    6XD I/O >> Issue solved
    5.3k
    • tecnoundefined
      tecno @droftarts
      @droftarts
      https://vi.aliexpress.com/item/1005002313192735.html?spm=a2g0o.order_list.order_list_main.11.364b1802NFG3VP&gatewayAdapt=glo2vnm
      Both white and ´blach PCB 8 LEDS
      Wiring https://forum.duet3d.com/post/345489
      gloomyandyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @tecno
        @tecno Shouldn't the control signal be going to d0 and not to d1?
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @gloomyandy
          @gloomyandy
          As I understand is 6XD D0 out goes to Di in.
            droftarts administrators @tecno
            @tecno Those do look like RGB LEDs, looking closer. Though they should light up, just with the wrong colours, if you put the wrong T parameter in M950.
            I thought you said you had changed the wire over? @tecno said in 6XD I/O >> Issue solved:
            Change White to shield.
            On each LED, there is a corner 'notch' to indicate which pin is GND. Can you check continuity of GND, DI and 5V from the LED pins to the connector?
            @gloomyandy It's DI for Digital In, DO is Digital Out, where it passes the signal on to the next one. Mine are labelled and wired like that.
              gloomyandy @tecno
              @tecno This has nothing to do with the 6XD I'm talking about the pads on the LED ring, there is a D0 and a D1. Your wiring here: https://forum.duet3d.com/post/345489 shows it going to D1 I think it should go to D0. It seems very odd to me to have the input labelled D1 and the output labelled D0.
                gloomyandy @gloomyandy
                Ah yes that may be Din and Dout I suppose. Oh well good luck!
                • tecnoundefined
                  tecno @gloomyandy
                  @droftarts
                  So now I changed White to signal and Shield is now 5V
                  So now we are getting closer 🙂
                    @tecno Okay, so now use:
                    M950 E0 C"led" Q3000000 T1
                    ie change T2 to T1
                    I expect that bare 'earth' wire had too much capacitance to transmit the signal. Now you're using the bare wire for 5V, so easier to create a short. Same goes for using that wire for GND. I'd replace the wiring with individually insulated wires, ie 3-core wire. If you don't have 3-core wire, use left-over stepper motor wire, that's about the right gauge for LEDs.
                    • tecnoundefined
                      tecno @droftarts
                      @droftarts
                      Works in R255 and P can be set = Nice.
                      Now to play with new colors
                        @tecno Do all 8 LEDs work now, and are controllable?
                        RGB LEDs aren't the best for white light. You'll have to play around with the levels in M150 for R, U (for green) and B, and brightness (P) to get close to what you want. If it's mostly white you want, you probably should have got RGBW, or just white, LEDs.
                        • tecnoundefined
                          tecno @droftarts
                          @droftarts
                          Yes all 8 work
                          I am aware that I can not get perfect greyscale with RGB. Hard to find 8leds RGBW that fits.
                          Thank you very much for your kind help Ian, I owe you a pint or two 🙂
                          I am sure more questions will arise
                          Cheers
                          Bengt
                          • tecnoundefined
                            tecno @tecno
                            • tecnoundefined
                              tecno @tecno
                              @droftarts
                              ;***Outputs
                              M950 P0 C"out0" ; Q500 ;#1 Nozzle Vacuum
                              M950 P1 C"out1" ; Q500 ;#2 Nozzle Vacuum
                              M950 P2 C"out2" ; Q500 ;Drag PIN Actuator
                              M950 P3 C"out3" ; Q500 ;ENA Nozzle 1/2 Up
                              M950 P4 C"out4" ; Q500 ;Xross cursor
                              M950 P5 C"out5" ; Q500 ;LED light x
                              M950 P6 C"out6" ; Q500 ;Vacuum power
                              Have problem with Outputs 4 and 5. can not switch off. Any advice is appreciated-
                              Off=1.4V On=1.3V all other Off 24V On 0V
                              tecnoundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                              • tecnoundefined
                                tecno @tecno
                                @droftarts
                                Is this something we can get working?
                                There is a cable with RX/TX/GND for the old controller. Two chips for vacuum measurement.
                                Cheers
                                Bengt
                                  Was this working before? Have you fixed it? Sounds more like a wiring problem.
                                  What chip is it? You need to find out what signal it outputs, and what signal it expects. If it outputs an analog signal of 0-3.3V, you can probably set it up as an analogue sensor, or a digital sensor if it outputs an on/off signal.
                                  • tecnoundefined
                                    tecno @droftarts
                                    @droftarts
                                    Hello Ian,
                                    These two worked OK with original controller, never got them working with 6XD.
                                    Wires have been checked, but I have to measure continiuity once moore on out 4 and 5.
                                    Have to dismanlte the board and see what is on it.
                                    Bengt
                                      @tecno As they are both LEDs, are you supplying the 24V to the correct side of the LED? If not, the LEDs act as a diode, and don't let the power through.
                                      • tecnoundefined
                                        tecno @droftarts
                                        @droftarts
                                        Cable is OK
                                        Original connected to PSU, 12V for Cross and 5V for LED Light
                                        • tecnoundefined
                                          tecno @tecno
                                          @droftarts
                                          Only way to turn outputs OFF is to remove cables
                                          • tecnoundefined
                                            tecno @tecno
                                            @droftarts
                                            Here pics of vacuum sensors = no labels
                                            tecnoundefined 2 Replies Last reply Reply Quote 0
