    Ringing in Y axis (Linear guide system, coreXY design)
    1.6k
    • JayTundefined
      JayT
      I am using Duet2 board, with corexy system of 500*500 build size. When I print, I see ringing effect only on Y-axis. Tried following solutions, but none worked.
      1. Tried with jerk values 1, 2, 3... upto 10 (acceleration 500, speed 60mm/s)
      2. Tried Different acceleration values from 500mm/s2 to 2500mm/s2 (speed 60mm/s & jerk 2)
      3. **Tightened the belts.
      4. Tried to double check alignment.
      5. Also tried DAA, but in vain.**
      6. Tried to use extra channels of Pulse & dir & use external drivers.
      a) Can you suggest what can be done to find root cause of ringing & resolve problem here?
      X axis is fine, its the Yaxis with the problem. Both on Linear guides, & Biqu extruder mounted.
      b) If it is vibrations, How do I root down the problem.
      NOTE: I am also using ssame board on a smaller bed size, with guide rod mechanism & cartesian system, it worked fine.
      Iin bigger size, rods induced vibrations, so I tried with corexy build to get better speeds.
      @jay_s_uk , @Phaedrux
      Images of ringing in XYZ cube: (ringing is always during breaking as per my observation)
      Image of setup (top view)
        jay_s_uk @JayT
        @JayT what firmware version are you running?
        JayTundefined 1 Reply Last reply Reply Quote 0
        • JayTundefined
          JayT @jay_s_uk
          @jay_s_uk : RRF3.5.0 RC3.
          NOTE: I use the same in 300 bed sized machine. It's not giving any problems.
          jay_s_ukundefined JackMartinezundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @JayT
            @JayT I would suggest running 3.6-RC3. Motion and input shaping has been rewritten in 3.6 and its much better than in 3.5
            JayTundefined 1 Reply Last reply Reply Quote 1
            • JayTundefined
              JayT @jay_s_uk
              @jay_s_uk said in Ringing in Y axis (Linear guide system, coreXY design):
              3.6-RC3
              Motion shaping as in acceleration profile ? (I am not using input shaping, as it didn't give much results).
              Do you see this problem arising from acceleration/deceleration profile ?
                jay_s_uk @JayT
                @JayT i don't think this will be something you can tune out by adjusting acceleration etc.
                Input shaping is the way to go to reduce this
                • JayTundefined
                  JayT @jay_s_uk
                  @jay_s_uk : Ok Let me try that. Meanwhile can you tell me if this is common in Linear guide systems? Any suggestion to check on design side?
                  jay_s_ukundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @JayT
                    @JayT yes, ringing is common. It happens more in Y on coreXY as you're moving the whole of x axis about
                    • mrehorstdmdundefined
                      mrehorstdmd @JayT
                      @JayT Have you tried tweaking the motor currents?
                      • JayTundefined
                        JayT @mrehorstdmd
                        @mrehorstdmd :
                        YEs, we initially used 2000mA, reduced it down to 1600mA.
                        • Tried to use Pulse dir pins with external driver as well. no luck.
                        • I am using 0.9deg motors (as with 1.8degree there was vertical ribbing in Y axis).
                        • I had built cartesian system, even then Y always had ringing. this wasn't the problem with 300bed side. Then we moved to Corexy for 500 bed size, but ringing appear despite slow speeds.
                        • JackMartinezundefined
                          JackMartinez @JayT
                          @JayT said in Ringing in Y axis (Linear guide system, coreXY design):
                          Yes, you are right, I also have the same and it works fine.
                            dc42 administrators @JayT
                            @JayT there are at least two possible sources of this resonance:
                            1. The combination of the heavy Y axis and the belts. Increasing the belt tension will increase the frequency of this resonance and may also reduce its amplitude somewhat.
                            2. If the tool head is heavy and its centre of mass is displayed from the Y axis by much distance then there will be resonance due to torsional rotation of the tool head about the Y axis. The frequency and seriousness of this will depend on the moment of inertia of the tool head about the Y axis, and how stiff the Y axis metalwork is. To reduce the amplitude of this resonance you will need to reduce toolhead moment of inertia (e.g. if using a direct drive extruder then switch to one with lower mass) or make the Y axis stiffer so that it better resists twisting.
                            On my E3D tool changer with Hemera tools, #2 is by far the most significant.
                            I suggest you upgrade to firmware 3.5.0-rc.3 and then use an accelerometer and the Input Shaping Plugin in DWC to measure the frequency of the ringing and tune input shaping to mitigate it.
                            • JayTundefined
                              JayT @dc42
                              @dc42 @jay_s_uk :
                              • Based on suggestion, I tried latest firmware 3.6 RC3.
                                NOTE: Tool head is Biqu. (not much heavy, with 3dpinted ducts for part cooling).
                              • Attached is an image with the top one printed using DAA & bottom one is how base printing without DAA appears. There is absolutely no difference after input shaping. (I manually calculated distance between 2 lines using vernier (except the corner one) ).
                              1. Jerk is 5.
                              2. DAA: speed is 120mm/s, acceleration 800mm/s2, and distance is 2mm between 2 lines, so that 60Hz for DAA. We used ZVD mode.
                              3. In the top cube, I also modified acceleration to 1500 mm/s2, but no difference.
                              Can you suggest here further?
                                jay_s_uk @JayT
                                @JayT best off getting an accelerometer and measuring it properly.
                                And ZVD is not the most aggressive input shaper, see the data evaluation info here about the different shapers https://docs.duet3d.com/en/User_manual/Tuning/Input_shaping_plugin#data-evaluation
                                maybe try ei2 or ei3
                                • JayTundefined
                                  JayT @jay_s_uk
                                  @jay_s_uk :
                                  @dc42 :
                                  Thank you for suggestions. I used EI2 & EI3 methods input shaping modes with 20Hz, and it indeed reduced ringing, also with reduced print speed, it further goes down. I am reading on connecting accelerometer to find exact frequency.
                                  Can you suggest where should I fit my accelerometer for Y-Axis? (on the extruder ? ) , NOTE: The accelerometer doesn't have axis marked.
                                  Can you mark in the picture above to suggest?
                                    jay_s_uk @JayT
                                    @JayT the closer to the nozzle the better. There are mounts you can print that let you mount an accelerometer directly to the nozzle (just for data capture)
                                    • JayTundefined
                                      JayT @jay_s_uk
                                      @jay_s_uk :
                                      Hi Jay, I tried 20Hz, result was better. And I used following accelerometer curve to detect the exact frequency. as per this 27.4 shaper frequency, but that does not remove ringing for me like 20Hz. Can you suggest further on how to proceed here or how to analyze this graph?
                                      Also What is the role of damping factor ? At 20Hz with 0.05 i get better result I feel. but I need to find proper frequency & damping factor to make its smooth.
                                      Damping factor 0.01
                                      EI2
                                      Mounted above BLtouch mount.
                                      • JayTundefined
                                        JayT @JayT
                                        @jay_s_uk
                                        @dc42 :
                                        Below is result at 20-22Hz frequency, where many lines reduce, speed is 60mm/s, so the lines are closer. However, I am not able to remove these lines in the picture.
                                        How do I capture this frequency in input shaping method?
                                        This is with damping factor 0.05 though, with 0.01 lines are more prominent i felt.
                                          @JayT as the ringing is so severe, you are unlikely to cancel it completely. You could try other input shapers such as ZVDD and ZVDDD.
                                          • JayTundefined
                                            JayT @dc42
                                            @dc42 :
                                            Hi David, I still see enough ringing despite using ZVDD& ZVDDD modes, but none reduce the ringing much. What am I missing here? The best frequency that works 20Hz with EI2 mode. But i still see lines on the plane Y facet.
                                            Can you suggest what can be optimized in Settings or the design to eliminate this ringing in Y direction?
                                            With cartesian i was able to solve ringing but could never attain acceleration > 800mm/s2 & speed >100. Same is the case with coreXY as well. I am not able to move to higher acceleration or speed.
                                            P.S.:
                                            1. I tried 0.9 degree double stack as well
                                            2. ZVD ZVDDD modes with 20Hz frequency.
