randomly reconnect of DWC on Duet2 Ethernet
after upgrade from 3.4.5 to 3.5.2 I observed a frequently reconnect of DWC when a message is shown on printer display (Paneldue 7i) e.g. leadscrew adjustment after homing or extruder not driven because of cold extrusion.
After upgrade to 3.5.3 I observe the same behavior. It is a Duet2 Ethernet with Duex5.
My second printer with Duet2 Ethernet and Duex2 is still on RRF 3.4.5 without this behavior. -
Your image is too small to make out any of the text.
you are right, I uploaded a new one.
Does this happen immediately after powering on?
Please share your config.g and the results of sending M122 and M98 P"config.g" in the gcode console.
@Phaedrux
No this only happens when a message on printer display is shown (see first post).
I searched the forum and found https://forum.duet3d.com/topic/36277/many-problems-with-3-5-2/18?_=1727095288513
for me it is the same issue.
