else easier to use.
                          www.precisionpiezo.co.uk
                          • swoozle
                            swoozle last edited by
                            Another vote for text boxes and +/- buttons so you can quickly change the setting in a fine-grained manner without having to keyboard.
                            And for fan controls too, please.
                            I do also like the sliders, though.
                            • DADIY
                              DADIY last edited by
                              It would be nice if the slider would snap to some of the values, for example returning the slider back to 100 is quite tricky, if it would snap to 100 that would help a lot.
                              • whosrdaddy
                                whosrdaddy last edited by
                                @DADIY:
                                I would be happy to see the sliders go and be replaced with editbox/spinner combination. On a mobile device, it is impossible to accurately control the sliders!
                                • hayseed_byte
                                  I'm guessing this isn't going to happen. It's hard for me to imagine anyone prefers sliders over text boxes. I don't know anything about developing software but surely we're not asking for the impossible here. Sliders for fan speed, fine. But for speed and extrusion? Definitely need something more precise.
                                  • chrishamm
                                    chrishamm administrators last edited by
                                    This is actually one of the next items left on my TODO list, so you can expect it fairly soon. I would have delayed this a bit longer since I've been planning an upgrade to another HTML framework but because several other people would like to get this feature I will try to implement it by the end of next week.
                                    Duet software engineer
                                    • hayseed_byte
                                      Wow...thanks. No need to rush, though. It's enough to know it's on the list.
