    New XZmotors problem
    278
    • aceranicundefined
      aceranic
      Duet 2 WiFi board, I changed XZ motors, CoreXZ printer, and started having issues with X movement staggering at higher speeds.
      Video of the problem below.
      It is not slicer related as it is happening in every X movement regardless if printing or just moving.
      https://youtube.com/shorts/qQqe81Eq0bg?si=B1n078K_Gy-EgicX
        jay_s_uk @aceranic
        @aceranic post your config
        aceranicundefined 1 Reply Last reply Reply Quote 0
        • aceranicundefined
          aceranic @jay_s_uk
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Dec 06 2021 21:58:20 GMT+0100 (Central European Standard Time)
          M550 P"TazmanSW" ; set printer name
          M669 K2 X1:0:1 Y0:1:0 Z1:0:-1 ; select CoreXZ mode
          M552 S0 ; enable network
          M586 P0 S1 ; enable HTTP
          M587 P192.128.68.68 ; connect to access point "Network-ssid-123" using WPA2-PSK authentication at specified IP address
          M552 S1
          M586 P1 S0 ; enable FTP
          M586 P2 S0 ; enable Telnet
          M569 P0 S0 ; physical drive 0 goes forwards
          M569 P1 S0 ; physical drive 1 goes forwards
          M569 P2 S0 ; physical drive 2 goes forwards
          M569 P3 S1 ; physical drive 3 goes backwards Extruder
          M584 X0 Y2 Z1 E3 ; set drive mapping
          ;M350 X16 I0 ; configure microstepping without interpolation
          M92 X80.00 Y80.00 Z80.00 E562.00 ; set steps per mm
          M566 X150.00 Y150.00 Z150.00 E240.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X30000.00 Y30000.00 Z30000.00 E10000.00 ; set maximum speeds (mm/min)
          M201 X900.00 Y900.00 Z900.00 E3500.00 ; set accelerations (mm/s^2)
          M906 X1200 Y1200 Z1200 E1200 I0 ; set motor currents (mA) and motor idle factor in per cent
          M84 S2 ; Set idle timeout
          M208 X372 Y380 Z315 S0 ; set axis maxima
          M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop
          M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop
          ;M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !zstop
          M574 Z1 S2 ; configure Z-probe endstop for low end on Z
          M558 P9 C"^zprobe.in" H10 F1200:420 T6000 ; set Z probe type to bltouch and the dive height + speeds
          ;G31 P25 X-30 Y-15 Z2.90 ; set Z probe trigger value, offset and trigger height
          M557 X50:370 Y50:380 S50 ; define mesh grid
          M280 P0 S160 I1 ; Probe reset
          M143 H0 S120 ; set temperature limit for heater 0 to 100C
          M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to s ensor 1
          M307 H1 B0 S0.75 ; disable bang-bang mode for heater and set PWM limit
          M143 H1 S280 ; set temperature limit for heater 1 to 250C
          M950 F0 C"fan0" Q255 ; create fan 0 on pin fan0 and set its frequency
          M950 F1 C"fan1" Q150 ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T55 ; set fan 1 value. Thermostatic control is turned on
          M563 P0 D0 H1 F0 S"Mosquito" ; define tool 0
          ;G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
          M563 P1 D0 H1 F0
          G10 P1 R0 S0
          M563 P2 D0 H1 F0
          G10 P2 R0 S0
          M563 P3 D0 H1 F0
          G10 P3 R0 S0
          ; Custom settings
          ;M572 D0 S0.3
          M564 H0
          M501
          M302 P1
          M950 P1 C"exp.heater4" ; allocate GPIO port1 to heater4 on expansion connector, 500Hz
          ;M955 P0 C"spi.cs4+spi.cs3" ; all wires connected to temp DB connector, no temperature daughterboard
          M593 P"zvdd" F56 ; use ZVD input shaping to cancel ringing at 40.5Hz
          M98 P"load_variables.g" ; Runs the macro in the file load_variables.g
          • aceranicundefined
            aceranic @aceranic
            @aceranic I had to change direction as I was getting Phase warnings....
            Also I have 2 motors on Y axis, connected to 2 Z axis drivers.
              jay_s_uk @aceranic
              @aceranic it could be a result of the fairly low jerk (M556) settings you have.
              Your acceleration settings are also very low (M201)
              • aceranicundefined
                aceranic @jay_s_uk
                @jay_s_uk Ok, I didnt have such issue before with same settings. They are set higher is slicer.
                • aceranicundefined
                  aceranic @aceranic
                  Increased current and accwl, jerk, still the same.
                  • aceranicundefined
                    aceranic @aceranic
                    Incresed all values but still no luckScreenshot_20250312_164054_Samsung Internet.jpg
                      jay_s_uk @aceranic
                      @aceranic i guess its mechanical issue
                      • aceranicundefined
                        aceranic @jay_s_uk
                        @jay_s_uk Not sure still. After board restart it was moving fine few times full X travel. Then I started the print and same issue again.
                        I tried one older print large size, same.
                          Are you using mesh compensation? Can you try disabling it if you are?
                          • aceranicundefined
                            aceranic @Phaedrux
                            @Phaedrux Hi. Will try. Only thing I didnt try yet.
                            • aceranicundefined
                              aceranic @aceranic
                              Yep. It seems that 25mm grid was too much to chew. Thanks!!!!
                              By the way Phaedrux, I ordered BTT extension for 3 drivers for my MMU. Will need help with that 😁
                                droftarts administrators @aceranic
                                @aceranic said in New XZmotors problem:
                                If it's this board https://github.com/bigtreetech/BTT-Expansion-module/blob/master/BTT EXP-MOT/BTT EXP-MOT V1.0User Guide.pdf then I think you can only use two of the drivers with Duet 2 WiFi, as it has to be connected in STEP/DIR mode, not UART or SPI mode. Is that correct @jay_s_uk ?
                                jay_s_ukundefined aceranicundefined 2 Replies Last reply Reply Quote 0
                                  jay_s_uk @droftarts
                                  @droftarts yep, thats correct. Step/Dir only with no UART or SPI control
                                  • aceranicundefined
                                    aceranic @droftarts
                                    @droftarts yep, that is the one.
                                    The plan is to use 2 drivers for MMU.
                                    This should be no problem I believe.
                                    Is there a guide enywhere for the configuration of this board?
                                      Just the linked BTT PDF, and https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting_external
