    A curious printhead for the E3D Motion System
    My Duet controlled machine
    267
    • fcwiltundefined
      fcwilt
      Hi
      I finally got a print head design, for my E3D Motion System printer, that meets most of my criteria, fits in the space available and minimizes the tool offsets yielding a printable area of 300 x 200.
      It uses a LDO Orbiter v2.5 and a E3D Revo Micro. It includes a micro switch to sense with a tool is mounted.
      One of the tool boards is for the tool changer and the other for the tool itself.
      It is not pretty but it works, so far.
      The final step is to see if I can add a scanning Z probe somewhere.
      All the parts are actually printed in gray, the colors here just make editing the model easier.
      dc42undefined 1 Reply Last reply Reply Quote 1
        dc42 administrators @fcwilt
        @fcwilt on my TC I have the SZP mounted on the tool pickup.
        • fcwiltundefined
          fcwilt @dc42
          I've added nothing to the bottom so that space is free for the sensing coil.
          I should be able to mount the board to the side of the housing.
          I'm using the tool distribution board (TDB) so the CAN bus runs from the TDB to the each tool board and back, utilizing the termination on the TDB.
          Can I stub the CAN bus for the SZP controller board off of the CAN bus to the tool board?
          dc42undefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
            @fcwilt said in A curious printhead for the E3D Motion System:
            Yes you can. It may be convenient to make the SZP the last board on the CAN bus and to enable its termination resistor. You can try getting 5V power for the SZP from the IO0 connector on the tool board, but check that the tool board doesn't get too hot because it uses a linear 5V regulator.
            • gloomyandyundefined
              gloomyandy @fcwilt
              @fcwilt Wouldn't it be easier to use a roto or other toolboard that has the SZP built into it for the toolchanger board? I'm currently using one of the Fly boards on my e3d toolchanger for exactly that purpose.
              • fcwiltundefined
                fcwilt @gloomyandy
                @gloomyandy said in A curious printhead for the E3D Motion System:
                Never heard of them.
                Do you have a link or a product name I could search on?
                  jay_s_uk @fcwilt
                  @fcwilt https://teamgloomy.github.io/fly_sht36_max_v3_general.html
                  • fcwiltundefined
                    fcwilt @jay_s_uk
                    @jay_s_uk said in A curious printhead for the E3D Motion System:
                    This unit?
                    Why the non-rectangular shape? Is it designed to fit something in particular?
                    Thanks.
                      jay_s_uk @fcwilt
                      @fcwilt thats the one.
                      Fits on the back of a nema 14. Most extruder designs use these now
                      • fcwiltundefined
                        fcwilt @jay_s_uk
                        Is the sensing coil included or is that a separate item?
                        Thanks.
                          jay_s_uk @fcwilt
                          @fcwilt included
                          fcwiltundefined 1 Reply Last reply Reply Quote 1
                          • fcwiltundefined
                            fcwilt @jay_s_uk
                            @jay_s_uk
                            Thanks much.
                            gloomyandyundefined 1 Reply Last reply Reply Quote 1
                              gloomyandy @fcwilt
                              @fcwilt Or you could use the Duet Roto Toolboard, that also has the SZP built in. https://www.duet3d.com/Duet3RotoToolboard
                              fcwiltundefined 2 Replies Last reply Reply Quote 0
                              • fcwiltundefined
                                fcwilt @gloomyandy
                                That is new to me.
                                And the BEST part - I get to buy new tools and spare parts for the connectors I've never seen before!
                                Thanks for the info. I will check it out.
                                • fcwiltundefined
                                  fcwilt @gloomyandy
                                  @gloomyandy
                                  I downloaded the step file for the tool board you mentioned but it has some funny bits.
                                  What are all those little white dots?
                                  Perhaps the file needs some work?
                                    gloomyandy @fcwilt
                                    @fcwilt I've no idea, perhaps one of the Duet folks knows? @droftarts ?
