    shutting down a servo?
    581
    • Tinchusundefined
      Tinchus
      Hi. I have a small servo connected to a duet3 (3.4.6, SBC mode, the servo open and close a smal lid, it is a 9g style servo, specifications are ok for the duet3 board)
      The servo is connected to its own 5V PSU (it uses 6.5 V ), just to avoid any potential problem of stall current or related things.
      Configuration on config.g:
      M950 S0 C"io5.out" Q285
      M280 P0 S1380
      The servo is a futaba SU-300. Acording to their tech support since it is a digital servo, the pwm frequenncy should be 285 and so I configured that on the M950 command
      The M280 P0 S1380 moves the servo ok in one direction,, M280 P0 S1450 moves it on the other direction.
      The problem is (may be it is not a problem jajajajaj): when I move the servo to M280 P0 S1450, the servo moves and then when it stops keeps doing a buzzing noise (small noise). Im guessiing, just guessing since electronics are not my field, that the noise comes is the servo trying to keep the position or maybe the servo is stall and trying to reach final position?
      To test this following the instructions here: https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_servos, on the stall current section says:
      Servos that are commanded beyond their movement limits usually stall. This heats up both the servo and the Duet. The servo is likely to burn out if held in this state. So:
      Ensure that the Duet can supply the stall current. >>>> not my problem because Im using an independant power source for the servo?
      Either be very careful not to command the servo beyond its working range, or else command the servo to move, hold it for a short time, then use M280 P# S0 to stop commanding the servo (replace # by the pin number or GpOut number as usual).
      I used the command M280 P0 S0 and the noise is still there, and the servo is still being commanded because if I try to move it I can feel the servo applying torque and keeping its position
      Should the command M280 P0 S0 do this I mean "turn off" the servo"
      Thanks in advance for the help
      droftartsundefined zaptaundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @Tinchus
        @Tinchus sending M42 P0 S0 should turn off the servo. M280 P0 S0 means 'set servo angle to 0 degrees', which often servos aren't capable of reaching, and maybe drawing a lot of current.
        Tinchusundefined 1 Reply Last reply Reply Quote 0
        • Tinchusundefined
          Tinchus @droftarts
          @droftarts that was my understanding, yes. But as I posted above, reading the documentation again on the link provided, says "then use M280 P# S0 to stop commanding the servo"
          To my understanding stop commanding meand stop sending command signal or something similar. An as stated on the documentation, that comand is an option in the case where the servo is may be neing prevented from reaching position, so the servo will start to draw a lot fo current. To avoid taht we can command the movement , and then send M280 P# S0.
          Then the information on docuemntation might need to be updated/corrected?
          Going back to my problem: any idea on how can I shut down the servo?
            @Tinchus The documentation is wrong, and I have updated it: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_servos#stall-current
            As I said before, M42 P0 S0 stops the servo. It sets the PWM on the servo control pin to zero. M280 always sets a PWM signal, so there's no way to turn the servo 'off' with M280. See the M280 notes here: https://docs.duet3d.com/User_manual/Reference/Gcodes#m280-set-servo-position
            • Tinchusundefined
              Tinchus @droftarts
              @droftarts Sorry, I missread. You meant M42 and I read M280 jajaja. Sorry again.
              I intentionally moved the servo to a position that I know will create a stall situation. I can hear the buzzing sound on the servo. Then I executed M42 P0 S0, and the sound is still there and it is not possible to move the servo by hand, it is definitely having power and trying to reach the commanded position, so the M42 command seems to not have the effect Im looking for?
              jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @Tinchus
                @Tinchus the servo will always have power unless you switch that power off. you would need a relay to do so
                  @Tinchus Strange, it works for me, I've just tested it. I sent:
                  M280 P0 S100 > servo moves to 100 degrees
                  M42 P0 S0 > servo 'turns off', can be moved manually
                  M280 P0 S10 > servo moves to 10 degrees
                  M280 P0 S5 > servo tries to move to 5 degrees, but stalls, with noise
                  M42 P0 S0 > servo 'turns off', noise stops, can be moved manually
                  My servo is a Hitec HS-70MG 12.5g.
                  Tinchusundefined 1 Reply Last reply Reply Quote 1
                  • Tinchusundefined
                    Tinchus @jay_s_uk
                    @jay_s_uk ok. My intentio is not to cut the power" but to achieve what in the documentatios is refered as away to avoid having the servo in a stall situation.
                    lets forget about the noise, if I execute m42 P0 S0 even if I have the noise I can trust no control signal is being sent to the servo?
                    • Tinchusundefined
                      Tinchus @droftarts
                      @droftarts I remember having tried that servo, I changed it just becauso of it torque (the futaba one is almost double). And the other important differentce is that your servo is analog, mine is digital
                        @Tinchus I think if you still hear noise, it's still trying to get to position, so still stalling. If M42 isn't working, maybe digital servos need a different mechanism to turn off. I've asked @dc42. Is there any information on this in the futaba SU-300 data sheet?
                        • o_lampeundefined
                          o_lampe
                          A humming servo is a regular thing, when it doesn't reach the desired angle.
                          It happens, even when the servo arm is within the boundaries of the internal gears, but it's no problem then. (unless your setup requires too much torque)
                          You could try one thing, for peace of mind:
                          • command the servo 5 degree or microsecond past the point you want to reach (whichever you prefer)
                          • wait a little while for the arm to reach the position (eg. G4 P200 ; waits 200milliseconds)
                          • move 5 back
                          With that trick, you'll overcome the backlash of the internal potmeter and it will be quiet
                          Maybe have to adapt to different angles/microseconds for your specific servo
                          • zaptaundefined
                            zapta @Tinchus
                            @Tinchus, I have a non Duet project where a servo needs to be quiet between moves and I solved it by stopping the signal to the servo (PWM output stays at zero volts) instead of pulsating. Potentially you can do the same with the Duet. E.g. by reconfiguring the IO point.
                            • achrnundefined
                              achrn
                              @Tinchus your problems might be your choice of servo.
                              Futaba SU300 is a digital servo. It doesn't want to see PWM, it wants to see SBUS, which is serial data, 25 byte packets, at 100,000 baud, and the polarity is inverted.
                              I think that if it doesn't get SBUS, it 'falls back' to looking for 'normal' servo PWM, which is why it works at all.
                              I suspect (but this is speculation) that M42 doesn't work as expected because when the servo doesn't see either SBUS or PWM it holds position. Possibly you can program what it does in that situation if you put it on a programmer (you want a CIU-3 programmer, I believe), but that's about 50 quid. I'd buy a 'normal' PWM servo instead.
                              Alternatively, there's a reasonably straightforward SBUS arduino library by Bolder Flight Systems - possibly you could lash together something where your Duet talks to an arduino and the arduino talks to the servo. Still, I'd buy a 'normal' PWM servo instead.
                              Tinchusundefined 1 Reply Last reply Reply Quote 2
                              • Tinchusundefined
                                Tinchus @achrn
                                @achrn I think you nare oin the righht truck. I was suspecting something about this and ttalking to futaba support about it. I will try to get a non pwm servo, any recommendations about it?
                                  @Tinchus You may be able to get the Duet to send the correct SBUS commands, similar to how @DonStauffer did it with the NeoDriver LED board: https://forum.duet3d.com/topic/35384/neopixel-driver-results
