    6XD I/O >> Issue solved
    5.4k
    • tecnoundefined
      tecno @droftarts
      @droftarts
      Hi Ian,
      @droftarts said in 6XD I/O >> Faulty Driver 5:
      Or is it that you want to display their status in DWC
      No I just wanted to know if the outputs work, and OUT 2 is NOT ( 0 and 1 works)
      Yet another output not working
      Cheers
      Bengt
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @tecno
        @droftarts
        Top is P1 bottom is P2
          droftarts administrators @tecno
          @tecno Can you post your whole config.g as it currently is, please. Also run M98 P"config.g" from the console and post the response.
          • tecnoundefined
            tecno @droftarts
            M98 P"config.g"
            config240923.txt
              @tecno You've set out2 as a fan!
              M950 F2 C"out2" ;	Q500	;Drag PIN Actuator
              Changle "F2" to "P2".
              • tecnoundefined
                tecno @droftarts
                @droftarts
                Corrected
                ;***Outputs
                M950 P0 C"out0" ; Q500 ;#1 Nozzle Vacuum
                M950 P1 C"out1" ; Q500 ;#2 Nozzle Vacuum
                M950 P2 C"out2" ; Q500 ;Drag PIN Actuator
                M950 P3 C"out3" ; Q500 ;ENA Nozzle 1/2 Up
                M950 P4 C"out4" ; Q500 ;Xross cursor
                M950 P5 C"out5" ; Q500 ;LED light
                M950 P6 C"out6" ; Q500 ;Vacuum power
                  @tecno Did you reset or run config.g before running the macro again?
                  • tecnoundefined
                    tecno @droftarts
                    @droftarts
                    Yes
                      @tecno Please post the macro.
                      • tecnoundefined
                        tecno @droftarts
                        @droftarts
                        M42 P2 S1
                        echo state.gpOut[1].pwm
                        M42 P2 S0.5
                        M42 P2 S0
                          @tecno said in 6XD I/O >> Faulty Driver 5:
                          Wrong pin. Use:
                          echo state.gpOut[2].pwm
                          • tecnoundefined
                            tecno @droftarts
                            @droftarts
                            2024-09-23 13:52:19 M98 P"0:/macros/TEST"
                            1.000
                            0.500
                            0.000
                            Still DEAD output
                              Still DEAD output
                              How are you measuring that?
                              • tecnoundefined
                                tecno @droftarts
                                @droftarts
                                Now suddenly the OUT2 works, so go figure what is going on. Cold soldering seems far away but could be.
                                Been take out plugs and inserted them testing.
                                Whole day yesterday I did not see the LED light up but OUT1 and OUT0 was working.
                                So DRIVER5 is still an issue here.
                                • tecnoundefined
                                  tecno @tecno
                                  @dc42 @droftarts
                                  Driver 5 is still DEAD !! How do you want to solve this?
                                  Cheers
                                  Bengt
                                    @tecno Can you post a good picture of both sides of the board, please. There's so very little to go wrong with these ports, I feel like it's something obvious. Did you check it with a multimeter, like I asked you to?
                                    out2 is still working correctly? Does the LED come on when active?
                                    Also, please send M586 and post the response, to see what network protocols are enabled, because your config doesn't have any set.
                                    • tecnoundefined
                                      tecno @droftarts
                                      @droftarts
                                      Hi Ian,
                                      Re multimeter = no as you can see it is not so accessible in the video. Later on today.
                                      https://photos.app.goo.gl/L56Zn79kaww26Q4U6
                                      out2 is OK
                                      2024-09-25 09:26:27 m586
                                      CORS disabled
                                      HTTP is enabled on port 80
                                      FTP is disabled
                                      TELNET is disabled
                                      Multicast Discovery is disabled
                                      MQTT is disabled
                                      Cheers
                                      Bengt
                                      • tecnoundefined
                                        tecno @tecno
                                        Pictures of 6XD board https://photos.app.goo.gl/6ME2iY7CesXBjeKPA
                                          @tecno Were you able to do any tests with a multimeter? I can't see anything obvious from the pictures.
                                          • tecnoundefined
                                            tecno @droftarts
                                            @droftarts
                                            Pls repeate exactly what you want me to measure now that the board is in the open.
