    Configurazione bl touch antclabs
    1.3k
      droftarts administrators @perfetto
      @perfetto said in Configurazione bl touch antclabs:
      good evening I downloaded the 3.5.4 firmware version and the duet2CombinedFirmware, what is the difference?
      From https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.4 download the "Duet2and3Firmware-3.5.4.zip" file. Upload this to the Duet without unzipping. This will update the firmware and DWC. You don't need to download the "Duet2CombinedFirmware.bin" file separately, it is in the zip file. If you upload just this file, it will update the firmware only. See https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#usual-procedure
      the combined version also updates panel2 i7.
      No, you need to update the PanelDue separately. Get the latest file from https://github.com/Duet3D/PanelDueFirmware/releases/latest. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue for instructions.
      last question to clarify my ideas, if the firmware version 3.0 is currently loaded, if I reload the firmware version 2.05.1 from web control does it reload or does it only accept later versions?
      If you want do revert to 2.05.1, download the "Duet2Firmware-2.05.1.zip" from https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1, and upload it to the Duet without unzipping. This should revert the firmware and DWC.
      • perfettoundefined
        perfetto
        Buongiorno, quado provo a caricare il firmware 2.02.1 o 3.4.4 caricando da web control al momento che mi chiede vuoi installarlo quado do la conferma appare errore
        errore m997 s0.txt
        grazie
          Good morning, when I try to load the firmware 2.02.1 or 3.4.4 by loading from web control at the moment it asks me do you want to install it when I give the confirmation an error appears
          Error: In-app programming binary "Duet2CombinedIAP.bin" not found in (m997 s0)
          The IAP file is the 'In App Programmer'; it is the program that updates the firmware, and needs to be accessible on the SD card. See https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#required-files
          Please send M122 and post the response, so I can see what firmware version you are currently running. If you can access DWC, please also look in the 'Settings > General' menu option, and post what version of DWC you are running.
          I guess you are using RRF 3.0 or 3.1. The "Duet2CombinedIAP.bin" is specific to these versions. Download it from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0 and put it in the /sys folder on the SD card.
          With all firmware versions up to RRF v3.2.2, all firmware update files (including the IAP file) are stored in the ‘0:/sys/’ directory.
          From RRF v3.3, to avoid too many files in this folder, all firmware update files are stored in ‘0:/firmware/’ directory.
          perfettoundefined 1 Reply Last reply Reply Quote 0
          • perfettoundefined
            perfetto
            DWC 2.0.4
            m122.txt
            • perfettoundefined
              perfetto @droftarts
              FIRMWARE 3.0
                DWC 2.0.4
                FIRMWARE 3.0
                Okay, that's fine. You need to upload "Duet2CombinedIAP.bin" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0 to the /sys folder on the SD card.
                I suggest you update to 3.5.4, and we'll fix the configuration there. Download "Duet2and3Firmware-3.5.4.zip" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.4 and upload the whole zip file (don't unzip it) to the Duet in DWC.
                Then send M122 again, to check it is updated.
                • perfettoundefined
                  perfetto
                  Ho caricato il file IAP nella cartella sys siè ricaricato il firmware 2.05.1 nei file di configurazione escono codici incomprensibili allego m122
                  m 122 -.txt
                  in seguito al tuo consiglio ho lanciato il firmware 3.5.4 adesso non si collega al web control dice versione incompatibile
                    I uploaded the IAP file in the sys folder, the firmware 2.05.1 was reloaded, incomprehensible codes come out in the configuration files, I attach m122
                    "incomprehensible codes come out in the configuration files"? Please give me an example.
                    following your advice I launched the firmware 3.5.4, now it does not connect to the web control, it says incompatible version
                    When you upgrade, you MUST go from 2.05.1 to 3.0 first. You can go from 3.0 to 3.5.4. But you cannot go from 2.05.1 to 3.5.4. I assumed you were on 3.0, and would update to 3.5.4.
                    Most likely, the firmware is still 2.05.1, but DWC is 3.5.4. So you need to go back to DWC 2.0.4. Download "DuetWebControl-SD-2.04.zip" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0 and unzip. Replace the contents of the www folder on the SD card with the files and folders from the zip.
                    I suggest you pick a firmware version, either 2.05.1 or 3.5.4, and stick to it. I recommend 3.5.4. We can fix configuration errors.
                    • perfettoundefined
                      perfetto @droftarts
                      @droftarts Ho ricominciato da zero:
                      caricato la prima configurazione funzionante del 2020
                      sono passato al firmware 2.05.1 poi alla 3.0 poi alla 3.5.4
                      attualmente in web control, impostazioni generali mi ritrovo:
                      Duet 2 2Ethernet versione 3.5.4
                      Duet Web Control DWC 3.5.4
                      allego m122 e config.g
                      m122.txt
                      config.g.txt
                      Spero di aver fatto bene
                      Grazie
                        I started from scratch:
                        loaded the first working configuration of 2020
                        I switched to firmware 2.05.1 then to 3.0 then to 3.5.4
                        currently in web control, general settings I find myself:
                        Duet 2 2Ethernet version 3.5.4
                        Okay, great! Currently, your configuration is for firmware 2.05.1. We need to update this for v3.x.
                        From your post here https://forum.duet3d.com/post/354792, you had a configuration for 3.5.1 (versione 3.5.1.txt). This is close to the configuration you need. If you have the configtool.json file for this (created by the configuration tool), can you upload it please? I can adjust it for you to match your original RRF v2.x configuration.
                        • perfettoundefined
                          perfetto
                          credo sia questo, ormi ho un milione di cartelle di prova ma questo è il primo
                          configtool.json
                          grazie
                          • perfettoundefined
                            perfetto
                            allego anche questo che fa parte della stessa conficonfig --.txt gurazione
                              I think this is it, now I have a million test folders but this is the first
                              I also attach this which is part of the same configuration config.txt
                              This configuration is a little different, but no problem, I'll check it through. I've run out of time today, so will do this tomorrow morning.
                              • perfettoundefined
                                perfetto @droftarts
                                @droftarts grazie solo una cosa la home deve essere x0 y-5
                                ancora tanti grazie
                                perfettoundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                • perfettoundefined
                                  perfetto @perfetto
                                  @perfetto
                                  Buongiorno, ho provato a settare la macchina con il configuratore 3.5 ho caricato il file zippato tramite interfaccia web, il bl touch funziona le temperature vengono gestite, la macchina non esegue la home.
                                  Nei file system ci sono molte cose strane ti ivio i file
                                  M122.txt
                                  config.g.txt
                                  config. json vecchio.txt
                                  configtool (1).json
                                  grazie
                                    just one thing the home must be x0 y-5
                                    Here is an updated configuration: perfetto config.zip.txt
                                    Download this, delete the ".txt" from the end, and unzip the .zip file. (The forum does not allow .zip files to be uploaded.)
                                    I recommend you rename the existing 'sys' folder on the SD card to 'sys_old', and copy the contents of the .zip file above to a new 'sys' folder on the SD card.
                                    The config.g is quite similar to your "versione 3.5.1.txt", but I have changed a lot of the values so they are the same as your "config.g funzionante 2020.txt". See the differences here: https://www.diffchecker.com/gZTQOoak/
                                    After you restart the Duet, please follow the 'Commissioning' guide, to check everything is working, here: https://docs.duet3d.com/en/How_to_guides/Commissioning
                                    If anything is not working, let me know. Provide as much detail as possible.
                                      Good morning, I tried to set up the machine with the configurator 3.5 I uploaded the zipped file via web interface, the bl touch works the temperatures are managed, the machine does not run the home.
                                      In the file systems there are many strange things I send you the files
                                      Please see my post above. If there are problems, please explain each one clearly.
