    optimize input shaping in the other direction
    Using Duet Controllers
    1.2k
    • axiomundefined
      axiom @jay_s_uk
      @jay_s_uk
      It is the newest 3.5.4 on a duet 2 wifi board, the acelerator is a duet v 0.2
      axiomundefined 1 Reply Last reply Reply Quote 0
      • axiomundefined
        axiom @jay_s_uk
        @jay_s_uk sorry, i ve postet the wrong screenshot, here ist the right one:
        • axiomundefined
          axiom @axiom
          @axiom and here with shaper effect:
          jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @axiom
            @axiom I would suggest not worrying about input shaping in 3.5. it's been rewritten in 3.6 and performs a million times better than on 3.5.
            You could always try giving 3.6b2 a whirl or wait for 3.6b3
              dc42 administrators @axiom
              @axiom change the shaper type to ZVDD or ZVDD or EI2 or EI3 and set the centre frequency between the two peaks.
              • axiomundefined
                axiom @dc42
                @dc42 That's interesting, and how can I write that into the config?
                engikeneerundefined 1 Reply Last reply Reply Quote 0
                • engikeneerundefined
                  engikeneer @axiom
                  @axiom
                  M593 P"zvd" F49.4
                  Becomes
                  M593 P"zvdd" F49.4
                  Or
                  M593 P"ei2" F49.4
                  Or whatever else. Its really that simple. As DC42 says, you may want to tweak the centre frequency (F parameter) so that it better covers both of your peaks.
                  Basically those other shapers have a wider frequency range than ZVD. You'll see that using the shaper tool when you switch between them!
                  i3 clone with a bunch of mods
                  axiomundefined 1 Reply Last reply Reply Quote 1
                  • axiomundefined
                    axiom @engikeneer
                    @engikeneer Thank you very much, but how do I enter the second frequency?
                      engikeneer @axiom
                      @axiom you don't. The shapers cover a frequency range, so if you pick one that covers a wider range and set it to be in the middle of the two frequencies, it should help both. You can't input shape different axes with different frequencies
                      In the second image you posted, you can see frequency range the ZVD shaper is filtering as a green dashed line. Play with the others in the plugin and see what works.
                      • axiomundefined
                        axiom @engikeneer
                        @engikeneer thank you very much, then I will just print a few tests
