    Run out of inputs on Duet 3 Mini 5+
    • fcwiltundefined
      fcwilt
      I have run out of inputs on a couple of machines using Duet 3 Mini 5+ boards.
      I only need to monitor a very few dry contact closures.
      Any thoughts?
      Thanks much.
      jay_s_ukundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @fcwilt
        @fcwilt use an Arduino and talk to the board over UART?
        • T3P3Tonyundefined
          T3P3Tony administrators @fcwilt
          @fcwilt one option is to use a SAMMYC21 development board over CAN.
          how many more IOs do you need?
          www.duet3d.com
          gloomyandyundefined achrnundefined fcwiltundefined 3 Replies Last reply Reply Quote 1
          • gloomyandyundefined
            gloomyandy @T3P3Tony
            @T3P3Tony If you have analogue inputs free (or can free one up), you may be able to create a set of switches with some sort of resistor ladder that allows you to identify which switch is open/closed. How easy it would be to do this will depend on if more than one switch can be "active" at once.
            • achrnundefined
              achrn @T3P3Tony
              @T3P3Tony said in Run out of inputs on Duet 3 Mini 5+:
              I note the chip45 link on https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Using_the_Sammy-C21_development_board_with_Duet_3 is broken - it should now be https://www.chip45.com/Microcontroller-Modules-Boards/Sammy-C21-ATSAM-Duet3D::4.html
              • T3P3Tonyundefined
                T3P3Tony administrators @achrn
                @achrn thanks, fixed
                www.duet3d.com
                • fcwiltundefined
                  fcwilt @T3P3Tony
                  @T3P3Tony
                  Thanks for the feedback.
                  I was not aware of that device. It looks like a fine solution.
                  • DIY-O-Sphereundefined DIY-O-Sphere referenced this topic
